Question about Hoover Vacuums
Panasonic Hoover cleaner motor cuts out and fuse blows
    Top Expert:
  • Hoover Master
  • 12,962 Answers
Using too much current. check to make sure that the motor is spinning at the correct speed. If there is grease caked on bearings it might be spinning slow, overheating, using too much juice and shutting down.
If motor speed is up to par and condition persists you may have some burnt/shorted windings responsible for the issue - the motor has to be replaced.
Posted on Dec 23, 2016
How to open Hoover S3825
Hi there! We recommend taking your cleaner in to a Hoover authorized service center to have the motor replaced or repaired. I have included a link to the service center locator if needed. Hope this helps!
Service Center Locator
Oct 05, 2014 | Hoover Elite Cyclonic Canister Vacuum with...
How to fix panasonic mc e450
The thermal fuse for the motor is inside the motor on some models or screwed to the motor case on others
Aug 08, 2014 | Hoover Vacuums
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
My Henry Hoover cut out and will not work. Emptied bag and replaced fuse but no success.
If no burning or smelling, maybe nothing to do with motor, and if caused by the safety cut-out, it will need about an hour to cool down, and then check filter, bag, and drop coin through hose, pipes and the floor tool, to check for blockages and to stop it running hot. Damaged cable, worn carbon brushes, broken electrical rewind electrical contacts or even the printed circuit board (later models) are the most likely causes.
Jul 08, 2011 | Hoover Vacuums
Hoover just cut out while we were vacuuming the floor, no power, is there an internal fuse somewhere?
No. there is a thermal fuse that will reset after the motor cools down. Check for blockage and clean filters and clean the cone assembly for proper air flow.
Sep 28, 2009 | Hoover WindTunnel Cyclonic HEPA Bagless...
Fuse auto shut off
Find the current rating for the vacuum cleaner motor (on a plate somewhere on the machine). Is it somewhat less than the breaker rating in the panel? If so, then either the motor is overloading the breaker due to bad bearings or a shorted winding in the motor or the breaker is failing. Check the current draw of the running motor with a clamp-on ammeter (a friend with one or an electrician). It should be close to the rating on the plate. If in excess, then the motor needs to be repaired or replaced. The motor normally works harder when it is pulling full vacuum--it speeds up if the air flow is plugged.
Sep 08, 2009 | Hoover S5620 Vacuum
Henry hoover cuts out
A 5amp fuse will struggle on start up on anything over 1000watts. Check the rating plate on the appliance for total load
Aug 19, 2009 | Numatic Henry Bagged Canister Vacuum
Keeps cutting out, and blowing the fuse, not so if tools are being used though
The information you've given suggests a problem with the main brush drive motor. Unfortunately this motor is in a place where it can very easily get wet - hence fuses blowing. Repair is something you probably won't want to attempt yourself (lots of people take them apart and can't reassemble them!). If you do get it repaired, expect the same thing to happen again sooner or later. Alternatively, save money and hire a professional carpet cleaner now and then.
Aug 15, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Hoover EmPower 4600 keeps blowing circuit breaker. The number of outlets in the house that will allow me to run the vacuum is dropping quickly. It is a 4 year old house and all the circuit breakers are 20...
take it to a friends house and plug it in if it does the same thing then the problem is in the vacuum cleaner.check your cord and see if there are anny cuts in it.you can open the breaker box then plug in the vacuum and watch the breaker box.you might see a spark and narrow down the problem.
Mar 22, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
