Question about Daewoo Refrigerators
Audible alarm sounding on Daewoo DFS-645 fridge/freezer.
fridgetech
  • 473 Answers
SOURCE: Daewoo Fridge Freezer not getting cold
Possible problems are a bad evaporator fan motor or a defrost problem. If the back panel in the freezer is frosted up then it is a defrost problem. If no frost listen for the fan in the freezer. If you don't hear it then it may be the problem. Not circulating the cold air.
Posted on Oct 05, 2007
skrbin
  • 121 Answers
SOURCE: daewoo fr581 freezer not freezing
Behind fridge probably have a ventilator,check is it work,clean a gas cooler(radiator) from dust with a dry brush.If ventilator is not work change it.
Posted on Jul 04, 2009
projdoc
  • 2237 Answers
SOURCE: My Daewoo FRS2021IAL has a warm fridge
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 27, 2009
  • 4793 Answers
SOURCE: Fitting a Daewoo american fridge freezer - airspace?
about an inch at the sides and 3 inches at the back,plus top and bottom vents in the front of the sill and top vallance.
Posted on Jun 09, 2010
hvac1960
  • 2133 Answers
SOURCE: AMERICAN FRIDGE FREEZER ALARM SOUNDS ON FREEZER
Check freezer temp setting is correct. ( -14*F and 8*F).
If still problem, replace freezer thermostat.
Thanks.
Posted on Mar 09, 2011
Daewoo FRSU20DCB not making ice
Sounds like you have an airflow issue. Freezer temp. should be @10-15 below and fresh food area @35-37 above zero You may have an evaporator fan or door switch failure
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
This link can help you diagnose your problem.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Dec 23, 2017 | Daewoo Freezers
I just moved into a home with a kenmore chest freezer. This is a real dumb question, but which symbol means on. Should the circle be showing for "on" or should the line be showing for "on"?
Some freezer models feature a temperature
monitor that provides an audible
alarm. The temperature monitor alarm is
located near the temperature control
The alarm sounds if the temperature in
the freezer rises 10° F (12° C) or more
above normal for selected setting. Alarm
may sound if temperature control dial is
turned to a much colder setting or if a
large amount of unfrozen food is added at
one time. Alarm is controlled by a three
position switch
0 = OFF prevents alarm from sounding
when freezer is warm, such as during
initial start-up or defrosting.
• ✓ = TEST sounds alarm regardless of
temperature. Alarm system should be
tested at least once a month.
1 = ON is proper setting for normal
freezer use. Return switch to 1 after
defrosting.
Jul 07, 2009 | Kenmore Freezers
Why the red light blinking with audible alarm?
Your temperature alarm is going off as it has exceeded your set high temp.
Usually means you have had a power failure or you have a thermostat, starter relay, compressor or freon problem.
To find out what is happening get a therometer and put in fridge. A fridge / freezer thermometer is best but any will help
May 18, 2009 | Bosch Refrigerators
Red light on
The red light and the audible alarm both come on when the freezer gets warmer than the alarm point... unless you disable the audible alarm with the rocker switch
Nov 24, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Its keeps peeping
Hello twins49
Welcome to Fixya,
You said, your Frigidaire freezer 17 cu. ft. , it keeps buzzing or peeping
The alarm may be malfunctioning or it may be warning you of low temperature.
You can go to any hard ware store and buy a refrigerator thermometer and ask them if it can go into a freezer too!It can, But ask anyway!
If it is cold enough then it is a faulty alarm going off.
Your freezer may be equipped with an alarm.
Here is some information that may help you find it and turn it off if you wish
Temp Alarm (audible only or audible with warning light)
This feature is designed to provide a warning of possible malfunction. If the
temperature of the food rises to a level unsafe for long-term storage, the buzzer will
sound. The red light will also glow on models so equipped. The Temp Alarm feature
operates on household electricity. If power fails, the alarm will not perform. An ON/
OFF switch allows you to deactivate the Temp Alarm when not wanted. The freezer
is shipped with Temp Alarm in the OFF position. After freezer has run approximately
4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm
without the alarm sounding.
Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch.
If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and
seals properly. If you suspect a technical malfunction, call an authorized servicer
immediately.
Let me no what you find.
Huuum
Please remember to leave a rating before you leave
Aug 26, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Pioneer DEH-P4000 DFS Alarm driving me crazy
How to disarm DFS alarm How to disarm DFS alarm Disarming alarm Upon entering your vehicle and within the ENTRY DELAY TIME set within the DFS alarm Menu, attach your Pioneer Detachable face. If you have forgotten the Detachable Face Panel: If the STARTER DISABLE is ON, insert the ignition key in the ignition within the ENTRY DELAY TIME, then turn the key from OFF to ON 5 times within 1 minute. If the starter disable is OFF, insert the ignition key in the ignition and turn the key from OFF to ON within the ENTRY DELAY TIME. CAUTION: If the starter motor will not run, the cause may be the DFS alarm. To check whether the DFS alarm is cause, try switching the position of the switch installed according to the AVOIDING TROUBLE section of the installation manual. If the DFS alarm is the cause of the trouble, then the starter motor will run. In case, confirm DFS alarm operation in safe place. If there is no problem, switch back to its original position. If left at the newly switched position, some functions of the DFS alarm will not operate. If the starter motor will not run after switching the switch, something other than the DFS alarm may be causing the problem. Have the vehicle checked at a nearby dealer. ----------------------------------------------- Select the DFS alarm feature ON/OFF mode (alarm ) in the initial setting menu. Press the arrow (up) button to switch the DFS alarm feature ON. Press the arrow (down) button to deactivate the DFS alarm feature. Press FUNCTION button for 2 seconds to enter the DFS alarm setting menu These are a couple of things I found to fix this problem. Here is the link that I got them from: http://www.pioneerelectronics.com/pna/v3/pg/support/knowledgebase/0,,2076_310069579,00.html Hope this helps:) Jason
Sep 04, 2007 | Car Audio & Video
Refrigerators Logo
43 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
