Question about Radio Communications
I have a trio ts 940s and cannot get any rx or sound on lsb usb cw am but comes to life on fm any ideas ???
2 Suggested Answers
  • 219 Answers
SOURCE: Wat ar FM,AM,USB,LSB.CW. On a CB radio
FM - Freq. Modulation
AM - Audio Modulation
USB - Upper Side Band
LSB- Lower Side Band
CW- Morris Code
Posted on Dec 04, 2009
I have a Galaxy ssb echo bace,with cw,fm,am,usb,lsb selection nobs.It power's up ok,but no transmit,or receave,please what could be the problum ? I can only guess maby the finals perhaps?
could be a number of problems,final being one of them.Could be a bad match to your antenna . could be a bad transformer or a rectifier . If you have no electronic knowledge take it to a tech a let them work on it. Could save you some money .
Dec 18, 2015 | Radio Communications
Usb audio
need to put it on an oscillascope and frequency counter and have it aligned. even taking to a shop should be less than $45 to have it fully done.
Mar 21, 2014 | Magnum Radio Communications
CW- Morris Code
Nov 27, 2009 | Ranger Communications RCI-6900F-25 CB...
How do i find the FM frequency for a Connex CX-4300-300 CB radio?
FM is just a form of modulation, not an actual frequency. The frequency doesn't change between any of the modes (LSB, USB, AM, FM, CW).
For example, if you are on channel 19 (27.185MHz) on AM (Amplitude Modulation,) switching to FM (Frequency Modulation) mode you would still be at 27.185MHz, but using a different form of modulation.
Nov 10, 2009 | Connex CX-4300HP CB Radio
Lightning happend, not far away.
dear Sires,
Sorry i am not finished yet with my TS-440S. I have found that TXB and RXB supply signals are present in same time. Transistor Q35 from IF UNIT was burned thru. Now the trasciever works in all modes excelent, but just on the 3,5, 7, 10 and 25 MHz band. I am looking for next damage away, but i have a little problem. I became a pacemaker last week, and must keep my right arm a vile.
With regards
M.Galovic 9a5amg
Jul 06, 2009 | Kenwood Audio Players & Recorders
How to find hidden menu on yeasu 857d
Note: The following was taken from a web site as follows:
http://www.kb2ljj.com/data/yaesu/ft-857.htm
WARNING: changing these will reset all the memories.
I want to warn you do not change these values unless you are sure of what you are doing. To get them turn transceiver off. Press and hold the A,B,C keys; while holding them in, press and hold in the [PWR] switch for 1/2 second to turn the tranceiver On. Now let go of all keys. Attention, for menu NO-017. Input voltage 13.8V = 138 to calibre voltmeter.
Press F key to finish.
Function Setting in my radio
