I have 55 in led there is an oily spots all over rear of tv I keep wiping off and they reappear after use what could this be
  • Brett Duxbury
    Brett Duxbury Dec 24, 2016
    Hi Ernie burl, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    wondering if electrolytic capacitors are leaking inside tv ?
How do I manage overpowering tv background noise
I think a surrond sound system helps. I have the same problem, i can't hear dialogue either. I can't afford surround sound system so i have to keep turning volume up & down accordingly.
Jul 31, 2014 | LG 55LV5500 55 Class 1080P 120Hz LED TV...
How can I fix it if the back breaks have seized?
remove adjustment cover on rear brakes. attempt adj to loosen brakes. if seized in open position (no brakes) try removing hub from axle....if seized closed (applied) spray a lil wd 40 in brake adj hole in rear of backing plate on brakes hardware only try not to get on shoes. wipe excess from shoes as soon as possible spray w/carb cieaner wipe till no oily spots on brakes. you will find costly repairs inside either way if corrosion has gotten so bad to pit alluminum maybe replace atv b cheaper.
Jun 01, 2014 | Yamaha 2005 Raptor 80
Tartan Pattern on screen of 55 inch samsung led tv
Suspect main board that processes all signal in and to the screen.
If not tried do see if same problem when rear inputs for audio/video are used.
May 25, 2012 | Samsung Televison & Video
I have a philips rear projection tv and it has a black spot almost like tint that is slowly covering the screen. perfect line from top to bottom and it keeps getting bigger.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as
Feb 16, 2011 | Philips 55PW9363 55" Rear Projection...
TV keeps losing power
cuz ur tv sucks, time for plasma
Sep 29, 2009 | Hitachi 55FX48B 55" Rear Projection...
TV shutdown itself. LED on/off indicator is blinking.
That happened to me before. I was watching TV and all the sudden it would just turn off on me. The power switch had gone bad and I had to have a new one put in.
Jul 16, 2009 | Toshiba TP55F80/81 55" Rear Projection...
if the timer led keeps blinking (more than 2 minutes) the DM module needs to be fix:
if doesn't respond after been blinking, bottoms on the front panel leaky
Nov 01, 2008 | Mitsubishi WS-55809 55" Rear Projection...
The best ways to move my 55 inch Mitsubishi TV to another home?
Move it with an appliance hand truck and do not lay it on it's side. When transporting, always keep unit standing upright. Good Luck
Aug 14, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
