Question about The Watches
How do i set the date on t719129j kids watch - The Watches
How to set time and date on a batman kid digital watch
Is it a BAT 4045? It appears this is a watch with poor or no instructions and ineffective time/date settings, which might be your situation. I found this review on Amazon which might help you.
Solid w/ a configuration issue
Byartayd2on 8 July 2013 - Published on Amazon.com
Verified Purchase
I've seen a few reviews indicating that they could not set the clock or the instructions were not included. While I did get correct instructions, they were not written well and seemed to be the end result of someone translating into English.
I had issues setting the time/date w/ the S2 button initially because of the specific location where you are required to press. It is not sufficient to push the S2 button to begin setting the clock, you really need a pen tip to press it squarely or you will continue to press the button and no time setting options will appear. I originally tried to set the clock by pushing the S2 button with a small thin pair of scissors that were handy but it did nothing even though I was clearly pushing the button into the watch face. After changing to a pen tip it worked right away.
With the exception of the initial time setting frustrations the watch works well and the strap feels strong enough for regular use for my three year old son, and it is pretty cheap!
Nov 26, 2017 | Watches
How to set new date of month on watch
How to change date on a watch?
Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. * If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock. 5. Adjust the time by turning the crown in the desired direction.
Instructions for Analogue Quartz and Mechanical Watches - Seiko
https://www.seikowatches.com/support/ib/pdf/Analogue_E.pdf Search for: How to change date on a watch?
How to set new date of month on watch Google Search
Dec 21, 2016 | Watches
How can i set the time for a disney accutime watch LR626
Amazon.com: Customer Questions & Answers
www.amazon.com/ask/questions/asin/B00MA9D2XG
Amazon.com, Inc.Disney Kids' FZN3630 Frozen Anna and Elsa Watch With Graphic Band. by Disney ... Question: i have no directions for setting the time either in or on the pkg.Missing: accutime ‎lr626
Disney Kids' FZN3630 Frozen Anna and Elsa Watch With ...
www.amazon.com > Watches > Girls > Wrist Watches
Amazon.com, Inc.
Rating: 4.2 - ‎68 reviews
The digital time makes it easy for kid's to read. It light's up when you push it. The Frozen theme is adorable. This watch does not look cheap at all. It will adjust to ...
Dec 27, 2015 | Disney Watches
How to advance date 4 or 5 days on a Timex T40021
This watch should have a "quick set" date function that lets you advance the dates by turning the setting crown. To get the watch in this mode, pull the set stem out half-way. At that point, turning the setting crown will advance the date on the watch without turning the hands. One some watches, finding the right position for the set stem can be a bit tricky--either it's not out far enough or it's out just a bit too far and the time hands turn. You may have to try pulling the stem in and out a few times to get it just right.
A word of advice: watches are generally designed to advance the date, not to turn it back. It's suggested that if you need turn the date back, you actually advance the date wheel up to 30 days to get to the date you want. Some watches do permit you to turn dates backwards, but I prefer not to risk the chance of hanging up the little springs and mechanism that are designed to advance the date indicator.
One final note: I have serviced several Timex mid-size (ladies or kids size) Expedition watches that lack a quick-set date. Many Timex watches in that size do have a quickset date like I've just described to you, so I have no idea whether these watches happen to have a cheaper movement or if they have some internal damage (it's been the same model each time). At any rate, for those watches, I have had to use the incredibly slow and painful process of advancing the time 24 hours to advance the date. With those watches, if the date is too far advanced by a day or two, it may be easier to stop the watch for 24-48 hours until the date is correct, rather than spend a huge amount of time spinning the crown to advance the time. Hopefully, your watch will have the more sophisticated movement, though.
May 28, 2011 | Timex Expedition® Metal Field 47042...
How do you set the time on an Armitron 165 wrist-watch?
Hi wtgillo,
Hi there I see that you are in need of assistance setting time on your Armitron Wrist watch.
I would be more than glad to give you details on how to, Please see steps below.
