Question about Homelite Garden
How ro repair the fuel lines on a homelite vac attack 2
4 Suggested Answers
  • 5 Answers
SOURCE: Need a user manual for Homelite Vac attack 2
I have a Homelite UT08107
Leaf Vac, I couldn't get it started so I took it completely apart and cleaned it all up and now I can't figure out how to put it back together. I'm looking for a shop or a servive manual
Posted on Sep 04, 2009
  • 885 Answers
SOURCE: I have a Homelite "Vac Attack" leaf blower model
The fuel line is replaceable by itself, you don't need a new tank. Just make sure you get the same size line or it will leak where it goes into the tank. Any local small engine repair shop should have the line. There are two lines that go into the tank, the pickup line has the filter on it. It not only filters the gas but keeps the end of the line down in the fuel.
Posted on Nov 02, 2010
roadtech7
  • 297 Answers
SOURCE: What is the fuel mixture
The mixture is 50 to 1.
Hope this helps
Posted on Nov 12, 2010
Nov 02, 2010 | Homelite Garden
My Homelite Vac Attack II is 4 years old and I
fit new pump ad float diaphragms in the carby
the fuel mix has become irrelevant as Stihl have an oil that is a 50:1 oil and covers all ratios and mixtures
do not use any e-mix fuels as that destroys carby components
Aug 09, 2017 | Homelite Leaf Vac Attack
My Homelite vac attack 2 won't start. It's out of
My Homwlitw Attack ii won't start. Spark plug is dry even after priming more than 10 times. Where so I start? Thanks, Fred
May 05, 2010 | Homelite Leaf Vac Attack
Wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
Jan 31, 2010 | Homelite Leaf Vac Attack
My Homelite backpack leaf blower runs until tank is 1/2 full
thats what it is try opening the gas lid look inside to see where the fuel line lies if its up high them try pushing it down to the bottom
Nov 13, 2009 | Homelite Consumer Products Backpack...
I have the homelite Vac Attack 2, i'm having trouble starting it, i prime it the desired 7 times (actually more) but i just sit there and pull, and pull, and pull the cord....really getting frustrated!
#1 senerio
Fouled spark plug
ie, carbon and or fuel fouled
install new plug, and withouth choking or priming, pull 4-6 times while holding the throttle at wide open.
If not fouled, go to senerio #2
#2 senerio
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 09, 2009 | Homelite Leaf Vac Attack
Does this blower use 2 cycle mix; I have a homelite vac attack II 200mph blower and it is having trouble starting
Yes it will use a fuel mixture of 40:1(3.2 oz of two cycle oil to 1 gallon of gas). Any fuel sitting over 30 days now is considered bad fuel. All the manufacturers schools this year and told us this. We are finding it to be true.
Good day.
Oct 12, 2009 | Homelite Leaf Vac Attack
Garden Logo
238 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
