Question about Air Purifiers
I just received my Dyson Air Purifier and the directions say to put the remote upside down on top of the unit...but it just keeps falling off....
SOURCE: Filter Queen Air Purifier
you can call 1.866.660.0612 Fm Air Inc a Filter Queen distributor will be happy to assist you.
Posted on Apr 17, 2008
SOURCE: Red Cleaning Light won't turn off
If the cleaning light stays red it is do to a failure of the nichrome wire sensor that detects deposit build up. This wire is locatied in the center where the grids are removed and easily broken. It runs from top to bottom twice. Look inside and if you see a loose wire that looks like a fine thread that is your problem. Not a do it yourself job.
Posted on Aug 29, 2008
JSEhandyman
  • 368 Answers
SOURCE: how to put together living air alpine bora III air purifier?
Hi Tlwynn,
The grid part of the screen should face the fan. The O3 produced by the cold-plasma discharge is what attacks the odors, and you want the fan to blow it out of the machine.
Make sure the spring-steel contacts are touching metal on both sides of the plate.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
Posted on Dec 28, 2008
  • 80 Answers
SOURCE: Install Plate Displayed
Call toll free 1-877-710-0057 and they will gladly help you.
Posted on Jun 06, 2009
co7196
  • 3433 Answers
SOURCE: I purchased a Hybrid GP germicidal Air Purifier,
Locate the photo electric eye that picks up the need to clean and give it a thorought cleaning. Good Luck and I hope you get it repaired. That photo cell should be your problem It's probably a little black or ruby red dot in a fin or on the housing where yhe air passes.
Posted on Jul 06, 2009
How do I put the top on after cleaning a oreck
To put the top back on you have to set in on top about 3/4 of the way before you try sliding it closed. Also check that if you disassembled it to clean the filters some of them will install upside down and then the top will not be able to close.
Aug 16, 2014 | Oreck XL Professional Air Purifier
How do I get to the wires inside the unit safely? I see several suggestions but not sure that I know how to get to these wires without damaging the unit.
For years I have tried to clean the wires.Mine sometimes sounds like a bug zapper! Anyway, the only solution I have come up with is this.--I take a Very thin cloth(such as an old worn out washcloth) dampen it and carefully holding on to one corner, insert it into open top of unit. I jigglel it up and down. It will help loosen some of the debris on the wires. Also, at times I purposely let it drop inside and shake the unit up and down, then turn it upside down to let it fall closer to the top to get it out.Do this several times, rinsing rag and wringing out well each time.I clean the slats with a thin rag wrapped over a butter knife.All of this is time consuming, but it pays to do it. Iv'e had mine 11 yrs. and they are still working.Just make sure all of the components are completely dry before reconnecting unit.
Aug 07, 2011 | Ionic Pro TURBO Air Purifier
Blueaire 501 dust caked up on wires and fan,how do you take it apart to clean it?
Hi, I have had the same problem and have figured out how to open it.
To open your blueair air purifier, follow the steps below;
1. Get a phillips head screwdriver,
2. Open the unit and remove the air filters.
3. Use the phillips head screwdriver to remove the screws that you can see.
4. After taking out the screws, remove the "galvanizedSwedish steel housing"
(cream coloured sides) of the purifier by lifting it upwards (i.e. from bottom to top of unit).
4. You will now have access to the interior of the purifier.
5. You can now take out the fan and clean it, or what ever part you are trying to clean. I used a Dyson HEPA vacuum cleaner.
6. To reassemble, reverse the instructions above to reassemble the purifier.
Feb 28, 2011 | Blueair 501 Air Purifier
Makes a hissing sound after I clean it
It may be a little late that I am answering your conundrum, but once you clean it, put the unit back together, tip it upside down until you hear a "click" and then turn it on. No hissing :)
Dec 24, 2010 | Sharper Image Ionic Breeze GP (SI730) Air...
Unit will sometimes make a crackling noise.
Mine does it too, I finally just tried something else when I was cleaning the blades. I took some alcohol on a qtip and with the blades out of the machine I wiped up and down the line wires that are inside that go from the top to the bottom, and also the little balls that are on the bottom of the wires that slide when you turn your unit upside down. It seems to work, I do it every time I clean the blades. scribner062
May 22, 2010 | Sharper Image Ionic Breeze Quadra Air...
I own an Ionic Breeze Quadra unit. It has been working fine and I really like it because it removes bad odors from the house. Mine has just started making a hissing noise. Any suggestions? Thanks
hi,
Sparking, popping, hissing or crackling sounds coming from your Ionic Breeze air cleaner are all signals that it's time to clean your machine. Once you've cleaned the collection grids inside the Quadra, the disruptive sounds will disappear
how to clean
Turn off and unplug your Ionic Breeze Quadra.Grasp the horizontal handle on top of the air cleaning grids--this is in the very center top of your Ionic Breeze Quadra--and pull the grids straight up out of the casingWipe the metal grids down, inside and out along the entire length, with a clean damp cloth. You may need to use more than one cloth if the grids are very dirty.Go back over the grids with a clean dry cloth to remove any water and remaining dirtPut the grids aside on a clean, dry surface and grasp the body of the main Ionic Breeze casing unit in both hands.Flip the casing unit upside down, then right side up, five or six times. You should hear a small bead sliding back and forth as you do this. The bead is cleaning interior elements concealed in the casing; if you don't hear it, your unit may be in need of repair.Place the casing unit back on its base, orient the grids so that the handle slopes in the same direction as the top of the air purifier, then carefully slide them back down into the machine.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Sharper Image Air Purifiers
Gp sharper image hissing problem
1. Unplug the unit
2. Turn the unit upside down and listen for the beeds to move along the static wires from top to bottom. Turn it upside down again and again until you feel the static wires are cleaned of grime.
3. Plug it in again and see if the hissing is gone.
Jun 06, 2009 | Sharper Image Hybrid GP (SI724) Air...
After cleaning the unit, replace the grid into the unit. Hold upside down for at least 30 seconds to reset.
Jul 19, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
My ionic breeze turbo makesa sizzle sound all the time...its even worse after i clean it. i use compressed air to clean it very well to
Turn the ionic breeze off, unplug it, and turn it upside down. The wires on the bottom of the unit collect dust. There are beads on the wires to scrape that dust off. Turn the unit upside down, and then right side up gently 7 or 8 times and the noise should go away. Yu may need to do this once or twice a week and after cleaning the blades.
May 10, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Living Air Purifier (Flair Model) Ecoquest
Pull the unit out of the box and flip it upside down. You should see it
Feb 16, 2008 | Ecoquest Flair Air Purifier
Air Purifiers Logo
114 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
