Question about Singer Sewing Machines
How to thread the bobbin of a singer 90s
Singer 90s Special edition
  • Singer Master
  • 12,533 Answers
Perhaps the manual will be helpful:
Singer 90S SPECIAL EDITION Manual
Posted on Dec 24, 2016
  • Singer Master
  • 5,481 Answers
First make sure that the needle is fully up (use the hand-wheel). Move the bobbin cover release button to the right and lift the bobbin cover out of the way. Remove the current bobbin, if needed. Hold the new, full bobbin so that the thread comes off the bobbin counter-clockwise when you pull the thread. Place the bobbin into the bobbin case. Pull the thread through the slot near the bottom of the case and to the left. Place a finger on top of the bobbin. Next bring the thread left further towards the back of the bobbin case until it stops in the second slot (near the 8 o'clock position if you compare the position to a 12-hour analog clock). Pull the thread back through the groove in the cover plate until it is cut by the thread cutter at the top left of the cover plate. (The thread will turn a "corner" to the cutter.) Replace the bobbin cover.
Singer has the manual for most of their sewing machines here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 90S is http://www.singerco.com/uploads/download/26e7243ab52aaed42904377fea7b090541eb0c9b.pdf . See pages 16-17 (page 18 in the PDF for the English description) and pictures that may be better than the verbal description.
I hope this helps.
SOURCE: Bobbin won't p/u thread Singer 478
i have no idea how to thread this machine ?
Posted on Aug 16, 2008
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
Maggie_B
  • 3 Answers
SOURCE: how to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Posted on Oct 31, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
How to wind bobbin on model 4411
Do you mean the Singer 4411 Heavy Duty sewing machine? If so,
first place the spool on the spool pin with an appropriate sized spool holder, if you are starting the project. Snap the thread into the thread guide to the left of the of the spool pin. Wrap the thread clockwise around the bobbin winder tension discs (slightly to the left and forward of the thread guide). Bring thread towards the bobbin spindle. Thread the bobbin (put the thread through the hole in the bobbin). Place the bobbin on the spindle with the hole up. Move the bobbin spindle to the right. Hold onto the thread above the bobbin and step on the foot control pedal. When the bobbin finishes winding the thread, cut the thread at the top of the bobbin and the incoming thread from the spool. Move the bobbin spindle to the left and remove the bobbin. If you have already threaded the machine for sewing, you will need to remove it from the various guides and tension discs that are used in sewing. Then after winding the bobbin, re-thread the top thread.
The directions to wind the bobbin are in the manual on page 12 (page 19 of the PDF). You can find many Singer manuals at the Singer support page: https://www.singer.com/support . The 4411 support page is https://www.singer.com/search/support?lp=support&title=4411 . The current link to the manual is https://www.singer.com/sites/default/files/product_manual/SINGER%204411%20Heavy%20Duty%20Sewing%20Machine.pdf .
I hope this helps.
Apr 30, 2018 | Sewing Machines
Singer 90S is plugged in, light is on but display screen is blank & machine won't sew. Now what?
Could be a computer component has failed. Repair expense could be more than the price of a new machine...
Apr 16, 2017 | Singer Sewing Machines
HELP PLEASE!!!! Need to figure out how to fix a Singer's Sewing Machine's drop in bobbin casing for my Singer 90s Special Edition???
Sounds like bird nesting or thread nesting (a user error), where there are thread "barfs" under the fabric. This is caused by the top thread not being seated in the tension disk. Remove the thread from the machine. ALWAYS RAISE the presser foot when threading the upper thread!!! Rethread from the beginning. Verify the thread path is correct. Set the upper tension at the midway point between high & low numbers--you'll probably need to tweak it for your particular machine.
Remember, when experiencing problems, install a brand new needle. Remove the thread from the machine, RAISE the presser foot, and rethread from the beginning.
It also helps to always pull the bobbin thread to the top of the fabric, gently hold both thread tails in your left hand, and then slowly take the first couple of stitches.
Understanding Thread Tension Threads
Mar 10, 2017 | Singer Sewing Machines
I have an old singer machine made in Canada. Model # J0855850. What is the year and value. Is there a manual available?
Fixya does not do appraisals. For a manual, try Googling (Singer)(J0855850)(manual) without parens.
Jul 07, 2016 | Singer Sewing Machines
Bobbins for a singer special edition cir. aprox 1960s
Your local Singer dealer should be able to help with this one. There are several good generic bobbins available and i suspect it will need to be metal rather than plastic. Also check the depth of any bobbins so that they fit in the case or the fixed case without being lose or too high. Lower than the bobbin case can work.
Mar 24, 2014 | Singer Sewing Machines
How do i thread the bobbin on a singer electronic anniversary edition
wind bobbin, drop into position ensuring that when thread is pulled bobbin rotates counter clockwise, pull thread towards you into slot, pull it to left under tension spring, then follow thread groove in bed to thread lock back left corner. close cover and start to sew ifr you need Singer 160 instruction email
Feb 04, 2014 | Sewing Machines
Sewing Machines Logo
115 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
