Question about Hisense Televison & Video
I have a Hisense 48H5. When I push the power button on the remote, the red light flashes and the "Hisense" name comes up on the screen. Within about 10 seconds, the tv shuts off and starts again.
It only gets to the "Hisense" screen and repeats. To get it to stop, I have to unplug it. The power button on the remote does not shut it off.
    Top Expert:
  • Hisense Master
  • 75,417 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Posted on Dec 24, 2016
Hisense 40k360 - TV
Look for a button on the TV labeled V or video and cycle it through until you get AIR or something similar. It could be a setup button also. You will have to play with it a bit to learn the controls and menu - I once had a TV that took 8 specific button pushes in sequence to run normally.
Mar 13, 2018 | Hisense Televison & Video
My Hisense smart flat screen 50H5G won't turn on. I push the power button and it goes to stand by. I push the button again and the red light blinks 10 times and it shuts off.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 22, 2016 | Hisense Televison & Video
My hisense pulse stopped working. Now on power up the screen flashes hisense and then blue screen with no signal. red led flashes at first and then nothing.
Sounds like corrupted firmware. A firmware update might be necessary. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 04, 2015 | Hisense Televison & Video
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
Hi, We have a 42" hslc10668phz
generally when you get a constant green light all is ok. these different lights indicate different problems within the tv. so the pattern of lights you mention suggests there is a fault of some kind (is there a troubleshooting section in your manual)? either way it needs to be looked at.
Nov 28, 2010 | Hisense Televison & Video
I am looking for remotes codes to program my universal comcast remote. I have a Hisense remote HYDFSR-A205EA
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
Nov 09, 2010 | Hisense Televison & Video
KDF-60XS955 Powers off and on every minute
The lamp light will not come on especially if it lights up during bootup from a cold start. The lamp only lights up on Sony when the lamp shatters in its housing and the system can't ignite the lamp from a cold startup, Sometimes it does'nt light up then. So if it lights when u first cut it on the sysem thinks its ok... But lets verify if the lamp is the problem.
With the tv off using your original remote, Press Display button-----channel 5 button----and Volume up button then Power button within 5 secs of pushing the first button, Screen should come on with a diagnostic screen, Look at the lamp driver option and see if its recorded any numbers to the right of it, if so then this is telling you that the lamp has stopped or tried to ignite that number of times..
Push the number 8 key then enter to reset the numbers back to zero.Turn off power now turn on the television and wait until it happens again, at this point go back to diagnostic as explained eariler and see what it has recorded. If it has recorded a 1 on the lamp driver then replace your lamp. Reminder: Once you have replaced the lamp go to diagnostic screen again and reset the numbers back to zero.
Hope this helps...Thank you
Delhielectronics@live.com
Sep 04, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Hisense tl2020 will not power on
power supply issue..may be some bad capacitors simply replace them....dada....your prob solved
happy to help
Aug 18, 2017 | Hisense TL1700 17 in. LCD Television
Hisense remote does not work with hisense tv
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Apr 29, 2008 | Televison & Video
Televison & Video Logo
257 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
