Question about Coffee Makers & Espresso Machines
The new grind and brew DGB-550 doesn't grind the beans fine enough and it produces a VERY WEAK coffee. The beans are all ground, they are very coarse.
  • Coffee Maker... Master
  • 20,350 Answers
Did you read the instructions to see if you can alter the grind?
If there is no setting, then you would need to either contact the company direct, or take it back for refund as 'not fit for purpose sold'..
Posted on Dec 23, 2016
Testimonial: "There is no way to alter the setting. Cuisinart does not answer the phone and they do not respond to emails."
  • 2 more comments
  • Andrew Taylor
    Andrew Taylor Dec 23, 2016
    I would suggest, packaging it back up and taking it back. They are probably closed over the holiday.
  • Andrew Taylor
    This lady loves it, but she probably got it free as a video blogger!
    https://www.youtube.com/watch?v=ztPvFvZb...
  • Andrew Taylor
    Please make sure the 1-4 setting button is pushed on. This setting does make a stronger cup of coffee due to the slower brewing process
  • Andrew Taylor
    I think there is an error in the instructions. It says to use 1 scoop of whole beans per cup. It also says use 1 scoop of medium ground coffee for one cup. This can't be right as whole beans have air spaces between them, so you need more whole beans to have the same volume of ground coffee. I would guess 1.5 to 2 times more. If you have electronic scales, measure the difference.
    https://www.cuisinart.com/share/pdf/manu...
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
Gaggia Titanium Weak coffee medium cup only produces a dash of water and weak coffee, also the ground is very course and I am going through lots of beans done the cleaning and re-calibration but still the...
The coarse grounds is definitely the problem. make sure your machines setting are near 5-8 depending on the beans you use.
You need to make 5 cups of coffee before you see the new grind size. Do not change the grind too often or you will not see what you are looking for.
If the coffee is still too coarse you may need to replace the grinder burrs. http://www.cerinicoffee.com/grinder-burrs-saeco-gaggia-asp.html
or you should take it to a service center.
http://www.cerinicoffee.com/espresso-parts/espresso-machine-service-center-new-york.html
Aug 11, 2013 | Gaggia Titanium Espresso Machine
Why does my DGB-300 grind coffee but doesn't brew?
having no idea where it get water from does not help us figure it out , would suggest checking with the manufacturer's website for technical support .but 15 years is a good long life . some burn out in only 3 or 4 yrs
Sep 17, 2017 | Cuisinart DGB-300 Coffee Maker
My Saeco Odea Go only produces weak coffee (like water). Tried adjusting the grinder and also different coffee beans. Any ideas?
have you tried adjust coffee strenght?
This is the bean symbol on the bottom of the front control
Jan 23, 2013 | Saeco Odea Go
Pucks in dregs drawer very wet
Hi
3 things can cause wet grounds.
1. You don't have enough coffee going into the brew unit. There is a lever on the right side behind the door at the top. Push it back towards the rear but not all the way. This will put more coffee in the brew unit and take up the air space so you will have less water.
2. Your grind is too coarse. Pull the lever below the bean hopper towards the front when it is grinding, to make the grinds smaller. Again less air space. Do this 1 number at a time so you dont make it too fine. Let each adjustment for 3 coffees before you make the next adjustment.
3. Your grinder has come apart and is grinding very coarse (French press). New grinder.
Dec 28, 2010 | Saeco Magic Comfort Plus Espresso Machine
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
DGB-550BK Filter basket won't stay shut when either brewing ground coffee or grinding beans.. With the ground; the basket pops open mid brew and makes a mess everywhere. When grinding beans, I've noticed...
Not a solution but...
Many folks have reported this, the latching mechanism wears out eventually.
We had the problem but discovered that the door on the basket wasn't getting completely closed. Now I make sure it's closed and haven't had any problem since.
Hope this solves your issue - if not, keep an eye on yard sales, we picked up two at different times for $5 and now have parts to swap out - not much help for a failed latch though.
Glad I never paid full price for it, even though it's a fairly good grinder/brewer.
Jan 19, 2010 | Cuisinart DGB-550BK
Saeco Italia coffee too weak - grindes too coarse
Remove beans from chamber, then remove the 2-3 screws in the chamber, then lift hopper slightly and turn adjustment knob towards the middle number, or halfway between fine and coarse. Then lower hopper make sure the gears line up together, set screws add beans and adjust finer.
Oct 08, 2009 | Starbucks Saeco Italia Digital Barista...
Grind is too coarse and "pucks" are wet and fall apart.
You say " I am getting a weak brew because of not being able to adust the grind to more coarse with the adjustment knob in the bean hopper" By making it more coarse you are making it weaker. Unless you just wrote it wrong. To make it stronger you should lower the grinder number to a smaller number. Usually about 4-6. Be sure you have the grinder grinding when you move it to a lower number. The pump noise could be that in shipping your pump came loose from it's mount. Nothing you can do without sending it to a Authorized Saeco Repair shop.
Jun 04, 2007 | Saeco Vienna Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
