Question about Majestic Heating & Cooling
I can't get the remote control to sync up on my Majestic Serenade Direct-Vent Fireplace
SOURCE: Remote Control Programming
sanyo uses code 10154 ,hold mute and select at the same time until the greenlight flashes twice then enter code and press power
Posted on Dec 27, 2007
SOURCE: Looking for owners manual for
Use model 36BDVR and search the net.
Posted on Dec 21, 2010
hvac1960
  • 2133 Answers
SOURCE: where can i get a
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
Posted on Dec 30, 2010
SOURCE: When we built our home
It has a panel hidden under the white fiber hearth bricks at the front bottom of the unit. you need to clean the lava rock off of them, pull both of them up, and then you will see the hidden linear cover that allows you to access the valve and light.
Posted on Jan 13, 2011
MrsK87
  • 43 Answers
SOURCE: looking for replacement parts for a Majestic Gas
This is incorrect. Gas log parts are NOT generic. Especially ofr a Majestic. They are model specific. www.ibuyfireplaceparts.com
Posted on Apr 20, 2011
I bought an Insta Flame model FSDV 30 direct vent wall furnace, need a natural gas conversion kit. It currently is set up for propane and could use some help in finding the parts and installing them.
There is a ban on that particular furnace as they can explode!
You won't find parts or anyone that will work on it.
[PDF]TSSA Bans Series of Insta-Flame and Northern Flame Fireplaces www.dunnheating.com/.../TSSA%20Bans%20Series%20of%20Insta_Flame%20and%...
  1. Cached
  2. Similar
Oct 23, 2012 - (TSSA) has banned a series of natural gas and propane-fired direct vent ... 'FSDV22' or 'FSDV30' or 'FSDV32' in the model name or number.
TSSA Bans Series of Insta-Flame and Northern Flame ... - CNW Group
www.newswire.ca/.../tssa-bans-series-of-insta-flame-and-northern-flame-fireplaces-51...
  1. Cached
  2. Similar
Oct 23, 2012 - All Insta-Flame and Northern Flame natural gas or propane-fired direct vent freestanding fireplaces with 'FSDV22' or 'FSDV30' or 'FSDV32' in ...
[PDF]Fuels Safety Program DIRECTOR'S ORDER - TSSA
https://www.tssa.org/corplibrary/ArticleFile.asp?Instance=136&ID...
  1. Cached
  2. Similar
Mar 25, 2016 - Natural Gas Fired Direct Vent Free Standing Fireplace - Model ... Insta-flame or Northern Flame: Models FSDV22, FSDV30, FSDV32, D222.
Majestic Fireplace - - Recalls & alerts - Healthy Canadians Website
www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2012/15058a-eng.php
  1. Cached
  2. Similar
Nov 9, 2012 - Natural gas and propane-fired direct vent free-standing fireplaces ... Insta-flame or Northern Flame (Models FSDV22, FSDV30 and FSDV32, ...
TSSA Safety Order Ban of Majestic FSDV22, FSDV30 and FSDV32
www.fireplacegroup.ca/tssa-safety-order-ban-of-majestic-fsdv22-fsdv30-and-fsdv32/
  1. Cached
  2. Similar
Dec 21, 2012 - TSSA Safety Order Ban of Majestic FSDV22, FSDV30 and FSDV32 ... CFM Inc. (Majestic Fireplace) and bear the trade names Insta-Flame or Northern Flame ... (a) Natural Gas Fired Direct Vent Free Standing Fireplace - Model FSDV22, FSDV30 ... -Stove shipped as natural gas; LP Conversion Kit included
http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2012/15058a-eng.php
Dec 11, 2016 | Kitchen Ranges
How to replace a pilot assembly on a fireplace
Monesson has all of these on their website. usually when someone believes they need to replace a pilot assembly the actual problem is a maintenance issue. Clear the air-holes at the base of the pilot tube with a vacuum cleaner.
Sep 04, 2014 | Monessen Wdv600ntsc Serenade Series 60inch...
Majestic DVR 36 RN gas fireplace pilot flickers when ignited, eventually gets to full pilot. Ocasionaly burner shuts off, pilot remains on. Also, need owners manual for part numbers. Help.
Does your fireplace have a thermostat connected? If so, that may be why the pilot stays on and the burner goes off. Otherwise, it could be a bad thermopile. If that is the case, I recommend you just replace the entire pilot assembly. It is an older model and manuals can be hard ti find. If you still have trouble, I recommend you contact a local certified gas appliance technician.
Jan 12, 2014 | Majestic Fireplaces Majestic Topaz 20ILDV...
Majestic gas fireplace
Either the vent pipe is clogged or maybe you need to have the restrictor plate checked to see if it is proper size for your system.
Jan 09, 2014 | Home
Pilot is on, why do gas logs not ignite?
Make sure the control knob was turned to on. If so check control switch,wall switch or remote setting.
Dec 29, 2012 | Empire Comfort Systems Empire Tahoe...
Fireplace remote control no longer works correctly
To re-sync your Honeywell 8220 transmitter to the valve: Turn the Local/Remote switch on your valve to Local. Then switch it back to Remote. Within 10 seconds of switching it to Remote, you need to press the Flame button on your transmitter. This will re-sync your transmitter to the receiver in the valve. Replacement transmitters and valves are no longer available for this system, they were discontinued by Honeywell and they are completely out of stock. Monessen Hearth Systems (now owns Majestic, Vermont, etc) has a retrofit kit with a new valve, pilot assy, and remote for these old RF units. (expensive, but cheaper than a new fireplace). FYI, aftermarket remotes are NOT compatible with this Honeywell system.
Nov 24, 2012 | Televison & Video
Cant start gas fireplace
  • Find the remote's receiver under the fireplace.
  • There should be a switch to change from "remote" to "ON".
  • Turn the switch to "ON", if the fireplace ignites, you may need to re synchronize your remote. If it does not, your remote control may be bad.
  • Bypass the remote to ensure your fireplace is operational by connecting the "TH" and "TP/TH" terminals on the valve with a wire or paperclip. If the fireplace lights up fine, then it is for sure a bad remote.
  • Universal gas fireplace remotes can be found HERE.
Oct 28, 2012 | Empire Comfort Systems Empire Tahoe...
Heating & Cooling Logo
Top Majestic Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
ray gallant
Joseph Coppeto
Joseph Coppeto
Are you a Majestic Heating and Cooling Expert? Answer questions, earn points and help others
