Question about Ovens
How to turn in a qa hygena APM3120 WHITE SINGLE ELECTRIC OVEN
bozcro
  • 867 Answers
SOURCE: my proline electric single oven is not heating up
most likely the heating element needs replacing, about 25 $ part.
Posted on Aug 31, 2009
  • 197 Answers
SOURCE: Thernostat Probe in Hygena QA Built in Oven is
inside the cooker at the top, they should be two little clips where the probe fits in to
Posted on Sep 21, 2009
Testimonial: "Many thanks for the informaion."
  • 417 Answers
SOURCE: Replacement knob for Hygena Turbo electric oven
You should be able to get a replacement fairly readily, try www.appliance-parts.co.uk or www.cooker-parts.co.uk.
Posted on Jan 04, 2010
barkencoa
  • 3463 Answers
SOURCE: Door hinge on hygena single electric oven broken
You neede to replace both door hinges.
To get more detailed instructions on how to do this, go to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR HINGES.
You should then click on the appropiate link, and follow the instructions.
Please rate my solution.
Thankyou.
Posted on Feb 04, 2010
Testimonial: "Ideal, thanks!"
ZJLimited
  • 17970 Answers
SOURCE: f7 will not stop flashing single electric oven
F7 usually indicates a problem in the control keypad in which case on your model the whole console panel usually needs to be replaced to correct the condition.
With the right model, in this link check this PART REPLACEMENT
Hope this helps.
Posted on Jul 06, 2011
My oven display has "sABBATH" written on the
May I get the make and model # to help you more. On some ovens if you hold the clock button for secondes it should turn off. I need the make and model # to be-sure.
Apr 24, 2011 | Maytag 24" Built-In Single Electric Wall...
How to install GE JKP35DPBB 27" Double Electric
The specs for this double oven give a rating of 5.1kW at 208V so it needs a 30 Amp circuit breaker. This assumes that the oven is the only appliance on the circuit. So you should be able to use the same circuit breaker.
A bigger consideration is that the opening for the double oven needs to be larger than that of the single oven. If the opening does not have a solid bottom, it must be able to support a heavier load. The runners and braces under a single oven has to support 200 pounds (91 kg). A double oven must have braces and runners designed to hold 375 pounds (171 kg).
Also check if your household uses aluminum wiring. The new oven has copper and problems will occur at the interface if you do not use the appropriate precautions. (Products designed for mating copper and aluminum are available - follow the directions).
I hope this helps.
(btw: you can find the User's Guide and Installation manual for the double oven at GE's website: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JKP35DPBB . See the section Literature and Manuals on the left hand side of the page below the picture of the oven.)
Oct 29, 2010 | GE 27" Built-In Double Electric Convection...
WWW.YOUTUBE.CO.UK
Thankyou.
Feb 03, 2010 | Ovens
Jan 04, 2010 | Ovens
MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
Dec 09, 2009 | Maytag 24" Built-In Single Electric Wall...
My Maytag Oven has 3 wires one red, one black & one white and then a copper wire. Will my oven model M5530DDs work with 220VAC? If so how can Identify which wire is which in electric terms?
red and black wires are the two "hot" power wires, the white is your "N" neutral connection and the bare goes to the appliance metel case as safety ground
Oct 02, 2009 | Maytag 30 in. Electric Single Wall Oven...
Thernostat Probe in Hygena QA Built in Oven is hanging down inside. Where should it be affixed?
Sep 21, 2009 | Ovens
Aeg b4101 single oven ,three years od
Sounds like a faulty thermostat.You will need a new one
Nov 07, 2008 | AEG B1180-4 Electric Single Oven
Ovens Logo
26 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
