How to fix box x2 problems no pictures all Google tv
I have a 50 inch Hisense TV and the picture went out but I'm still receiving sound.... Can you please help me with a fix for the problem?
It all depends what has led up to the problem, however if there has
been no indication of something going wrong,ie. picture getting dimmer, the most common fix is to reset.
First just check all cables are firmly connected. If that does not work then....
Unplug tv, disconnect from cable box, satellite box, any receivers.
Also turn power off to them as well.
Connect everything back and turn on.
Here is a video of other generic problems that can go wrong on any
tv that leads to sound with no picture.
TV Has Sound But No Picture Troubleshooting Guide
Nov 19, 2015 | Hisense Televison & Video
Nokia x2-01 battery low problem
Why not try a call blocking app like LEO Privacy? I have used it almost one year and it works well on my Samsung. LEO Privacy Applock Hide Safe Android Apps on Google Play
Dec 29, 2013 | Nokia X2-01 RED,BLUETOOTH,FM,QWERTY...
Sony kv 34hs420 no picture blinks 7 times unplugged for days. Does not fix problem. Any hope?
Visit this site for details. Most of the faults to Sony Trinitron TVs are described there. Type in "Electro-help" either to yahoo or Google search box and click search. You can see the site with same name [with a hyphen in between words]. Click it open.
May 12, 2012 | Sony KV-36XBR400 36" TV
How do I enlarge the picture on my Dynex 32: LCD TV (32l152a11)
Consult the owner manual (Google model number with "manual" if you do not have that) and also if using a box look at settings in it.
Some boxes will (fixed and not changeable) determine the size of the picture.
Apr 09, 2012 | Televison & Video
Cant get picture on tv
Disconnect from Directv box, and test DVD plaver with tv, if picture returns the problem is with the Directv Box, I would call them up to get this matter fixed.
Mar 10, 2012 | Memorex MVD2040 DVD Player
I have a fairly new Hisense ltdn24v86us television. The menu keeps popping up in front on my picture and it prevents me from watching tv. Almost any button on my my remote will make it go away but it...
Go into the television settings menu and look for something in the section that the pop up box mentions. I had a Sharp television that made the box pop up if the stereo signal turned to mono due to lack of audio strength. If you turn off the error reporting, the box will stop.
You can also Google the make and model of your set and look for the manual for clues.
This article has a neat fix for you and thinks it is sticking buttons on the remote or the set. Take the remote out of the room for an hour. Press all the buttons on the side of the set.
Fix Your TV Instantly
Sep 05, 2017 | Televison & Video
Yamaha htr6180 with Motorola HD Cable Box Causes Picture to Blink
Can't be done. Your version of HDMI firmware and hardware in your receiver have "handshake" and "HDCP" incompatability issues that are too costly to fix. Your receiver has version 1.1 HDMI and the current version is 1.3b and soon to be 1.4. HDMI is not to blame though; it's RIAA, the recording industry that keeps changing audio and video codecs to protect against "copyright infringement" It's a ROYAL LOAD of !@#$%^&*. I am in the industry and have been avoiding HDMI at all cost! Too many issues! even with current BLURAY players they are using RJ45's on the back to allow software updates to keep in line with all the new codecs. If you want more info on HDMI and it's many issues; google "HDMI problems" and you can read forever!. Sorry for the bad news, but it is the fact. Hope this at least helps in understanding that there is nothing wrong with your product! it's the recording industry!
Oct 23, 2009 | Yamaha HTR-6180 7.1 Channels Receiver
Need to know how to display the Laptop screen onto my Tv please?
you either need a Tv-Out card or an adapterTV Out box to connect the Laptop to the TV. Optionally if your Tv has a SCart connector(Google for what that means), you could connect the Laptop directly to the TV, instead of the adapter.
Jan 26, 2009 | HP Compaq Presario CQ50Z-AMD Sempron(TM)...
Black box in the middle of my mitsubishi tv
This is a common problem, some how you have the closed caption on and turned to the text mode. So to fix this scoll through the tv's menu and find the closed caption and tur it back off
Mar 27, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Picture Flashing
I have a similar problem but my picture flashes black and white and the sound goes at the same. Also sometimes it will flash pink and blue. I've read elsewhere that the issue is a known problem with compatability between Samsung tv's and sky boxes. Apparently the box needs to be replaced but I'm unsure what type of box. I've read perhaps a PACE sky box could fix the problem. I think the best option would be to contact Samsung - that's what I'm going to do.
Feb 14, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
