Question about Vizio Televison & Video
Does the Vizio E43u-D2 support 4k 10 bit input?
Tip
Vizio TV Input Menu Scrolling
Read the recommendation about holding the Input button of the side of the Vizio TV to 'reset' the Input option. The scrolling was driving me a bit nuts so I tried it and "IT WORK GREAT". Certainly beats having to replace the circuit board recommended in other suggestions submitted.. Thank you for you helpful advise.
on May 31, 2015 | Vizio VA Televison & Video
Vizio av input
On the specs for this tv, you might have to use an HDMI cable if your dvd or blu-ray supports it. Look for a small rectangular jack labled "HDMI" on the back of the DVD player. HDMI cables are about $10 stores. And you only need One. For both Audio and Video.
Jan 18, 2014 | Televison & Video
Vizio p50hdtv10a led light blinks 10 times when powered off
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 16, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Why does my 32 in. Vizio make a loud noise and then turn off?
There is something shorting inside, possibly due to moisture collection. First, change input device to some other and see, if it works fine, the problem is with the input device. If you notice same problem, this may need attention by a qualified service technician.
Jul 21, 2012 | Vizio L32 32 in. LCD HDTV
My vizio tv wont turn on. Any secret buttons that
Hi my name is Roety,
I can help you with your issue ,
 Check the AC plug, to reset the TV unplug and connect it. If the power light lights up check the input select button the TV needs to be own the correct input to view TV again.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Jan 26, 2010 | Vizio VW32L 32 in. LCD HDTV
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
Vizio lcd hd--sounds fades and then no sound after 10 minutes
Sue, I had same problem. I worked around it though, and glad I did. I used a computer sound system (sobwoofer, 2 speakers, power supply) and used the headphone output as the speaker system's input. Now I have surround sound controlled by the remote. Great for the kitchen where we all sit around and watch movies.
Apr 04, 2009 | Vizio VX20L 20 in. LCD TV
Connection problem to tv
For this to work please make sure your TV is tuned to its "AV" input channel. It will not display a picture on any of the normal tunable channels.
Feb 03, 2009 | Video Cameras
P50 VIZIO WHEN ON HDTV I GET SNOW
it's probably the Time Warner cable box that have issue and not the TV. Try using a DVD player and test the same input, it should work fine.
Nov 15, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
