Question about Diesel Case 1370,1470,1570 Tractor Piston & Sleeve
Case 1370 AgriKing won't move
Have added full hyd fluid, new filters and still no movement or powersteering. Is there an inlet screen?
2 Suggested Answers
SOURCE: case 1370 agri king runs wont move
have you checked all of the linkage and lines? filters? get pressure test on hydraulic system to see if pump is weak
Posted on Nov 01, 2009
Case 970 AgriKing tractor. Wont move forward or reverse, but PTO still works
cheek if the large snap ring that goes inside of the drum is not missing
Sep 29, 2016 | Garden
1952 Fordson major diesel hyd fluid gets into front tranny
Sounds as if the input shaft seal for the hydraulic pump that is driven off the transmission is bad and allowing the fluid to enter the transmission housing. When the fluid gets too full it aerates and causes the "root beer float" fluid.
Mar 05, 2015 | Cars & Trucks
7FGCU45BCS TOYATO FORK WHY ARE LIFT CYLINDERS SLOW PUT NEW HYD. PUMP AN CONTROL VALVE ON ALSO CHANGED FLUID AND FILTERS COULD THERE BE AIR IN SYSTEM?
air bleeds out with the piston movement so with the piston movement air is put in and then is evacuated as the piston come back down. an indication of air is a jerking motion of the rams as pressure is built up and the ram moves which lowers the pressure until it gets up again. I would be having the pressure relief valve on the pump checked for correct setting. I would also be having the hydraulic hoses checked as they have been known to fail internally and block of the oil flow.
Aug 12, 2014 | Cars & Trucks
No fluid from rear pump 410 john deere backhoe
1st ck hyd tank for fluid level and fluid quality 2nd remove and ck hyd filter for blockage (note some hyd filters have a water sensing block valve inside) 3 rd verify that fluid is reaching pump , pumps will make horrible noises with no fluid in them , if all are well replace pump , and ck that bypass valve is not stuck open and is set correctly (some are internal to pump )
a method i've been sucessful with is to temp power hyd system with remote from another working tractor/bobcat , this sometimes unsticks bypass valves , but unless your familiar with what fittings do what and such I don't recomend this action for novices
Mar 19, 2014 | John Deere Garden
1992 lexis car replaced thepowersteering pump now it won't turn at all
bleed power steering with engine off pour power steering fluid in the power steering reservoir until fluid stay at full mark on powersteering pump dip stick.wait few minutes then check powersteering fluid again if low add little more when fluid level stop dropping crank vechicle turn steering left to right with out a stop turn steering wheel all the way to the left to all way to right for minute until air bubbles leave the powersteering fluid. when steering wheel feel normal stop engine check check power steering fluid should be at full hot mark if fluid level dont drop air is out the system. dont overfill powersteering reservoir if so you will blow front seal.dont drive vechicle if steering dont feel normal have vechicle towed in garage.
Sep 15, 2012 | Cars & Trucks
2005 malibu ~ changed tranny fluid/filter now car won't move. what did I do wrong?
If the tranny was fine before then something went wrong. make sure theres enough fluid in it and that the correct amount was added, another thing is that the filter was installed correctly and is sucking up the fluid. good day.
Jun 19, 2011 | Chevrolet Malibu Cars & Trucks
Troubles shooting p0551 core
Powersteering fluid is full and no problems while turning the front wheels you may just need a new powersteering pressure sensor. If your low on fluid fill and check for any leaks, and if your steering is hard to turn you may need the pump.
Jan 18, 2011 | 2001 Ford Escape
Ford TRactor 1710 hydraulic problem
raise front loader....loosen hyd. line a little lower loader till all air is released and only fluid is coming out and retighten.....its like bleedig brakes on a car
Nov 16, 2009 | Plumbing
Case 1370 agri king runs wont move
Apr 11, 2009 | Diesel Case 1370,1470,1570 Tractor Piston...
94 jeep pick up can't get the hydralic clutch bleed
need to free flow, means to open bleed valve open and let it run down but adding fluid to till you dont see air bubbles.
use a clear pice a hose, hook it to bleeding valve and into a bottle with 1/4 full of fluid will take few tries.
Feb 15, 2009 | 1991 Jeep Wrangler
Diesel Case 1370,1470,1570 Tractor Piston & Sleeve Logo
166 people viewed this question
Top Diesel Garden Experts
Dennis Key
Dennis Key
john h
Wade Mobley
Wade Mobley
Are you a Diesel Garden Expert? Answer questions, earn points and help others
