Question about Reebok Exercise & Fitness
Reebok 8700es treadmill will show display but belt will not move
Display will show minutes and speed but belt will not move
  • Reebok Master
  • 6,694 Answers
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts.
Posted on Dec 24, 2016
Reebok ZR8 display is completely blank. Belt working fine, speed and incline keys still responsive - just can't see speed, distance etc
Hi Adrian, All a treadmill is... is a motor, running belt and console display pad. You'll find the console display pad has malfunctioned.... This can happen when something heavy is placed on it OR something hits it and if yours is under warranty then get it fix as soon as possible mate, I had a problem with my console display pad and it cost me $100 just for the pad....... My treadmill is a different brand but I can tell you the motor and running belt will last and last and last.....I hope this helps.........CHEERS..
Apr 27, 2016 | Reebok Exercise & Fitness
I believe that my Reebok 8700es was plugged in during a power surge. I bought a dedicated extension cord and plugged it back into the wall and turned it on. Nothing happened. There were no sounds a
Step 1:
1) Please NEVER use extension cord, this will bring dangerous spikes, glitches, that will affect to your treadmills.
Disconnect it and use the specific outlet wall, for your machine
2) I recommend that you use the Software calibration for easy diagnose, troubleshooting and fix it. This will be clear the information code appearing the display.
Go ahead
Step 2:
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Step 3:
Jan 07, 2013 | Reebok 8700 ES Treadmill - Silver Service...
Reebok 8700es treadmill w/ Universal iPod dock & Ifit Fitness Journal. Display screen is unreadable. Light is on but unable to read the numbers on the screen Treadmill features: Custom workouts,...
If the display is unreadable, the Display resolution is faulty
Time to replace since thee are LCD, this fail.
Call to the supply treadmill manufacturer. or
Treadmill Treadmills Best Treadmill Treadmill Doctor
Nov 08, 2017 | Reebok 8700 ES Treadmill - Silver Service...
How do you shut this thing off . the lights on the display stay on. reebok 8700es
Hols the stop button and the speed decrease button down while inserting or attatching the key (magnet). There should be a "d" on the screen, press the incline down button and it should go away. As soon as it disappears, your done. Just pull the key off and your display will shut off.
Hope this helps
Nov 06, 2010 | Reebok 8700 ES Treadmill - Silver Service...
How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
Mar 07, 2010 | Reebok Exercise & Fitness
The Walking Belt keeps staying close to the right side
speed the belt up to around 4mph while adjusting the belt. you will see it centre very quickly. once centered leave it to run for a couple of minutes to see if it stays central.
Apr 16, 2009 | Reebok New York Giants Eli Manning Jersey
Exercise & Fitness Logo
49 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
