I have a Empire wall furnace Model # DV-235-2-SG 3500 BTU'S the electrical igniter will click but the pilot won't go on.
  • 946 Answers
Clean the hole of the pilot light and clean the metal where the spark comes from and goes to. Could be bad igniter though.Mine here iffy, so I just light it with a long match while holding down the button in pilot mode. don-ohio (:^)
Posted on Dec 24, 2016
Empire DV-235-1 Heater
There is a thermostat which is creating the problem
Sep 08, 2008 | Empire DV-35 Heater
Replaced thermocouple pilot stays on but burner wont light
Make sure the gas valve dial is turn to the "on" position. Otherwise, I would need more info to answer this question fully.
Nov 17, 2015 | Empire Comfort Systems DV-215-SG...
Empire wall furnace pushing down the pilot button trying to light the pilot found too much gas flowing
Is the button on the gas valve or a red button in the line to the pilot assembly? If its in the line, there is a regulator upstream of the button. If the gas is coming from the gas valve, there is a small screw covered hole in line with the pilot line in the gas valve. If neither of these apply, you may need to replace the orifice in the pilot assembly. Let me know how it goes.
Nov 19, 2013 | Empire Comfort Systems Direct-Vent Wall...
Blower don't work
did you check for proper voltage at motor itself??? if none work your way back from motor till find voltage and what component is not allowing voltage to pass
Nov 12, 2013 | Empire Direct Vent Wall Furnace Millivolt...
I believe all the Empire manuals are there to download or read at their website:
Nov 08, 2011 | Empire Direct Vent Wall Furnace;...
My empire wall furnace does not ignite. It has gas flowing because the pilot is light, i have changed the thermostat and wired it two different ways in case I reversed them. What is next? Could it be the...
It could be several things: Is the Control Knob turned from Pilot to ON? If that is the case, wait a few minutes after turning it to ON. That will allow the Thermopile to heat up sufficiently. Be sure the flame is touching the Thermopile. If everything looks correct turn up your Thermostat to higher than the ambient room temperature and see if the burners light. Remember to turn your Wall Thermostat down to the lowest temperature setting before turning the knob from Pilot to ON.
FYI - That Wall Furnace does not have a Thermocouple. It uses a Thermopile instead to generate millivolts of electricity to open the gas valve and maintain the pilot flame.
If it is the Thermopile, you can order it directly from Empire Comfort Systems, as well as download your Owners Manual at
Feb 04, 2011 | Empire GWT-50 Wall Mounted Panel Heater
Have an empire wall furnace. Natural gas. Vent through the wall. My problem is that sometimes when it ignites, it makes a loud boom and I can see a flame flash at the top of the heat exchanger. I was...
Not sure what the problem is, but mine does the same thing.It also blows the pilot light out when it does it..Had several service calls, no luck...POS, don't buy another Empire heater....
Nov 09, 2010 | Empire Hight Efficient Direct Vent Wall...
Empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Nov 29, 2009 | Empire Direct Vent Wall Furnace Millivolt...
How to change the orfis from propane to gas on a empire 40,000btu
what is the model # for the furnace. You are going to have to change the pilot orofice and gas valve for natural gas also.
Oct 30, 2009 | Empire Hight Efficient Direct Vent Wall...
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
