Tools & Hardware - Others Logo
Derek Cahill Posted on Dec 23, 2016
My workzone stapler will not effect staples - Staples Tools & Hardware - Others
Battery is fully charged. Light turns on but it won't shoot staples
If your battery is fully charged but your stapler is not shooting staples, there are a few potential causes for this problem:
  • The stapler's mechanism may be jammed or stuck. Check the stapler's mechanism and clear any jams or debris that may be preventing it from functioning properly.
  • The stapler's spring may be damaged or weakened. If the spring is not providing enough force to push the staples through, the stapler may not be able to shoot staples effectively.
  • The stapler's nosepiece may be damaged or misaligned. Check the nosepiece and make sure it is not bent or out of position, as this can prevent the stapler from shooting staples correctly.
  • The stapler's battery or other internal components may be faulty. If the problem persists, you may need to have the stapler serviced by a qualified technician.
If you are unsure how to check for and address these potential causes, you may want to consult the user manual for your stapler or contact the manufacturer for assistance.
My stapler won't wrap staples around the paper. What can I do?
Amazon.com : The Classics Staple-Free Stapler the "Paper ...
www.amazon.com/The...Staple-Free.../B000IGCUZE
Amazon.com, Inc.The Classics Staple-Free Stapler the "Paper Grip" with 5 Sheet Capacity, Kid Safe (TPG-133). by The ... Gift-wrap available. Enter your ..... It is hard to get the correct pressure on the paper--too much and it tears, not enough and won't fasten.
PaperPro Prodigy One-Finger Desktop Stapler, 25 Sheet ...
www.amazon.com/PaperPro...Stapler/.../B000GGY9L...
Amazon.com, Inc.
Rating: 4.4 - ‎399 reviews
Gift-wrap available. ... One-Finger Stapling Technology only needs one finger to stapleup to 25 sheets ... The Paper Pro Prodigy Stapler is the most distinctive, powerful non-elictric stapler available. .... This is such a great, easy to use, and quality stapler that once you use it, you won't want to use a ... A near-great stapler.
Swingline® Full-Strip Stapler, 15 Sheet Capacity ... - Staples
www.staples.com > Office Supplies > Office Basics > Staplers
Staples Inc.Stapler can easily handle up to 15 sheets of paper at a time and has ... refill this Swingline stapler with a full strip of standard office staples, so it won't run out of ...
Staples One-Touch™ Plus Desktop Flat Stack Full Strip ...
Stockists for workzone staples
where can i locate staples for workzone sttapler
size are 8x11.3x1,2
4helpful
3answers
I can't seem to reload staples into this stapler. I used the staples that came with it and it worked fine. I try reloading and it doesn't staple.
With the stapler sitting a solid surface, turn it 180 degrees so it is pointed away from you, and you are looking at the back. Press down on the plastic extension that you see (about mid-height on the stapler). This releases the staple-holding compartment (it shoots out the front of the stapler). Reload it with standard staples, push the compartment back in place until you hear a click. Voila!
10helpful
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
9helpful
2answers
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Tr250 does not drive brad nails all the way down.
Jason,
I think this is typical of these staplers/nailers. I bought a lighter model Stanley the first time and had this problem. I took it back and exchanged it for the heaviest Stanley they had at Home Depot and had the same effect. It drove the stapler a little deeper but not all the way.
I did find that if I put all the down pressure on the stapler right on the edge where the staple comes out and then pull the trigger it would drive the staple almost all the way in. I think that there is a recoil effect (like with a gun) when you pull the trigger and the staple enters the wood. Try this. it will help.
Hope this helps Good Luck Loringh PS Please leave a rating if appropriate Thanks for using FixYa
AS 300 electric stapler--pulled out jammed staples but even though it staples, it won't grab the staples (staples as though empty)
What has most likely happened is part of a staple is stuck in the front portion of the stapler where it forms the staple and presses it into the stapler.
You would most likely have to remove the stapler, and remove the binding staple from the stapler head.
Top Staples Tools & Hardware - Others Experts
vince
Jesse Walters
Jesse Walters
Paul Bade
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
