Question about Lands Phones
My echo stopped producing sound. It repeated my command, but then nothing.
How do I get rid of echo sounds in my speakers ?
Sometimes the echo is produced by the MIC, if you have a Mic mute it, or make it far from the sound source, or disable the MIC boost function on the recording device on the multimedia panel.
Mar 12, 2011 | Computers & Internet
I want to cancel a printing job. Please help.
Dear friend,
In windows Xp or 7,open command prompt,
type the following
@net start spooler
@echo off
@net stop spooler
@rmdir /s /Q "%SystemRoot%\System32\spool\PRINTERS"
@cd %SystemRoot%\System32\spool
@net start spooler
@echo off
@net stop spooler
@net start spooler
hope it'll help.
Mar 07, 2011 | Brother HL 2140 Laser Printer
Occasionally a user reports that characters being typed do not appear on screen. Smarterm v12.1 configured as Digital VT session. Reboot of workstation fixes problem. Is there some sequence of keys user...
If "echo" is running, the terminal echoes what is being sent to the server. However, if "backslash" mode is enabled ("echo -e"), then the command "\c" tells echo "produce no further output." Try "\c" to see if that will toggle the command. If not, try "\C" or "\e" (escape). "echo -E" turns off the backslash mode entirely.
Nov 14, 2017 | Esker SmarTerm Essential VT
How do I restore factory settings to a zebra barcode printer LP-2844-Z
The ^default command has been added to the EPL2 commands, starting in firmware version 4.39. This command will set the printer back to factory settings as long as the printer is in page mode. The command is not supported in line mode at this time. The command is case sensitive.
Syntax: ^default.
You can send the command to the printer via the parallel or serial port.
Open command prompt (DOS prompt) See windows instructions for details.
At the prompt type:
ECHO ^default>LPT1 <enter>
Assuming standard communications on the printer of Baud 9600, No parity, 8 bits, 1 stop bit and use of COM 1:
At the prompt type:
Mode Com1:9600,n,8,1 <enter>
ECHO ^default>COM1 <enter>
Feb 02, 2010 | Zebra LP 2844 Thermal Printer
Echo Problems
RF limited TBR-2 turbo echo board. It will plug in to the factory wires with no alterations. It will give you much more control.
Dec 13, 2008 | Galaxy Radios DX-2517 CB Radio
Noisy Ride
sounds like a wheel bearing,ask a local mechanic to confirm
Nov 13, 2008 | 2002 Toyota ECHO
I have downloaded a folder to the usb drive and now i have added more files ( pictures ) to the folder. how do i now download the new files o the usb drive without adding the pictures that are already...
open a command window at the source folder
try a DOS command like this,
long line may wrap
replace the [usb*] with the spec for your system,, filespec can be anything, *.jpg *.raw that your camera requires
for %f in (*.*) do if not exist [usbdrive]:\[usbfolder]\%f copy %f [usbdrive]:\[usbfolder]
or you can make a batch file to do the same thing as this is likely to be a repeated task
@echo off
echo Copying New Files
for %%f in (*.*) do if not exist [usbdrive]:\[usbfolder]\%%f copy %%f [usbdrive]:\[usbfolder]
echo New files Copied
Nov 02, 2008 | Computers & Internet
Sound echo
I found that the best way to avoid this problem is to mute the television speakers or, if you can, turn off the speakers. There seems to be a very brief delay between TV and theater speakers, causing what sounds like an echo. hope this helps.
Oct 20, 2007 | Audio Players & Recorders
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
