Question about Whirlpool Washing Machines
Water will not drain out
Whrilpool Heavvy Duty Imperial-2speed/9cycle Modle#LA7800XSW1 Water will not drain out properly.
  • 744 Answers
Hi..
Remove bottom panel. ( 2 or 3 screws on bottom.) Remove what looks like a big white screw, this is probably clogged up. When you do this, lean the machine back about 45 degrees and have bucket ready when removing the pump clean out...This should help
thank u
rate me
Posted on Jul 21, 2009
How to remove a underground swimming pool pump
if the pump is above water level there is no need for valves. If the pump is below water level, partially drain pool until water level is below pump, then install unions and shut off valves when you remove the pump.
Aug 18, 2014 | AO Smith BN62 3hp 230 v Spa Pool Pump...
I have a frigidaire 9 cylce-heavy duty-2speed ,model fws445rfs0. It fills with water, drains water but won't spin on the spin cycles. I was trying to remove the middle spinner piece inside to see if...
for schematic try:http://www.partselect.com/ModelFrames.aspx?ModelID=1004870&ModelNum=FWS445RFS0&mfgModelNum=&ManufactureID=4&Selected=ZH8J52ZV&Position=4&mfg=Frigidaire&Type=&Mark=4
Feb 02, 2012 | Frigidaire Washing Machines
I have a Maytag Heavy Duty 2speed super capacity 9 cycle washer. My washer won't spin are drain on regular cycle or permanent cycle. It will however spin and drain on delicate cycle! Could you please give...
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time. It is possible that there is less water and more time for the pump to empty on delicates.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 05, 2011 | Maytag Washing Machines
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Jun 05, 2009 | Admiral AW22 Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
