Question about Technics Audio Players & Recorders
Doorwant open on technics cd changers-mc7 - Technics Audio Players & Recorders
4 Suggested Answers
  • 112 Answers
SOURCE: technics 5 cd changer sl-pd787
Does it show the disc length or any other details? Have you carefully cleaned the lense with a q-tip and some alcohol? Can you hear the laser moving in and out of focus? If you push the laser sled out away from the centre does it move back to the middle when youi put a disc in?
Posted on Feb 29, 2008
keemo68
  • 1263 Answers
SOURCE: I have a Technics SL-MC7
the quickest way to do this if your comfortable with opening electyron componants is to take the top of the unit off. there will be a cover over the disk carousel that has to be removed as well you will be able to remove the disks from there and then replace everything back in the same order. becareful not to wear clothing that will hold a static charge, a discharge on the circuit boards will fry them. also do not touch the optic glass of the laser this will damage it. please rate the solution...thanks
Posted on Sep 21, 2008
donnydo77
SOURCE: technic sl-mc7 110-disc cd changer
The problem is likely the carriage drive belt. The player is well over 10 years old so the belt gets stretched with use. Then it is unable to transfer power for moving mechanisms.
If you feel comfortable about opening the cover using proper electrical safety procedures then you can observe what the carriage is doing upon turn on. Unplug the player, remove the cover by unscrewing four fasteners (I think, but you can easily figure it out), plug in and power up. The carriage should go through a positioning calibration and disk checking sequence (simply, it moves out of the home position, travels across the player and repositions itself to await front panel input).
Yours probably doesn't so look at the belt on the top of the carriage. If it is off the drive wheels, remove electrical power, then simply put it back on, power up, and recheck.
If the belt is spinning on the wheels and seems loose then it needs replaced. Fortunately, here is an inexpensive and attainable replacement courtesy of another FixYa poster
http://www.fixya.com/support/t1616894-looking_drive_belt
Also, a clean up and lube of the mechanisms would be a good thing to do. That takes some technical know how to clean without damaging and applying the correct lube in the right amounts to the appropriate mechanism components. Some general references are available in electronic service books or online. I should probably launch a site!
Otherwise, without knowing the conditon of other components in the drive assemply, a service manual is required to proceed with further troubleshooting specifically for the player.
Hope that the K.I.S.S. approach helps you enjoy your player again.
Posted on Aug 06, 2009
I have a Technics SL -MC7 CD changer with a broken drive belt. Any idea where I can get a replacement part?
mostly they are a rubber band and assortment kits for cd units are from places like JAYCAR electronics
May 07, 2017 | Technics Audio Players & Recorders
Stuck in "checking discs" mode
Obviously your device is not working and you should seek professonal assistance..
Jun 08, 2015 | Technics SL-MC7 110-Disc CD Changer
The cd changer buttons do not work
Could be a broken drive belt. Sounds like the same symptoms that mine exhibited. You will need to open it up carefully, so you don't dislodge any CDs. See previous posts here for the exact size o-ring that you can find at your local hardware store as a replacement.
Aug 03, 2014 | Technics SL-MC7 110-Disc CD Changer
Technics SL-MC-7 Multi Disk CD Player- When I put a CD in it says
What does it stay? I am (Hooch) Please get a different CD (PLayer) I have (Retired)
Nov 09, 2012 | Technics SL-MC7 110-Disc CD Changer
My Technics SL-MC7 was zapped by a power surge. I am looking for a power supply. The part number on the PS is CMKS-P3X but when I search it I get hits for a copier PS that does not look like the one I...
You will need a service manual to get the correct part number. Go online to Technics, contact customer support and technical department to see if they can provide one.
Apr 07, 2012 | Technics SL-MC7 110-Disc CD Changer
This unit has no remote or manual...was wondering if it has a random mode, and how it works? Thanks, Sean
Copy and paste this link in your internet address bar in a new tab and it will bring you to your manual.
http://the-manuals.com/technics-sl-p-770-manual/
Mar 29, 2010 | Technics SL-MC7 110-Disc CD Changer
Looking for a drive belt for a SL MC300 Technics 110 CD changer
A rubber "O" Ring as a belt solved the problem.  At our local hardware store:  1 1/16 OD x 15/16 ID - 1/16" wall  $0.39!
Jan 29, 2009 | Technics SL-MC7 110-Disc CD Changer
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
