The developer unit for the SL'X7609GX color neutral
That code indicates a problem with the (K) developing unit, which is the black color developing unit. Try removing and reinserting the black developing unit. If that doesn't work, probably need to replace the developing unit. Hope that helps.
Sep 28, 2016 | Kyocera Office Equipment & Supplies
Have error 2453 bizhub 6501c
cyan developer motor, developer sensor or control board. swap developer unit with different color does the code change, if so then replace the developer unit, First replace cyan develop and run required checks
May 21, 2015 | Konica Minolta bizhub Office Equipment &...
C550 to making full reset like new copper . Developer one of colors out from the unit every 3000 copy
Sir, what color has the problem? I don't understand you question? Are you using OEM parts. Have you had qualified Konica Minolta technician look at it?
Feb 05, 2015 | Konica Minolta Bizhub C550
How can i settle the problem of magenta developer finishing so fast. Magenter developer for Konica Minolta Bizhub C550 is getting finished so fast.
If the message Change Imaging Unit Magenta displayed refer to imaging unit with contents a developer.The Imaging unit life is 80.000 copies.
The imaging units located after front door when is located the waste toner box.
If the message M toner end/change the M toner displayed refer to toner cartridge
The toner cartridge life 15.000 copies 5% saturation.In full color mode the color saturation is 80% and the color toner life is 6.000-8.000 copies.
I think your problems is a toner not the developer.
Apr 11, 2013 | Konica Minolta Bizhub C550
Which developer should I use
I have a few questions first. A: What is the natural color of the hair?B: Are you trying to lighten hair that has been previously colored? If yes what color is it?C: What is the desired color in the end?
Jan 23, 2013 | Clairol Kaleidocolors Tonal Powder...
Blue line in middle of the colored copy how can I fix
What color is the blue line showing up in??? If it is a green color there is a problem with the yellow drum or developer > I the color is a purple color then there is a problem with the magenta drum unit or developer unit.... Odds are you may need a service tech to come out & do a general cleaning...... Good Luck
Dec 07, 2012 | Sharp MX-2300N Color Copier
It's asking me to change the developer unit! What is this?
The developer unit is the part that is supposed to distribute the toner to the particular drum or photoconductor. a broken developer causes a faint or white line or even band in the concerned color. This is usually a difficult part to replace and the job is mostly very dirty. i advise contacting a technician.
Sep 27, 2010 | Sharp MX-2300N Color Copier
Wiring motion sensor for bathroom lights SL-6107-WH need to know what color ires are? BLK,Brn,Red,Grn
OK .. this sounds european .. but as I understand it ,,, the black would be power connection .. the brown would be neutral connection .. and the red would dgo to the light being controlled .. the green always connects to everything metal
If there is no neutral wire in your switch box to connect to ,,. then you will need to get a dimmer that does not require a neutral connection.
Please Vote !!
Dec 30, 2009 | Heath Zenith Occupancy Motion Sensor Wall...
Ricoh Aficio CL7300 DT2 Laser Printer Cyan color issues
developer unit not set properly.
push the unit in tight
Mar 16, 2009 | Ricoh Aficio CL7300 DT2 Laser Printer
20 people viewed this question
