Question about Home
Where do i put the batteries in my dreamgouse mirror
Just put new batteries in. No film. I looked at the view finder and snapped a pic then the screen went black. I took the lens off and the mirror is sideways.
You have two main possibilities. The new batteries are incorrectly inserted or the batteries are faulty.
If not those, then it's a camera fault (it's definitely faulty if the mirror is actually sideways and not merely halfway up) and as you can get N75's for free these days (my last two have been boxed and nearly unused from FreeCycle) then it's simply uneconomical to repair it unless the mirror can simply be removed and correctly re-fastened. Spare parts availability is already very poor for the n75.
Aug 03, 2010 | Nikon N75 35mm SLR Camera
How to replace mirror in toyota corolla
1) Disconnect the Corolla's negative cable to the battery.
2) Remove the triangle-shaped interior mirror cover from the top of the
door panel. Pry the cover off with your hands, a blunt plastic or
wooden tool to prevent damage to your door trim.
3) Take out the mirror wiring connection.
4) Remove the door trim bracket around the mirror. Take out the
mounting nuts.
5) Pull the power mirror off the Toyota Corolla.
1) Put the new mirror in place on the Camry.
2) Re-install the mounting nuts making sure they are securley holding
the mirror in place. Replace the mirror insulation.
3) Reconnect the wiring to the new mirror.
4) Install the triangle interior cover by snapping it back in place.
5) Connect the negative battery cable.
Thanks
Xeeshan
Nov 22, 2009 | 2005 Toyota Corolla
Cannot take picture, no film advance, new battery
The shutter could be stuck or the mirror could be stuck. (Guessing you have an SLR.)
The film advancing is normal; means it is cocked and ready to go but something is stuck.
Take off the lens and see if anything is keeping the mirrors/shutters from returning.
Oct 23, 2009 | Canon EOS-AE-1 35mm SLR Camera
Remove/replacing side view mirror on a jeep grand cherokee
    Remove the Old Mirror
  1. Step 1 Disconnect the negative battery cable before you take off the grand Cherokee front door trim panel. Remove all screws and clips.
  2. Step 2 Detachthe window trim cover screw, and control lever screw beforedisconnecting the entire mirror trim cover. Remove the rubber coverinside the mirror cover, and disconnect the electrical wire.
  3. Step 3 Remove three nuts from the power mirror using a Torx® star-shaped screwdriver.
  4. Step 4 Pull out the outside rear view mirror. Guide the power wire through the hole in the door.
  5. Install the New Mirror
  6. Step 1 Replace the old mirror. Put the new power mirror in place. Push the new wiring through the hole in the door.
  7. Step 2 Install and tighten the three retaining screws you took off when removing the old mirror.
  8. Step 3 Connect the power mirror wiring to the connection located on the door panel. Replace the rubber cover and interior mirror cover.
  9. Step 4 Put the front door trim panel back in place by securing all clips and tightening all screws.
  10. Step 5 Connect the Subaru Outback's battery cable to restore the power.
i will recommend i site where you will get all the information you need to remove and replace your side mirror
http://www.wjjeeps.com/mirrors.htm
Sep 10, 2009 | 2004 Jeep Grand Cherokee
Outside mirrors go down when in reverse and go back up when put
that is normal it is the reverse mirrors for backing up if you go into the menu you can turn off that function
Apr 04, 2009 | 2002 Lincoln Continental
Shutter stays open-battery sign flashes but they are full..
This could be one of a number of problems, but first check the battery contacts are clean. These cameras rely on an elecrtic motor to drive the mirror and prime the shutter. The extra current drawn may cause the voltage to drop if the battery contacts are dirty.
Another possibility is a shutter fault, either the shutter has a sticky deposit or there is an electrical problem. Last time I had one like this I found a crack in the solder connection to the shutter.
Putting a new battery meants the camera will reset to a default setting. This means the shutter will be instructed to fire and the mirror return to it's initial position.
Jan 17, 2009 | Canon EOS Elan 7e with 28-80 lens 35mm...
Side Mirrors will adjust side to side but not up and down.
There are two tiny motors in each mirror. one for up/down. One for side to side. They have jack screws (plastic) that fit into the motors.
You can manually put your hands on either side of the mirror and force adjust it. If you hear a ratcheting sound, the jack screws are OK. Then repeat with hands on top and bottom.
If you hear ratcheting and mirror stays where you stop it, that means one of the motors is bad. The motor assembly is available as a separate part.
Mirror Motor—Crown Victoria, Grand Marquis
Removal and Installation
  1. Disconnect battery ground cable. Refer to Section 14-01 .
  1. Remove outside Rear View Mirror Glass as outlined.
  1. Remove Outside Rear View Mirror as outlined.
  1. Remove two screws from outside rear view mirror motor.
  1. Remove outside rear view mirror housing from outside rear view mirror base.
  1. Disconnect connector and remove outside rear view mirror motor from mirror housing.
  1. To install, reverse Removal procedure.
Might be cheaper to buy used irror at car-part.com. Look for * to find page with cheapest part. Or, EBay. Good luck
Aug 11, 2008 | 1996 Ford Crown Victoria
Mirror Locked in Up Position
When you say you put in a new roll of film, did the camera advance the film with the mirror locked up? Have you tried triggering the shutter few times to release the mirror? If that doesn't work, open the back of the camera. Turn the film take up spool in one direction...that should release the mirror down. Turn it also in the opposite direction. If that doesn't work, reach inside the lens mount opening and pull the mirror (very very gently) down. Don't force it down if it doesn't want to go. Sometimes that releases the mechanism that freezes from sitting idle for too long. It is always a good idea to take the camera out and triger few frames every couple of months to keep things lubricated. Let me know if that fixes it. AJ.
Sep 03, 2007 | Nikon N70 35mm SLR Camera
Home Logo
35 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
