I have a tajima TFHX-IIC 1504 embroidery machine. how do i get the computer unlocked?
I had a code come up and i had to leave the shop so i shut the machine down and when i turned it back on the computer will not work.
SOURCE: Janome Memory Craft 5700 shut down and won't turn on
I have had the Janome5700 since July 2006. I purchased it from QVC for a very affordable price Brand New. I also purchased a warranty from Sears because Janome makes Sears machines. They were willing to sell me the warrranty. I keep my machine clean and bring it to Sears at least once a year for a routine maintenance. I also have brought it once in between as I felt it needed a cleaning in between the yearly. They were more than happy to service it. I use my machine every day and have had no problems. If you have any questions you can contact Janome on line as they have a wonderful customer service and tech-support no matter how old your machine is and never ask the age of your machine or where you purchased it. Try Janome.com it is worth a try. Remember never oil your machine or take it apart. Let an experienced tech person help you. It is worth the extra money.
Posted on Apr 15, 2008
Saigua
  • 981 Answers
SOURCE: will embroidery designs from Dakota
 Why wouldn't you ask Dakota collectibles?  Moreover, why would you care as long as you can find free software for your PC that converts designs from format to format?
Posted on Jul 31, 2008
  • 4 Answers
SOURCE: I recently bought a Singer
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura software.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
t00nz
  • 4738 Answers
SOURCE: camera turns on and then shuts down leaving the
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jul 14, 2009
jpack76645
  • 23 Answers
SOURCE: what is a 211 error code on a tajima 2 head emb
A 211 is generally caused by the degree wheel not resting in the "red" zone. This zone indicates the machine is in a ready state to start or shift. Look at the degree wheel and manually move it to the zone (around 100-110 degrees). If this doesn't work it will need repaired. It usually takes 1-3 hours depending on what is involved.
Posted on Dec 01, 2009
How do you correct/fix a 316 error/main shaft motor error on a Tajima 2 head embroidery machine
I hope this link will help.
http://www.digitsmith.com/tajima-tmfd-g1220-type-2-error-316-a-31639.html
Sep 28, 2017 | Sewing Machines
I have Tajima embroidery machine TFMX1508 Igot error code 6D2 what's wrong is it who knows
This should be in your Troubleshooting guide in the manual.
Here are some codes related to trouble codes on a Tajima machine, may need the correct error codes for your make Model machine.
http://www.theembroiderywarehouse.com/errorlist.pdf
Cheers and good luck!
Embroidery Services
San Diego, CA
Aug 07, 2017 | Sewing Machines
How do I fix error code BC1 on Tajima Embroidery Machine when there are designs on the flashdrive that did work yesterday
The format of your program may have different formats that will work for Brother but not Tajima. The extension of the program is the key to the one to use. You will notice a program name that is the very same but the extension is different. Your program can't be found if you use the wrong extension. Use other design extension or you may need to register the program.
Nov 18, 2014 | Sewing Machines
Hello, Error 225 Travel outside the set embroidery area
( When the software frame limit is set, or
on cap machines) Here is website for all the errors:
May 17, 2014 | Sewing Machines
Hi. I have a commercial one head tajima embroidery machine. I was sewing and realized I had no thread on one bobbin so I stopped the machine. Instead of continuing on, I decided to start all over with a...
Your new embroidery program has to be loaded first. The 2b7 is referring to needing instructions or in other words the embroidery program has to be loaded. Shut the machine down and turn the machine back on and load just as before.
Jul 06, 2017 | Sewing Machines
Tajima embroidery machine troubleshooting
We are having a similar problem with one of our single head Tajima TMEX-C1201 machines. In our case the design runs part of the way, then the head jumps and continues running and ruins the work. Any feedback on this would also be appreciated. Thanks.
Jul 15, 2013 | Sewing Machines
Tajima tfhx-2c1502 s card
What is your question or problem?
Feb 01, 2013 | Sewing Machines
Tajima embroidery machine error code 316
it sounds like their is a problem with the electronics of the
embroidery machine and the machine needs to be checked.
Dec 19, 2012 | Sewing Machines
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
