Question about Westinghouse Dryers
I bought a 3 way fan switch by westinghouse has 3 wires black, blue, red. there are four wires from old switch black, red, white, yellow. where do blue white and yellow connect to
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
docjohn174
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
  • 235 Answers
SOURCE: Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
Posted on Jun 30, 2009
SOURCE: changing the 3 speed switch on my westinghouse ceiling fan
De-coding the nonsense..........
Ceiling Fan 3-speed Switch By Westinghouse 77021
Black = L = Power
Brown = 1 = Low Speed
Purple = 2 = Medium Speed
Gray = 3 = High Speed
Posted on Aug 18, 2009
  • 351 Answers
SOURCE: Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
Posted on May 25, 2010
Testimonial: "I appreciate the response, which reinforced my thought process and it worked - Thanks!"
I have a westinghuse fan with light it has four wires on it green, blue, black, and red what are they ie live neutral etc
Question posted under 3-speed switch
1) Are you replacing the 3-speed switch?
This is a field with much discussion because Westinghouse 4-wire fan switches vary.
Process of elimination is needed to find hot line. From there you test each wire to the hot line wire to determine which wire or combination of wires makes up low, medium, and high speed.
Open following links for some resources:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php
http://www.atlantalightbulbs.com/ecart/catalog/westinghouse-6.html
2) Or are you looking at fan connection wiring at ceiling?
Green wire goes to bare ground.
Fan should have hot and neutral.
Hot line should be black.
Neutral should be white.
Red usually goes to light
Blue is normally not there.
Where is the white neutral wire?
Take multimeter set to read ohms and test black wire to each other wire.
Process of elimination should reveal correct wiring.
Aug 21, 2011 | Speed Ceiling Fan 3-speed Switch By...
How to wire a Westinghouse 77052, which has black, red and blue wires. CIrcuit in ceiling fan has two yellow, pink off 4 uF (350K 1/2 w), Gray off 5 uF (330K) 1/2 w. Connected as follows: Pink to red;...
Copy following link for wiring 3-speed fan switches
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 30, 2011 | Westinghouse Electric Ceiling Fan 3-way...
Westinghouse Electric Westinghouse Lighting 3speed Ceiling Fan Switch 7707500 how do I connect wires I have black,white,blue and yellow wires I think black goes in L but at speed 3 not as fast as...
May 30, 2011 | Westinghouse Electric Westinghouse...
I forgot to write down the color connections. my options are L 1 2 3 my wire colors are, blacr, purple, yellow, blue. which goes where?
One line on the fan goes to the house common and should be white. this one is separate from the new switch. The other 3 lines on the fan are the 3 speeds. "L" is for the hot line coming into the fan and should be BLACK or RED. It should also be in the same box connector as the white above.
1,2 and 3 are the 3 fan speeds and tie to the 3 leads on the fan.
Try 1=purple 2= blue 3=yellow
You may need to move them after testing but darkest to lightest is usually the 1,2,3 order. Please let me know how much this has helped. Thank you!
Roger
Apr 02, 2011 | Westinghouse Electric Westinghouse...
I have a Hampton Bay ceiling fan. I bought Westinghouse 77021 to replace the fan switch. I have black, white, yellow and blue wires inside the fan's case. Where should I connect these wires? Jane
Hello. Yhe most common combination for this wire combination is: L - White, 1- Black, 2 - Blue, 3 - Yellow . However this is assuming your 77021 (the fan) has three speeds and the pullchain has four wires. Here's a link to some very good troubleshooting advice: http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php
and a link to Diagrams: http://www.hurontel.on.ca/~taitg/pages/cfan.html
Hope this helps, and don't forget to rate our help. Thank you.
Mar 07, 2011 | Speed Ceiling Fan 3-speed Switch By...
I have a three wire switch blue+black+red for the light on my ceiling fan need to know how to hook it up to turn the light on and off have four lights used to be five but took one out cause the fixture was...
Make sure the power is off.
Connect ALL White wires together -- from the ceiling box, the fan and the lights.
Connect the Black wire from the switch to the Black wire in the ceiling box.
Connect the Red wire to the Black wire on the Fan. That should activate on the first pull
Connect the Blue wire to the 4 black wires coming from the lights. That should activate on the second pull.
The third pull should activate both. To change the order, swap the connections to the Red and Blue wires.
Jan 19, 2018 | Westinghouse Electric Ceiling Fan 3-way...
please respond .
Please Vote !!
May 24, 2010 | Westinghouse Electric Westinghouse...
I am having trouble installing the wiring with my westinghouse. I don't know how to match up the wires. The Westinghouse has black, white, blue, and green wires, and my house wiring is purple, yellow and...
At the fan green is ground, blue is to turn on the fan, black turns on the light. I believe at your house wiring white is neutral and goes to the white in the fan. The purple and yellow are to switch on the fixtures, you can connect the purple to the blue, and the yellow to the black.
Oct 27, 2009 | Westinghouse Contempra Trio 42" Ceiling...
Changing the 3 speed switch on my westinghouse ceiling fan
If you are careful and take the hot coming into the fan from the power source and connect it to the colored wires one at a time, you will be able to find which one is high, med. and low. Then connect them. Hot in is L, 1 is low, 2 is med, 3 is high
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 18, 2009 | Speed Ceiling Fan 3-speed Switch By...
Wiring the replacement 3 speed switch (fan motor)
I called King of Fans and the rep that I spoke with gave me the correct wiring for the 3 speed switch:
L White
1 Yellow
2 Blue
3 Black
The problem is that after I wired it this way I am getting the same result (off on 3 settings and a motor hum on 1 setting). So, either the Westinghouse switch that I bought at Home Depot is not compatible or it is the capacitor. The saga continues.
Feb 18, 2009 | Hampton Bay 44 In. White Carousel II with...
Dryers Logo
29 people viewed this question
Top Westinghouse Dryers Experts
Naveen Sistla
Naveen Sistla
Level 1 Expert
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
