Question about Motorola Cell Phones
Where is the SIM card on my Motorola BZ60 cell phone and how do I remove it
aerolle
  • 36 Answers
SOURCE: unlock codes
here are set of code that you can apply and play with. You should have included the model of your cellphone but i'm hoping that this would help.
Code to lock keys. Press together *7
Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
Enable EFR:
[] [] [] 1 1 9 [] 1 []
Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec.
You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps:
enter menu and press 048263* quickly, then you will enter the secret engineering menu
under "Opcode"
input 10*0*3 for GSM 900
10*0*4 for GSM 1800
10*0*5 for GSM 1900
10*0*6 for dual band GSM 900/1800
10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested)
Posted on Jan 04, 2008
SOURCE: Inserting SIM card in Motorola V3C
Ahh! but there is a slot. Remove the battery and slide in the skinny sim card where you don't think there is space.....voila!
Posted on Feb 09, 2008
prmshl
  • 6 Answers
SOURCE: transfer contacts from a sim card onto cell phone
Go to contact list and select the contact.press option button then press copy option then press copy to phone.
Posted on May 16, 2009
  • 13 Answers
SOURCE: How do I remove the Sim card from a Motorola Razr
hello
these are the steps to remove a sim card from motorola RAZR
step 1. Turn off your cellular phone by pressing and holding the power key for two seconds.
Step 2. Remove the battery on the back of the phone by sliding it back and lifting gently.
Step 3. Identify the SIM card, which is under the battery area. A retention strap holds it in place. Don't stretch the retention strap. Slide the SIM card slowly back, up and out of the slot.
Step 4. You may now use the SIM card in another phone, or insert a new SIM card into the Motorola RAZR
Posted on Mar 15, 2010
Ranglo
  • 1194 Answers
SOURCE: how do you remove sim card from a samsung knack?
This phone is CDMA, so it does not have any sim card slot as it has inbuilt system which is directly operated by the service provider.
No other service provider is compatible with this phone.
Good luck
Posted on Jun 17, 2010
Testimonial: "Thanks, now I can just forget this problem."
How to install SIM card in XT907 Motorola phone
You will need to get the removal Sim card Tool
It looks like this
Once you have that tool you will be able to remove the Sim Card tray and place the Sim card on your phone.
Hope it helps.
Marge
Motorola Mobility.
Aug 05, 2014 | Motorola Cell Phones
Unlock generic sim for BZ60
In this case, I recommend you to contact the original service provider for further assistance.
Best Regards
Suny
Motorola Support.
Mar 15, 2014 | Motorola Mobility BZ60 V3xx V6 Maxx
Cell phone contacts
Step 1Remove the SIM card from your Motorola phone. The SIM card is a small chip that is located under the battery in your cell phone. After you've removed the SIM card from your Motorola phone, remove the SIM card from your LG phone.
Step 2Insert the SIM card from your LG phone into your Motorola phone. Turn on the Motorola phone.
Step 3Press the "Menu" key and select the "Address Book" option.
Step 4Select "Options" by pressing the right soft key. The "Select Multiple to" option will appear on the screen. Choose the "Select Multiple To" option and then select "Copy to SIM to Phone."
Step 5Remove the SIM card that you placed in your Motorola phone and insert it in your LG phone. After inserting the SIM card, turn on your LG phone.
Step 6Click the "Menu" key on your LG phone and select the "Address Book" option.
Step 7Select "Options" and choose the "SIM Management" option.
Step 8Select the "Copy from SIM" option and choose "Select All."
Step 9Select the "Copy" option. Your contacts will be transferred from your SIM card to your LG phone.
Feb 24, 2012 | LG Cell Phones
Motorola bz60 subsidy password
You can get the code from service provider and Unlock it...
Jul 21, 2011 | Motorola Mobility SLVR L7 Cellular Phone
Does the motorola razor bz60 have a sim card?
I do not believe so. To check for certain, take the back off of the phone, in the back by the battery (sometimes under the battery) you will find a card slot with a small card that can be pulled out and changed. Most media phones do not utilize the changeable SIM card like smart phones.
Mar 01, 2011 | Cell Phones
My motorola bz60 wont start up when I put it on the charger
Remove the battery and insert it back into the phone, then you power it on before charging it. If that does not help, then you run a check on the battery, the charger and the phone. Try then out in other devices to see the faulty component. once you detect the faulty component, then you replace it with a new one.
Hope this information helped!
Jan 10, 2011 | Motorola Mobility BZ60 - Cellular phone...
How do I remove the Sim card from a Motorola Razr V3M cell phone?
it is very easy to remove.just use your finger to open the back cover of the phone, remove the battery close to where the battery terminal is, and slide out the Sim card out.
But if you can not remove the Sim card with you finger, just get s screw on something you can use to pull the back cover and the battery out, then you can get access to your Sim card.
Good luck to you.
Mar 15, 2010 | Motorola Mobility RAZR V3m Cellular Phone
How to unlcok a motorola BZ60
Enter a non accepted sim card (oine that is not from the network the phone is locked to. You will be prompted to enter that code. If you are not prompted..simply leave the phone on for about 1/2 hrs to 3hrs and you will be granted the option to enter that code.
Aug 04, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Unlock a motorola bz60
You can get the unlock code here http://www.mobileunlocksolutions.com...-phone/rs1wp2/ and also get the unlock instruction in the same site....
Mar 27, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Cell Phones Logo
35 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
