Question about Mitsubishi Televison & Video
Mitsubishi Model WS-55315 won't power up and green light blinks twice before going off.
    Top Expert:
  • Mitsubishi Master
  • 12,505 Answers
Check out power supply.
Posted on Dec 23, 2016
  • 139 Answers
SOURCE: mitsubishi ws-55315 won't turn on
YOU HAVE LOST H.DEFLECTION CIRCUIT
Posted on Dec 27, 2009
  • 11800 Answers
SOURCE: Lost power last night, now
Not very much - when the power was lost a power spike happened and this spike has fried some components from the power board: the blinking light signals that the protection system of the source has detected an overload on one of the outputs and has shut it down to protect it and the rest of the tv The only way to fix that is to open the tv and test the components. This is a job for someone who has done this before and has at least a basic understanding of electronics. If you're not such a person then it's time to call one, no way around that.
Posted on Nov 13, 2010
  • 1694 Answers
SOURCE: Mitsubishi WS-65513 65 in Perpetual Blinking Problem:
Replace four 1000mf/25v caps on DM module.....pix's at...
www.Chris@ChrisAndNat.com..................T.
Posted on Dec 01, 2007
800pctechs
  • 39 Answers
SOURCE: GREEN LIGHT BLINKING AND TELEVISON WILL NOT RESET ON MITSUBISHI WS-48613
Bad solder on the vertical ic401, or bad solder on the yoke.
Posted on Oct 02, 2008
SOURCE: HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Posted on Feb 25, 2009
When I push the on button the green light comes on for second or two then goes out.(will not stay turned on long enough to even get a picture on the screen.Mitsibishi Model # WS-55315
This set has a self check feature--if set has been unplugged it clears the error buffer--plug in and try to turn on set.
When green light comes on and then goes off ON THE FRONT OF THE SET press and hold BOTH the menu and input(device) buttons at same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat the code for a total of five times.
Let me know what error code you find and I will explain it.
May 27, 2012 | Mitsubishi Televison & Video
MITSUBISHI WS-55315 WON'T TURN ON WITH REMOTE OR START BUTTON
do the self check and find the error code if set shows power and then goes total dead shortly after.
May 02, 2012 | Mitsubishi WS-55513 55" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Set comes on then turns it self off
do the self check this model has:
when green light comes on (power) and then goes off:
On the front of the set press and hold both the menu and input (device) buttons at the same time for at least five seconds and then release both.
The power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and then repeat it several more times.
Let me know with a comment here and I will tell you what it means.
SD TECH
Nov 23, 2010 | Mitsubishi WS-55315 55" Rear Projection...
My mitsubishi 55" will not turn on... when I press
Hi:
The most common failure for this model is the deflection board assembly or commonly known as a Large Signal board. The unit is going into shutdown, mode because no high voltage. Unless you are strongly electronically inclined I suggest you try to replace the deflection board.
Nov 10, 2010 | Mitsubishi WS-55315 55" Rear Projection...
Hi my tv is the ws-55315 and i turn the tv on the light comes on for a second(the power light) and the tv shuts off is that the bulb i dont know?and how do i fix it
WHEN the power light goes off on front of set, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Power light will blink an error code: most common is 2 blinks, 2 blinks, a pause and it will repeat code several times.
This is self check and will narrow down what is wrong with your set.
Let me know what code you find and I will tell you what it means.
SD TECH
Nov 06, 2010 | Mitsubishi WS-55315 55" Rear Projection...
WS 55315 Tv won't turn on-
Thanks for your help can you send photos so I can see what to look for
Dec 01, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi Mod # WS-55315
On this model the timer led blinks when the tv is off if you have the timer set to turn it on. You can get the manual here.
Mar 13, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
