Question about Cameras
How can you test a camera before use to be sure the flash sync is working properly.
  • 28 Answers
Set camera up and aim at a blank wall. Place flash on camera, fire off test shots with camera set to flash sync speed and lens set to wide angle (eg 18 mm), ensure flash matches angle of lens.
You will probably have to turn auto focus off, so that camera will fire, after taking photo/s use review to ensure that you have a nice even coloured piece of wall.
Any problems either with camera sync problems or flash coverage will show up in the test shots.
Camera sync, will show as part of the frame only exposed, for example you may find a horizontal line approximately 1/3 to 1/2 of frame with a proportion of the frame dark.
If you have flash "drop off" you will find the corners of your frame will be dark, you need to ensure that your flash angle specified on the flash and the focal length of the lens match.
Hope this helps Ian
Posted on Aug 14, 2009
The flash and picture are out of sync.
If your flash has worked properly in the past, the camera may need to be serviced. If your subject is within 6 - 8 feet and is not being properly illuminated, something needs to be adjusted or replaced.
By specification, your flash will only adequately illuminate subjects out to 14 feet (wide angle) or 10 feet (telephoto). If you're trying to shoot subjects further away than that, the flash is not bright enough.
Dec 28, 2009 | Canon PowerShot A630 Digital Camera
Camera won't take a picture
chk the flash bulb seem it is blown off.
Jul 31, 2008 | Photography
Nikon SB600 / D90 out of sync
Check that the terminals on the flash and the camera foot are clean Use a pencil eraser to clean thyem by using a gentle rubbing motion. reconnect and test.
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Nikon Speedlight SB-600 TTL Flash
Flash fires but the image is dark. Tried the flash on two Canon cameras, same problem with both.
Check the flash sync speed on the cameras. With most film cameras, the flash sync speed is 1/60 of a second.
With digital cameras, you must use a flash rated for the digital camera and use their recommended flash speed.
If the camera to flash sync speed is correct it is possible that the flash output is weak. This would be due to the battery not being able to properly supply, or some defective components in the flash circuits.
You will require a flash sync detector, a flash intensity meter, and a battery load tester to perform the the first level of basic tests if you wish to analyse the fault yourself.
This is not a problem you could service yourself, unless you are experienced and knowledgeable for servicing flashes.
These flash units use very high voltage at a very high current when operating. The current is built up and stored in a very efficient high voltage capacitor. A flash can be dangerous to service yourself.
Jerry G.
Sep 25, 2009 | Canon Speedlite 220EX TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    No iTTL mode (or TTL mode) in SB 800 synced with cord to D300
    Bingo! That's an X-sync cable, only for firing the flash, syncing it withe shutter - carries out no auto features or communication with the camera.
    Don't waste your money on another cable the same. There is no TTL light measuring features with an X-sync cable.
    You can, however, get the proper 'off-the-camera' TTL syncing cable either from Nikon or a 3rd party provider. This proper TTL cable can cost a fair bit, I don't know exactly but thinking from $40-$50 to $80'odd.
    Shop around, buy from a store where you have the face-to-face enquiry and a return facility if 'they' get it wrong.
    **.The best way to acknowledge contribution is to rate it's relevance.**
    Feb 04, 2009 | Nikon Speedlight SB-800 TTL Flash
    Novatron 240 Flash Kit
    First you need to isolate the problem by doing some troubleshooting.
    1) try a known good sync cord to determine if the problem is the sync cord and not the power pack.
    2) try a known good sync cord with a known good camera to determine that the problem is not in the camera.
    3) try your camera with a different power pack to confirm your camera is triggering the power pack OK.
    These steps will isolate the source of the problem.
    Aug 24, 2008 | Cameras
    952AF/CAN Flash
    I guess you did the basic thing and see if the flash fires when pressing the shutter button.
    I don't know the Rebel itself,but I can suggest a few general things. I will be speculating here for you.
    Make sure that in the setup for the flash, that the curtain is in the correct mode. If I remember right there is something about when the flash will fire. Check this in the instruction manual.
    Also check the flash sync speed range. If the sync speed is out of range for the flash, it will fire at the wrong time. If you want to experiment, try using 1/60 for a start just to see if it works.
    If you call Canon tech support, they will help you.
    Jerry G.
    Apr 17, 2008 | Cameras
    Problems with my camera's flash...
    Well if you have time and the camera manual with you check out the settings to make sure you have not missed anything. You could also check out the Fuji Tech Support at the Website Not much else you can to unless you can find a repairer- after all you re in the land where they are all made.
    Jun 10, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
    Cameras Logo
    112 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