============================================================= Adjust-No Function Setting Mode Frequency ============================================================= NO-001 HF1-RXG 118 CW 1.800.00 NO-002 HF2-RXG 91 CW 7.068.19 NO-003 HF3-RXG 133 CW 21.225.13 NO-004 50M-RXG 106 CW 50.000.00 NO-005 VHF-RXG 77 CW 145.437.50 NO-006 UHF-RXG 103 CW 438.900.00 NO-007 SSB-S9 61 CW 21.225.13 NO-008 SSB-FS 54 CW 21.225.13 NO-009 FM-S1 68 FM 145.437.50 NO-010 FM-FS 99 FM 145.437.50 NO-011 DISC-L 50 FM 145.437.50 NO-012 DISC-H 79 FM 145.437.50 NO-013 FM-TH1 100 FM 145.437.50 NO-014 FM-TH2 100 FM 145.437.50 NO-015 FM-TI1 10 FM 145.437.50 NO-016 FM-TI2 10 FM 145.437.50 NO-017 VCC 138 FM 145.437.50 NO-018 HF1-IC 83 CW 1.800.00 NO-019 HF2-IC 80 CW 7.068.19 NO-020 HF3-IC 87 CW 21.225.13 NO-021 50M-IC 84 CW 50.000.00 NO-022 VHF-IC 72 CW 145.437.50 NO-023 UHF-IC 74 CW 438.900.00 NO-024 HF1-PO-MAX 165 CW 1.800.00 NO-025 HF1-PO-MID2 105 CW 1.800.00 NO-026 HF1-PO-MID1 31 CW 1.800.00 NO-027 HF1-PO-MIN 13 CW 1.800.00 NO-028 HF2-PO-MAX 159 CW 7.068.19 NO-029 HF2-PO-MID2 102 CW 7.068.19 NO-030 HF2-PO-MID1 29 CW 7.068.19 NO-031 HF2-PO-MIN 11 CW 7.068.19 NO-032 HF3-PO-MAX 158 CW 21.225.13 NO-033 HF3-PO-MID2 101 CW 21.225.13 NO-034 HF3-PO-MID1 29 CW 21.225.13 NO-035 HF3-PO-MIN 11 CW 21.225.13 NO-036 50M-PO-MAX 145 CW 50.000.00 NO-037 50M-PO-MID2 92 CW 50.000.00 NO-038 50M-PO-MID1 47 CW 50.000.00 NO-039 50M-PO-MIN 8 CW 50.000.00 NO-040 VHF-PO-MAX 87 CW 145.437.50 NO-041 VHF-PO-MID 43 CW 145.437.50 NO-042 VHF-PO-MIN 7 CW 145.437.50 NO-043 UHF-PO-MAX 112 CW 438.900.00 NO-044 UHF-PO-MIN 16 CW 438.900.00 NO-045 HF1-TXG 48 USB 1.800.00 NO-046 HF2-TXG 38 USB 7.068.19 NO-047 HF3-TXG 43 USB 21.225.13 NO-048 50M-TXG 40 USB 50.000.00 NO-049 VHF-TXG 47 USB 145.437.50 NO-050 UHF-TXG 49 USB 438.900.00 NO-051 ALC1-M 203 USB 21.225.13 NO-052 ALC-M 85 USB 21.225.13 NO-053 HF1-REV-ALC 61 CW 1.800.00 NO-054 HF2-REV-ALC 56 CW 7.068.19 NO-055 HF3-REV-ALC 50 CW 21.225.13 NO-056 50M-REV-ALC 47 CW 50.000.00 NO-057 VHF-REV-ALC 62 CW 145.437.50 NO-058 UHF-REV-ALC 57 CW 438.900.00 NO-059 CW-CAR-LEVEL 144 CW 21.225.13 NO-060 AM-CAR-LEVEL 125 AM 21.225.13 NO-061 DEV-W 216 FM 145.437.50 NO-062 DEV-N 110 FM 145.437.50 NO-063 MOD-MTR 200 FM 145.437.50 NO-064 DTMF-DEV 10 FM 145.437.50 NO-065 CTCSS-DEV 233 FM 145.437.50 NO-066 DCS-DEV 168 FM 145.437.50 NO-067 LSB-CAR-POINT -7 LSB 21.225.13 NO-068 USB-CAR-POINT +5 USB 21.225.13 NO-069 VSWR2 at 10W 17 CW 14.257.90 NO-070 VSWR3 at 10W 42 CW 14.257.90 NO-071 ATAS-TEST LSB 14.257.90 NO-072 AMTR-TEST LSB 14.257.90 NO-073 HTEMP-THRESHOLD 38 LSB 14.257.90 NO-074 FTEMP-THRESHOLD 102 LSB 14.257.90 Hope thia helped........kevin KC8IDG
Oct 21, 2008 | Radio Communications
Cb radio
i have a president hr2510 when you finish keying the mic.say am,usb,lsb the receive takes a 2 seconds to come back on any ideas out there....
Aug 08, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
63 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
