Question about Furniture
My mother in law has a craftmatic bed and the bed will not lower. The head and feet raise and lower, but the whole bed is stuck in the up position.Is there a way to manually lower it?
  • 2,191 Answers
Only if you can get to the motor and take off the cover and get a spanner or socket and rotate it till the bed lowers if possible but it can be dangerous
Posted on Dec 23, 2016
Have a 2017 jayco freedom motor home with the electric bed. Bed is stuck in the up position & will not come down
20160912_145359-zvse2t43rh2wgzoypk0ynhom-4-2.jpg Here is an example of a Tempurpedic electric bed. Depending on your preference to find a cure or to just woke a band aid to give temporary results. On the first picture you see the screen lever attached to frame rail to raise and lower the head. If you remove the cotter pin and push out the connecting pin, you will be able to detach the motor drive system to lower the head for sleeping. On the other hand, the second picture shows the motor assembly. If you can detach it vs trying repair it in an awkward position, you can open the casing to check the screw drive that extend the shaft that you just detected. While there, check the wiring and plug connection to make sure everything is solid. If you have an assistant and a multimeter, you could also check to verify you have voltage, which should be 120VAC, when the switch is being pushed to raise as well as lower. Maybe check the plug and power before disconnecting anything, just in case.
Feb 23, 2018 | RVs
My bed does not go up or down for feet or head. It worked one day and not the next please help me. Its a craftmatic1 that has the control attached to the bed i beleave it was made in 2005
If you have checked to make sure the bed is plugged in and the outlet works, recommend contacting Craftmatic. Here is a link to download the manual. http://www.craftmaticparts.com/index.php?main_page=index&cPath=10
Troubleshooting steps are included along with the contact information.
Mar 05, 2015 | Cars & Trucks
The bed is stuck with head up can I manually lower the bed
We have a Tempur-pedic. Each side is controlled by its own remote. It also has battery backup for each side (head and foot) in case the power goes out. We simply push a little button on the battery controlled box on whichever side needs lowered. It works to lower them, but they cannot be raised in a power outage. If you don't have something like that, or a manual crank or something, I suggest you call the company and ask THEM what to do. If it's stuck with the power still on, then even more reason to call the company.
Apr 23, 2014 | Ergomotion Furniture
Craftmatic
Why not refer this problem to Craftmatic directly?
Nov 28, 2012 | Televison & Video
Ultramatic bed problem - bed will not raise either head or feet - does not move at all. Received replacement remote from company but no different. Lights on remote do not stay on - only when press a button...
Had same problem with my husbands moms bed. Found out that it ended up being a stripped plastic piece that the screw uses to raise and lower the bed. Because its stripped the screws don't have anything to grip on again to raise or lower bed. Piece needs replacing, but not sure where to get them.
Jan 12, 2011 | Minicraft Models Full Electric Bed -...
My Craftmatic Adjustable bed does not stay upward after adjusting it (head or foot). It just slowly sinks back down.
Hi. Most likely a faulty switch in the hand piece. I had a hoist in for repair the other day doing a similar thing. The down switch was being pressed by the covering on the handpiece. You might be able to find someone in a local electronics store to look at it or buy a new hand piece. Try raising the bed and then unplugging the hand piece and see if the bed stays up. Good luck. Neil.
May 21, 2010 | Health & Beauty
Have craftmatic bed with wireless remote. It stopped working....
while setting ours up last night I noticed that the 3 plugs that go into the moter unit do not like to stay in. have you check to make sure they have not come loose?
Jan 27, 2010 | Health & Beauty
Furniture Logo
479 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