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push D/Alarm Button to set the minutes
  • After setting the minutes on your watch, Press date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Have a nice day,
mvincentc
Apr 21, 2011 | Armitron Watches
Do you have directions for armitron mens pro sport watch 49/1000
Hi robinmsavage,
I will be glad to help you with your concern regarding your Armitron Wristwatch, what exactly would you be experiencing? cause I only put info on how to set time and date on the Watch.
Please see below steps:
See Steps below:
*Setting the time*
  • Press and Hold down the Date Button till the Minutes flash, then push Alarm Button to set the minutes
  • After setting the minutes on your watch, Press Date till you get the month flashing push Alarm to set the month
Thank you for choosing Fixya,
mvincentc
Apr 21, 2011 | Armitron Chronograph Sport #204345BKBK...
How do i set a timex kids digital watch?
Thank you for contacting Fixya.
  • Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
  • Press the "Date Advance" button on the upper right side. This will reset the seconds.
  • Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
  • Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
  • Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
  • When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
  • Hope this helps. Best regards.
    Aug 25, 2010 | Timex Kids Digital 73962 Wrist Watch
    How to set time on my Casio Lw-200 Kids watch Its a digital watch
    Thank you for contacting FixYA.<br /> <div style="BORDER-BOTTOM: medium none; TEXT-ALIGN: left; BORDER-LEFT: medium none; BACKGROUND-COLOR: transparent; COLOR: #000000; OVERFLOW: hidden; BORDER-TOP: medium none; BORDER-RIGHT: medium none; TEXT-DECORATION: none"> <li id="jsArticleStep1" itxtvisited="1"> Examine your watch. Attempt to find its "Mode" button; nearly every digital watch has one. The various modes might include "Date," "Alarm" and "Stopwatch" among others. Repeatedly press "Mode" to cycle through the modes available on your watch until you have it in the mode that displays the current time.<br /></li></div> <li id="jsArticleStep2" itxtvisited="1"> 2 Locate the button that allows you to adjust the settings on your watch; this button could be labeled "Set" or "Adjust." Once you've found this button, press it in and hold it. After a few moments, the time display should begin to flash.<br /></li> <li id="jsArticleStep3" itxtvisited="1"> 3 Select either minutes or hours as the aspect of the time you'd like to adjust. Press the "Mode" key to cycle through your options; each element should begin to flash as it's selected.<br /></li> <li id="jsArticleStep4" itxtvisited="1"> 4 Press a button to adjust the time element you've selected; the button for doing this will vary from watch to watch. If there are up and down arrows on your watch, use them to increase or decrease the number. A button labeled as another function could serve this purpose too; trying pressing the various buttons on your watch to discover the correct one to adjust the time.<br /></li> <li id="jsArticleStep5" itxtvisited="1"> 5 Move on to the next element you want to adjust, such as minutes or the date, by pressing the "Mode" display.<br /></li> <li id="jsArticleStep6" itxtvisited="1"> 6 Press the "Set" button to finalize the new time on your watch. You'll know that the time has been set when the numbers stop flashing.<br /></li> <br /> For more Casio info go to:<br /> http://www.casio.com/support/<br />Best regards.
    Aug 24, 2010 | Casio LW200-1AV Wrist Watch
    Setting date on my swiss 200M women's watch
    mcdevito75 here, If your watch has a stem (winder) it is most likely 2 position, Pull out stem to first position, this should allow you to change the date, set the date at 1 number before the actuall date you want, NOW pull the stem out to set the time, rotate the hands until you have the date and time for the actuall date.
    Jun 29, 2010 | Swiss Army Wenger Sportedge Bracelet Watch
    0512037FA Wrist Watch: how do you set the date in the window of a seiko 6...
    mcdevito75 here, The stem should have 2 positions to set the DATE without haveing to cycle the watch 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it's first position, it may take practice so be patient, once in it"s first position you can easily change the DATE, change it to 1 DATE before the DATE you want. NOW! push the stem back in and then pull it out to set the proper DATE and time of day, your watch is set and will change on time, around Mid Nite.
    May 18, 2010 | Seiko 0512037FA Wrist Watch
    Watches Logo
    22 people viewed this question
    Top The Watches Experts
    D. E. Hev
    John mullen
    vince
    Are you a The Watch Expert? Answer questions, earn points and help others
