Question about Electrolux Dryers
Purchased an Electrolux dryer Labor Day 2016. Ever since the first load, it has made a "bang" noise every 5 to 6-1/2 minutes, until the cool down phase. Any idea what could cause this? Thanks
  • Jo Downing
    Jo Downing Dec 24, 2016
    We have have 3 techs out here in the past few months and they still haven't fixed the problem. Last tech replaced 2 thermostats and the idler arm, but that didn't fix the problem. Another tech is coming out again this week. There is also condensation running down from the bottom of the door, down into the pedestal.
  • Bill Boyd Dec 24, 2016
    time to ask for a replacement unit or a refund as it is not fit for the purpose
    contact head office and state that the technicians cannot fix the fault
    Top Expert:
  • Electrolux Master
  • 51,198 Answers
Get a technician out under warranty to fix it
it should have gone back the first bank for repair
Posted on Dec 23, 2016
My Electrolux from load washer GLTR1670AS0 started making a load banging noise during the high speed rinse out
One or more of the washer drum shocks is broken and or the washer drum bearing is defective and has excessive play.
Jan 28, 2017 | Electrolux Washing Machines
My tumble dryer is making a loud banging noise when it turns. It is on for a few minutes and seems to happen when it switches to turn the opposite way
It will be worn slipper pads that are around the front edge of the drum. If your dryer can run when inverted that will stop the noise until the pads wear down again.
Purchase some new slipper pads and remove the back panel of the dryer moving the drum back about 1 inch. You will now see were the slipper pads are fitted around the inside edge at the front.
There will be about 6 of them, you can take the top ones and move them to the bottom. This will also stop the banging until they also wear down.
Oct 24, 2015 | Dryers
Why is my Electrolux dryer EIED overheating
Check the exhaust duct. It may be plugged. When it's running, go outside and feel if there is any air leaving the exhaust port where it exits the house.
Aug 16, 2014 | Electrolux Dryers
Shutting off won't start when hot
The windings in the motor are bad and the motor will need to be replaced. Here is the motor to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 17, 2012 | LG Home Applaince LG DLE0442W 7.3 Cu. Ft....
Electrolux Washer dryer EWW 1273 banging
I think a sensor is being faulty when you load and go to use the unit. Also might want someone to check out the timer on the unit just in case it is going out on you.
Aug 08, 2012 | Washing Machines
Spin cycle out of control off balance loud noise
time for new washer?the spider gear is broke.usually from using to much detergent.it eats at the metal until the spider gear breaks,you should only be using 1/4 cup of h.e. detergent any more than that will damage the spider gear,you'll know if it's bad,it will bang loudly in the spin.the part costs 4 to 5 hundred dollars not counting labor
Feb 22, 2011 | Whirlpool LHW0050PQ Front Load Washer
The cooling light is always on, and it takes about 90 minutes to dry a load.
In normal operation as the dryer is drying the "drying" light flashes and the "cooling" light is on steady until the 5 minute cooldown at which time the "drying" light stays on steady and the "cooling" light flashes. click on this lg link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6253
Nov 18, 2009 | LG DLE7177 Dryer
My dryer just started making a slight banging noise when it runs
Does it bang all the time or just ar start up?
All the time ... maybe you left a sneaker inside :-)
At start up ... normal noise. The belt has to do some fancy curlie cue stuff at the bottom and it takes a while for it to get stretched back to normal just like you do when you are abruptly awakened (when someone presses your START button) :-)
Let me know if this helps
a
Sep 21, 2009 | Dryers
Dryer making loud and louder noise after about 5 minutes of use
my dryer started making a very loud banging noise when I turned it on. It heats up and the drum turns, but I am afraid to use it.
Apr 22, 2008 | Kenmore Dryers
Dryers Logo
35 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
