How many feet are in.54 acres, planning on fencing my yard in wit PVC pipe. 7 foot walls in most of it
  • 2,290 Answers
>.54 acres is just over a half acre.
My lot is 104 ft long and 104 wide and my deed says I purchased a half acre lot so you can go from there.
Hope this works for you.
Posted on Dec 24, 2016
  • Dan Apthorp Dec 24, 2016
    >54 acres is just over a half acre I own a half acre and it is 104 feet wide by 104 feet long.
Acres in square or radius area would be better
difficult to know exactly what you are asking here
what is 16000 bbls--abbreviations do not known around the world so you need to be specific
next you are asking for a radius but include a height measurement.
an acre is a surface measurement but as soon as you give a 3rd dimension ( your height) it becomes a volume measurement or cubic ft/ yards or gallons
so post it all again and explain the end result that you want people to answer
Dec 21, 2016 | Garden
I need to know how much stone in tons I need to fill 8.5 acre at 1.5 ft depth
Stone is approximated at about 2700 lbs. per cu. yd.
An acre is 43560 sq. ft.
8.5 acres is 370260 sq. ft.
There 9 sq.ft. per sq. yd., thus there are 41140 sq. yds. in 8.5 acres.
A cubic yard is 3 feet by 3 feet by 3 feet (LxWxH).
Since you are only going to be at 1.5 feet, each square yard is equal to 1/2 cubic yard, so to figure the cubic yards divide sq.yds. by 2, thus you get 20570 cu. yds. of stone.
20570 x 2700 = 55539000 pounds. Divide by 2000 to get tons:
55539000/2000 = 27769.5 tons.
Nov 16, 2016 | Office Equipment & Supplies
How many cubic yards would it take to fill in. 20' x 2' diameter
Hi Paula:
A mathematical logic question.
You need to get all of the measurements in the same units.
- A cubic yard is 1 yard x 1 yard x 1 yard
- equals 3 ft x 3 ft x 3 ft
- equals 27 cubic feet,
so once you have the volume of the pipe in cubic feet, you divide by 27 to get the volume in cubic yards.
- Volume of a cylinder (the pipe) is the cross sectional area X length.
- Area equals Pi x r squared.
- equals 22/7 x 1 x 1
equals 3.14#####
times length (20)
equals 62.857### cubic feet volume
divide by 27 cubic feet
equals 2.328### cubic yards.
- The answer is always the easy part.
- what is important is knowing exactly what the question is, and
- determing what calculations are needed to get the answer.
Wasn't that better than if I'd just said 2 1/3 cubic yards?
Jan 05, 2016 | Office Equipment & Supplies
What is the radius of a 3/4 acre circle (in feet)
Oh wow, lots of math going on here...
There are 4840 square yards in an acre and 9 square feet in a square yard (4840 x 9 = 43,560).
An acre is an old timers measurement used in agriculture...
it was 4 poles wide and 40 poles long. A pole is equivalent to sixteen and a half feet. So back then, an acre was a piece of farming land 660 feet long (220 yards or one eighth of a mile) and 66 feet wide (22 yards or one eightieth of a mile).
Acre is a measure of area, which would be square feet.
Feet are a measure of distance.
The best you could do is something like this:
An acre is 43, 560 square feet.
Draw/imagine a square or a rectangle that would cover that much area.
If it is a square, it would be (approximately) 208.7 feet on each side.
Its perimeter (the distance around it if you walk an imaginary fence around you acre-sized plot) would be 834.8 feet.
Trying to to figure out an acre of 'Circle' - hmmmmm???
Radius = 1/2 of Diameter
sorry, just can't wrap my head around this to come up with the correct equation.
maybe we can get lucky with some other brainiac taking what I did provide and come up with a solution for you?
Square - It would be 208.7 feet across if you walk across it, and the same if you walk the other way across it.
Apr 11, 2015 | PetSafe Wireless Fence System For Dogs &...
How many linear feet is a fense 25x25x25ft? The cost of the fense about $15.00 per linear foot.
I am assuming you are talking about fencing in 3 sides of an area with each side being 25 feet long. Linear feet refers to only the running length of the fence. It doesn't care about height. For example, you fence will be 75 linear feet long...three sides each 25 feet. The price per linear foot already takes into account the fence height. For example, you say that the fence you want is about $15.00 per linear foot. For the sake of argument, say your fence is 4 feet high. If you were to change to a 3 foot high fence, the cost per linear foot would be less since there is less fencing material. If you wanted to up the height to 6 feet, the price would rise accordingly.
Mar 06, 2015 | Home Fencing
I have Parmak S.E.3 fence charger, it's send energy out into wire but not enough to shock cattle, the unit is around a 7 acre field with 2 lines, what could be the problem?
Grounding is very important for an electric fence, especially in dry soil. I normally drive 2 or 3 - 6 foot long ground rods 10 feet apart then join them all together and run that to the charger using double 14 gauge or 12 gauge copper wire. You can get the roda at Tractor Supply.
Aug 19, 2014 | Electrical Supplies
I have a fence that is 1100 linear ft how much sq ft is that
Normally, there is no conversion needed between linear feet and regular feet. Linear feet is just simply stating "1100 feet in a straight line". Etrix_new is exactly right, we would need to see if the fence would be laid in a straight line, or if there would be turns and different heights. Respond back if you can!
PVC Railings Gates and Vinyl Fencing
Jun 19, 2014 | Heating & Cooling
Under the burnt out green of this small yard's tufts of grass where water was once used to wash pots , pans, poes,ochre appaers. a rusted bucket , hole kicked into its bottom, lies on its side. fence , lo...
It sounds like a good summer project. That yard might take some work. The first thing you will want to do is clear out the wildlife (including neighbors) and rebuild the fence. I suggest digging a trench and have the fence go a foot or two into the ground to prevent the animals from coming back underground. After that, the bushes will need to pulled out and grass can be planted. I wish you luck!
Elisa Jed '
Mar 04, 2014 | Computers & Internet
How do you put this net together? i got it at a
  • Step 1
  • Attach two 8-foot PVC pipes to one of the 12-foot PVC pipes using two elbow fittings and PVC cement. The result will be a short U shape.
  • Step 2 Attach the remaining three 12-foot PVC pipes together using two elbow fittings and PVC cement. The result will be a tall U shape.
  • Step 3 Attach the two U-shaped assemblies together using two elbow fittings and PVC cement. The short U shape is the horizontal base; the tall U shape is the upright frame. The finished result will resemble a bookend
  • Step 4 Cut strips of poultry netting and stretch them across the frame, fastening them with nylon cable ties. You'll find poultry netting packaged in rolls that are 3 feet in width. Cut lengths of the netting to stretch horizontally across the frame, leaving them in the standard width. Start at the top and work down along the back of the tall frame, creating a netted pocket. Overlap the strips by about 8 inches.
  • Step 5 Position the net so that no houses, automobiles or high-traffic areas are behind it. Errant balls can be unpredictable and dangerous.
  • Step 6 Secure the net by placing one 50-lb bag of sand on top of each leg of the practice net's base.
  • Apr 07, 2009 | Golf Digest Practice Net
    35 people viewed this question
