Question about Garden
My actuator will not go up or down on my snowbear plow. the black box clicks when trying to operate plow up or down with the controller
2 Suggested Answers
adamfjeld
  • 1508 Answers
SOURCE: plow lift actuator is not working but is getting
this is the forum for the kids toy
Posted on Jun 08, 2012
I chang fues still no power fisher minit plow 2005 gmc plow work fine last year put on now no power to control box
May want to begin tracing the wiring harness from the plow all the way to the control box.
Dec 23, 2016 | GMC Cars & Trucks
2009 Chevrolet impala has a clicking noise in the heater and ac system
That is more then likely a blend or a mode door actuator , they have plastic gears inside that strip an get stuck an then they just click .
The air temperature actuator is a 2-wire bi-directional electric motor. Two control circuits enable the actuator to operate. The control circuits use either a 0-volt or 12-volt value to coordinate the actuator movement. When the actuator is at rest, both control circuits have a value of 0 volts. In order to move the actuator, the HVAC control module grounds the appropriate control circuit for the commanded direction. The HVAC control module reverses the polarity of the control circuits to move the actuator in the opposite direction.
The mode/recirculation actuator is a 2 wire bi-directional electric motor. Two control circuits enable the actuator to operate. The control circuits use either a 0 or 12-volt value to coordinate the actuator movement. When the actuator is at rest, both control circuits have a value of 0 volts. In order to move the actuator, the HVAC control module grounds the appropriate control circuit for the commanded direction. The HVAC control module reverses the polarity of the control circuits to move the actuator in the opposite direction.
The HVAC control module determines the door position by counting motor pulses on one of the control circuits. These pulses are small voltage fluctuations that occur when the brush is shorted across 2 commutator contacts as the motor rotates. As the actuator shaft rotates, the HVAC control module monitors the voltage drop across an internal resistance to detect the pulses. The HVAC control module converts the pulses to counts with a range of 0-255 counts. The HVAC control module uses a range of 0-255 counts to index the actuator position.
Your have to figure out which side of the heater box the noise is coming from . The Temperature Valve Actuator Replacement - Right Side - the glove box needs to come out to get to it .
Temperature Valve Actuator Replacement - Left Side
the driver side knee bolster needs to be removed
Jul 09, 2016 | Chevrolet Cars & Trucks
I have a fisher minute mount an older model with fixed controls. plow goes up and down but does not go left or right, sometimes with the control set for left or right it starts to go up ? where to sta
check the wiring connections on the plow solenoids to be sure they are correct, the second step is check the controller box, using a continuity check via multimeter set for DC voltage. I have an old western plow that had similar symptoms, and was the controller box.
Oct 19, 2014 | Cars & Trucks
I have a 2003 f-250 with a curtis sno-pro 3000 hitch n run plow system. when i go to lift plow or go left or right it kills the truck. the light shut off and every thing else as soon as i hit any of the...
I think you have a problem with the plow motor grounding out. when you raise or turn plow in either direction you have to run the plow motor which is grounded out. ( as in hooking the ground and positive together directly ) the plow is on a gravity drop when you let it down by the weight itself and does not require the motor for the plow to operate. It's your plow motor or the positive feed to selonoids.
Feb 05, 2011 | 2003 Ford F250 Super Duty Crew Cab
NO power wont lift
boss plow will not go up or down, do not have light on main control. Truck lights will go on but when toggle switch is activated, truck lights stay on and plow lights will not go on.
Jan 28, 2011 | 82" TruckSUV Snow Plow
2006 snow bear plow, winch will not lift plow, sounds like its turning but is not lifting plow consistantly, Is something loose?
Yes, Check where strap or chain is mounted to winch. It could be loose or have dirt or oil on it something to make it slip.On mine there's a brass piece that raps around the shaft, It got lose and dirty so I cleaned and tightened it. If you pull motor off winch to check gears [don't use gear] when reassembling it's too thick when it's cold. I used white spray lube. Hope it helps!
Jan 20, 2011 | 82" TruckSUV Snow Plow
Snow Bear Winch..... Will not pick up plow at times. Motor seems strong drum will not turn,,,slips. Is there a replacement part available without buying an entire winch? Thanks
Hi there, I had the same problem, my winch has a chain to lift the plow.I put oil on the chain to keep from rusting and thats what started my troubles.So I took the mount off that holds the chain on the winch and there's a brass piece that is squeezed behind it.Cleaned and tightened it and works fine now. If you take motor off winch to check gears[ DON'T USE GREASE] when reassembling! When its cold it doesn't want to turn, just use motor oil or spray lube
Jan 19, 2011 | 82" TruckSUV Snow Plow
My problem is when i turn my defrost to another setting i get a clicking sound from a little black box i have no taken out, its a little steal rod that runs from the settings down to the black box and then...
its called a blend door actuator, it contains an electric motor and gears that operate the blend doors over time the gears strip out inside the actuator,it needs to be replaced, and can be quite a job to get to my advise is to take it to a local dealer, they know the product and it may not be as costly as you might think..
Dec 12, 2009 | 2002 Nissan Altima
08 avalanche frame the same as 07 ??
I've never heard that there was a difference in the frames but who knows...
Oct 19, 2008 | 2008 Chevrolet Avalanche
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
