Question about Lakewood Heating & Cooling
Power light out on Lakewood Model QTV-22; is it still safe to use?
3 Suggested Answers
SOURCE: Cycles on and off after reaching desired temperature
The problem sounds like the thermostat which is probably a bimetal strip. It sounds like the bimetal strip is just constantly bending one direction then the other. It could be possibly adjusted by bending it -- this would be a trial and error process.
Or, it could be replaced.
Posted on Apr 29, 2009
  • 49191 Answers
SOURCE: I have a Lakewood QTV-22 750/1500 Watt heater and one of the tubes doesn't heat up when I turned it on. Is it safe to use?
yes
as the elements are in parallel
have an appliance shop replace the faulty element
Posted on Oct 29, 2017
Replacement wheel for Lakewood Heater Model 7101
I did the drill think once. but today when trying to repair an old Lakewood 7101, I removed the two screws holding the front cover in place (top and bottom). the cover slides down and out. and underneath I see a large plug that can be unscrewed to drain or fill the heater!
Sep 02, 2012 | Lakewood Heating & Cooling
Lakewood heater model 6500 the top high low knob melted and started smoking. i immeadiately removed it andsaw the melted plastic.the unit seemsto still work fine. is it safe to use?
you can still use this heater, but continue to monitor its operation. If it gets hot enough to start smoking again, discontinue use and purchase a new one. Your safety means EVERYTHING!!!!!!
Nov 27, 2010 | Lakewood Oil-Filled Electric Radiator...
Model 707 Lakewood portable heater stopped working
I don't know how to make your heater work again, but I do know (from long experience with Lakewood 707s) that the setting knobs often fail to function properly even if the heating element still works. My solution is to plug the heater into an adapter with an on/off switch on it and use that to control the power. I leave the setting knobs on the heater itself in the position where I usually use them (max heat). These are excellent heaters except for the knob problem.
Apr 06, 2010 | Lakewood LAK707 Utility Heater
No lights on switch on--no heat--on LAKEWOOD mODEL 7000/A
Look for a thing called a Thermal Fuse, small, pencil sized cylindrical, silver, (usually) with stiff lead at each end. It should be in the Phase/Active line. Try replacing that.
Feb 12, 2010 | Lakewood Oil-Filled Electric Radiator...
Disposal of lakewood oil filled electric radiator (portable)
take back to lowes or wallmart call a enviromental recycling company
Jul 03, 2009 | Lakewood Oil-Filled Electric Radiator...
Apr 29, 2009 | Lakewood LAKQTV22 Utility Heater
Model 7096 heater
http://www.ul.com/media/newsrel/nr041405.html
Concerning Lakewood Model #7096
RECALL
May cause electric shock!
Nov 20, 2007 | Lakewood Oil-Filled Electric Radiator...
Power switches
what do the switches look like? can you supply a picture?
Nov 10, 2006 | Lakewood 7101 Oil Filled Radiator Heater
Heating & Cooling Logo
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
