Question about Smith Corona Office Equipment & Supplies
Have an electric Smith corona sterling from the 60's and the carriage will return when I hit return key but immediately goes back to the left. How do I correct this?
  • 453 Answers
May be that there is a broken tooth on the escapement or the release lever is sticking
Posted on Feb 02, 2017
4 Suggested Answers
  • 329 Answers
SOURCE: Smith Corona 235 DLE doesn't advance
Does the platen move or does the paper not advance? Check the paper release lever to make sure the feed wheels are snapped in place. If the platen does not move something in the paper feed motor area.
Posted on Aug 13, 2008
  • 49 Answers
SOURCE: hitting Return just brings the carriage back to
Assuming this is a mechanical machine with elect5ric motor:
Verify the line space selector is not set on 0. (just inside LH platen knob)
Check that the LH platen knob does no have a push lever sticking out to the left.
Try placing a few drops of oil at the left portion of the platen, just left of the metal teeth (the linespace pawl may be jammed and not restoring to rest position)
Posted on Nov 09, 2009
afzalhareez
  • 5 Answers
SOURCE: smith corona sterling floating manual typewriter carriage return does travel all the way to the right
To make things clear are you not able to ON your PCusing the POWER button? or is this a resarting issue?
If POWER button issue please follow as below;
There should be the following issues related:1. Power supply issue2. Power or Reset button issue
-lets take above number 01 firstif it is power supply issue you will need to replace the power supplyby submitting it to a store or dealer.
-if it is number 02 we will need to check it as below:Remove the chasing (remove all screws and cover/ if there are no screwscheck the manual to remove the chasing)
check the cable which connects to your power switch to you PC.Remove this cable (you could see this cable mentioning as 'POWER' printedon the end of the cable which fits to the motherboard)
unplug/remove this cable from your motherboard and then switch on yourpc. See whether this switches the PC automattically. If so, the issueis with the POWER switch. You will need to replce this cable with yoursystem manufacturer. If this is not the case then the problem is withyour powersupply.
Posted on Dec 12, 2011
I need Smith-corona sterling manual
PDF]SMITH - CORONA STERLING
site.xavier.edu/polt/typewriters/SCSterlingManual1963.pdf
Your new Smith-COrona Sterling is a precision built writing ... ponents or when youhave occasion to change ... ble quick and easy it you follow instructions.
[PDF]Owner's Manual for Smith-Corona Standard Portables
sevenels.net/typewriters/manuals/Smith-CoronaPortablesManual.pdf
YOUR NEW SMITH-CORONA PORTABLE is the finest portable typewriter ... havemade Smith-Corona portable typewriters the ?rst Chain: of millions.
Smiths & Coronas - Sevenels.net
sevenels.net/typewriters/s-coronas.htm
See here for a quick-reference guide to Smith-Corona portable serial number prefixes. ... Download the manual for this typewriter here. Corona Four Serial # ... So why haveonly a fraction of these already rare sterling silver Sterlings survived?
Smith-Corona Sterling Manual Typewriter - YouTube
? 0:41
https://www.youtube.com/watch?v=gt9MsZWWHiE
Feb 04, 2016 | Smith Corona Office Equipment & Supplies
How do I fix my Smith Corona SC110 Typewriter?
make sure the right hand platen knob is tight hold the platen and turn the knob top toward the back of the typewriter until it is tight
Aug 17, 2014 | Smith Corona Wordsmith 100 Typewriter
I have a Sterling Cartridge Smith-Corona typewriter and it shakes really bad when I turn the on switch, what is the problem?
It could be the machine is trying to return but is not successful. Help the carriage by hand up against the left margin, and see if this helps. Sometimes the centrifugal clutches on the motor need replaced, and sometimes the belts can cause this. Either way, you will probably not be able to fix it yourself.
Jul 17, 2013 | Smith Corona Refurbished Super Sterling...
Hitting Return just brings the carriage back to the start of the same line and doesn't insert a line break on a smith-corona
Nov 08, 2009 | Smith Corona Office Equipment & Supplies
Carriage return problem
The tab button may be stuck or the carriage release lever is stuck or a broken escapement.
Dec 24, 2008 | Smith Corona Wordsmith 100 Typewriter
Jul 28, 2008 | Smith Corona Wordsmith 200 Typewriter
Carriage Return doesn't work. Everything else works fine; but it will not return the carriage when the return key is used.
check to make sure no forien objects are in machine preventing the carrier from moving, with the mach. turned OFF you should be able to move the carrier by hand from one side to the other
Jul 09, 2008 | Smith Corona Wordsmith 100 Typewriter
90 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Ron Dufek
Ron Dufek
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
