Question about Lands Phones
Answering machine message
How do I record a message for incoming calls?
  • kakima Dec 23, 2016
    Hi Astrid Turner, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
  • judy fitz Dec 24, 2016
    Astrid,
    Please tell us what kind of phone or answering machine do you want to record message on?
Candyhelp
  • 136 Answers
SOURCE: answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
Posted on Mar 30, 2008
SOURCE: GE Telephone answering machine will not work
298976e2-a owners manual,
i have same problem,
sorry if my english not the best.
i "paste and copy"
We have the answering machine set to 4 rings. When people call, the machine picks up on the 4th ring, it beeps, then cuts off. No recorded message. No message is recorded, the call is disconnected. What do we do?
send me email.
samspicuglia@rogers.com>>>Canada
Posted on Jul 03, 2008
SOURCE: Problem with answering machine on Panasonic Model # KX-FPG376
i followed the advice posted & it worked fine after that. thanks.
Posted on Nov 25, 2008
Junoon007
  • 1011 Answers
SOURCE: answering machine not picking up phnone messages
sir,
can u provide brand name and model no.
Posted on Dec 16, 2008
SOURCE: vtech w/answering maching does not allow outgoing calls or record
unplugging the unit from the power source and waiting 30seconds seems to be the answer. the answering machine is working and i can call out again.
thanks you to everyone who posted that answer in different parts of FixYa.
Posted on Jan 31, 2009
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
Jan 25, 2015 | AT&T Lands Phones
Uniden d1680 answering machine doesn't record messages, only dial tone.
If the system doesn't answer the call at all then you need to turn the answering system on. If it answers the call but does not record a message then you need to turn "Announce Only" off. Both of these are in the Answering System Menu options described on page 13 of the manual.
Apr 18, 2012 | Uniden D1680-3
I have a Uniden cordless answer machine,Can my meesages be retived?
You can operate your answering system from a remote location using any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even to record a new greeting message.
  1. Call your telephone number.
  2. During the greeting message, press 0 and enter your PIN code. By default, the pin code is "80" without the quotes.
  3. The answering system announces the current time and the number of messages stored in memory. Then you hear "To play incoming messages, press zero two. For help, press one zero".
Available commands are:
  • 0 then 1 Repeat a Message
  • 0 then 2 Playing Incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop*
  • 0 then 8 Greeting Message Record/Stop*
  • 0 then 9 Answer System Off
  • 1 then 0 Help Guidance
Jan 23, 2011 | Office Equipment & Supplies
How do you record a message for incoming calls?
The "recording outgoing messages" is the first thing on the second page of the manual at
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/4303829_PM_EN.pdf
Dec 29, 2010 | Radio Shack (43-3829) Digital Answering...
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
PERSONAL RESPONSE TO INCOMING CALL
Here are two screen capture from the manual to help you record your outgoing message.
Feb 04, 2010 | Uniden TRU8885 Digital Answering Machine
Not recording
Record Time sets the duration for recording the incoming messages. You have three
record time options. The options "1 minute" or "4 minutes" set the duration for
recording the incoming messages. "Announce only" answers the call but prevents
the caller from leaving a message.
1) Enter the Answ. Setup menu, and then the Record
Time submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select Record Time
(1 Minute, 4 Minutes, or Announce Only)
3) Press the OK soft key. You will hear a confirmation tone.
Feb 02, 2009 | Uniden TRU8885 Digital Answering Machine
Vtech w/answering maching does not allow outgoing calls or record
Jan 31, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
No Recording
Make sure the answer mechine is ok. Press "On/Off" serveral time. You can try to record your personal memo ,to check if the answer machine can at least record message locally.
Jan 17, 2009 | GE 29875GE Digital Answering Machine
Lands Phones Logo
82 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
