I accidently dropped my Power Glide 60101325 14.4 volt 3/8 inch cordless drill. The plastic casing is damaged and won't screw tighten due to damage. Where can I get a new case? raylinks
when i plug in the battery to recharge the two lights on the left light up and the battery does not...
(More)
when i plug in the battery to recharge the two lights on the left light up and the battery does not charge. I tried it with two different batteries. Is the charger defective? Thanks
One of the front power jacks will not work. The motor side works great. The orthe side the gear on...
(More)
One of the front power jacks will not work. The motor side works great. The orthe side the gear on the shaft from the motor turns and it also turns the gear that raises and lowers the jack but the jack does not move. Are thys a pin that has been sheared and can it be fixed?
I lent my Ryobi 18 V batteries and flashlight to a friend during a power failure. When they were...
(More)
I lent my Ryobi 18 V batteries and flashlight to a friend during a power failure. When they were returned, both batteries would not take a charge and the green yellow lights show on the charger. Are the batteries toast, and is the problem that they were charged before they had a total discharge?
