Question about Cobra Video Cameras
How do i download my picture to my sd memory card so i can get them printed at a photo store
  • 205 Answers
SOURCE: Memory card
When you use an SD card in mulitple cameras, each camera creates it's own folder beneath the DCIM folder. I'm not sure if you have a program that automatically opens when you insert the SD card in your reader, but perhaps you can try double clicking on "My Computer" and locating your reader/SD card and opening that folder manually. Once you're there, open the DCIM folder and see if there are multiple folders inside. Open each one to see if you can locate your pictures.
If you have a program that opens automatically when you insert the SD card you'll need to figure out how to tell it to look in other folders.
Posted on Dec 28, 2007
SOURCE: sd card not reconsized by pc
omg same thing keeps happening i have a vista and i try to download the photo's on my vista but it won't work
Posted on Oct 11, 2008
SOURCE: internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
Posted on Dec 24, 2008
SOURCE: transferring stored data from micro SD card on G1 to new one
plug your G1 to your PC via a USB cable that came with it .., once you plug it in you'll get a notification entitled USB connected .. select it and then choose mount ... once thats done open your My computer icon , you'll see an exrta drive that wasn't there be4 somethig like K or M .. open that and you'll see all the content of your SD card .. copy and past everything to a folder anywhere in your computer ... then all you gotta do is replace the SD card , repeat the same proccess but then time copy everything back to your new SD card .
Posted on Feb 02, 2009
SOURCE: Lg lp500 cookie mobile wont store automaticaly into memory card
Hi, with the Cookie you have to set your camera and video settings to external memory seperately, even though you have already made external memory your primary storage....its weird! I don't have the phone with me right now to check but open up the camera by clicking the button and while the icons are on the screen tap the one that looks like a cog, this takes you to the settings page for the camera, under one of the tabs here you will see two memory type options. Tap the 'external memory' option and away you go! You need to do the same with the video settings.
Posted on Feb 11, 2009
I put pictures on my sd card useing my camera but when i try to upload them to my computer it says that there are no new pictures to upload
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Jan 26, 2013 | Casio Exilim EX-Z30 Digital Camera
Memory card locked
SD and Micro SD memory cards SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts. ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Oct 19, 2012 | Nikon D3000 Digital Camera
My memory card for D3000 is locked but i checked the card, it seems like the lock is not there how do i sort this out?
Oct 19, 2012 | Nikon D300 Digital Camera
How to remove pictures from camera and sd card
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jul 01, 2012 | Vivitar ViviCam 3710 Digital Camera
How to tranfer picture from camera to flash drive
Connect the camera to the computer with the supplied USB cable. the computer will see the camera as an external storage device. You can then copy the photo from the camera to the computer's hard disk and or your flash memory stick.
If you camera has the photos stored on a SD memory card you can remove the SD card and insert it into an USB memory card reader. Then connect the card reader into the USB port of your computer to download the photos from the SD card to the computer's hard disk and or your flash memory stick.
Aug 21, 2011 | Computers & Internet
I accidently deleted a picture. How to recover it back. It is a Canon IXUS 870 IS camera. It uses a SD card.
You can connect camera's memory card to computer, then download this picture recovery program which is outstanding among all picture recovery software.
http://www.001-software.com/picture-recovery/
Aug 30, 2010 | Canon PowerShot SD880 IS / Digital IXUS...
How do I recover pictures from the camera's memory if there are no pictures on the memory card?
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this digital camera recover program called asoftech photo recovery from
http://download.cnet.com/Asoftech-Photo-Recovery/3000-12511_4-10913438.html?part=dl-10913438&subj=dl&tag=button
Install and open the photo recovery software, select the memory card, and click 'Start' button.
Jun 18, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
I accidentally formatted my sd card and lost pictures also the ones that were locked how can i recover all of them
dont worry, pictures lost after reformatted sd card can be recovered with sd card photo recovery software, you can download the picture recovery software from
http://www.asoftech.com/apr/
May 10, 2010 | Kingston 2GB Secure Digital Memory Card
Accidently Reformatted SD card and need important pictures back
you can recover photos from reformatted sd card with a professional photo recovery program, here's how you can do it
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended asoftech photo recovery (simply because i was using it and it worked), download the program from
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Asoftech-Photo-Recovery.shtml
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your lost photos.
Jan 21, 2009 | SanDisk 2GB microSD Memory Card
Sd card
when you camera is connected, go to my computer and you should find it listed under other devices, you should then be able to explore the camera folders in which sould be your sd card folder, copy and paste them.
Sep 06, 2007 | Konica Minolta DiMAGE G530 Digital Camera
Video Cameras Logo
24 people viewed this question
Top Cobra Video Cameras Experts
Tony Parsons
Tony Parsons
Are you a Cobra Video Camera Expert? Answer questions, earn points and help others
