Question about Dyson DC44 Animal Cordless Vacuum
My DysonDC44Animal stops and won't start again until I charge it for a while. Is this normal?? Can you only run it continuously for a short time?
    Top Expert:
  • Dyson Master
  • 39,229 Answers
The battery may be weak and unable to recharge completely after use.
Posted on Dec 23, 2016
Dirt devil easylite 7.2 v does not hold charge. Can you suggest any fix? Thanks
Sorry to say that the batteries seem to be worn out. Usually this is caused by using it for to short a time each time you use it. Batteries develop a 'memory' after several short time uses, and can only be charged the time it 'Thinks' is a full charge. You can try running it until it almost stops. Then let it sit for about an hour turned off, then turn it on again, and run it till it almost stops. After doing that put it on the charger for 8 hours. Then run it until it almost stops again. then charge it again. That process sometimes breaks the memory problem. If not, you need new batteries- or a new dirt devil.
Jul 02, 2017 | Dirt Devil Vacuums
Bikegit
Replace the switch! It shut down when battery get depleted. and then when you start it again the cycle is shorter because the batery regenerate but not as previous cycle.
Jul 16, 2014 | Karcher WV50 Window Vacuum
Room a 620 keeps stopping
It could be clogged with hair (when was the last time you cleaned it out?), it could be the battery isn't holding a charge any longer. It could be getting caught on something . How long is it running before stopping? I found I used to get about a two hour run from my Roomba, before the red light flashed. Then I started to unplug the charger and Roomba when it had a full charge and it wasn't needed. I noticed that after this the Roomba didn't run as long, maybe one hour, before needing a charge again. I leave it plugged in all the time now.
Jul 07, 2014 | iRobot Roomba 560 Robotic Vacuum
My dc04 motor stopped in mid use and wont start up again has motor gone?
Hi Steve,
Your DC04 is equipped with a safety device which shuts down the machine if it starts to overheat. This can be due to a blockage, or because the filter needs a wash. You should find the machine will restart after cooling down for about an hour, but to ensure this doesn't happen again, please follow the steps shown in our online support guide to locate and remove any blockages from the cleaner:
http://www.dyson.co.uk/support/help.asp?article=89&product=DC04-SY-STD-BC
In normal use, the filter should be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
This should resolve the issue, but if the machine won't restart, or if it continues to cut out in use, please get in touch with us directly so we can help. You can call free on 0800 298 0298 - our Helpline is available from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Dyson Online Customer Support
Nov 07, 2011 | Dyson DC04 HEPA Bagless Upright Cyclonic...
My dyson handheld charges fully, but keeps cutting out when using. About 7 seconds is the longest continual usage time
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to replace the battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
May 21, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Fully charged, filters cleaned, vacuum keeps shutting down in and then starts again only to shut off again. the 6 minute time limit is not used up.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Oct 19, 2010 | Dyson DC16 Root 6 Bagless Handheld...
My dyson dc 16 hand held vacume stops & starts while in use, each time you pull the trigger it will start again but then stops after a short while untill i pull the trigger again.
Cutting out can be due to a few things , motor overheating due to dirty filter, Faulty mains cable or plug..sealed type also..Faulty Switch/trigger.May need to seek pro help to fix.
Apr 01, 2010 | Vacuums
I have a Nutone central vacuum model number CV450W that was working great until I recently removed the hose and it now runs continuously until I pull the plug....any suggestions please
Disconnect the thin low voltage wiring between the vac and the rest of the house. If the vac continues to run you have a defective relay in the vac motor housing.
If the vac stops you have a short in the wiring in the house, likely behind an inlet in the wall.
If any inlets have been disturbed for painting or renos lately that would be the first spot to look in the house for a problem. Look for wires behind the inlet valve which are touching against each other or a mounting screw or against a metal mounting plate behind the inlet. Start at the last inlet used. Be careful not to loose the spring under the screws where the wiring attaches to the inlets
Oct 08, 2009 | Broan-NuTone CV450 Central Bagged Central...
Roomba 415 bumps into something 3 time, stops
Txs for not helping me out unless I pay for it!!!! :-(
Jan 02, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Turning itself off
With newer models will not work things that you attach to the vacuum such as the hose and the carpet shampoo attachment. Loose attachments will work just fine. It is same diameter holes that are being used in later models.
Switch - there is not much you can do without getting inside of the vacuum. You have to access inside and get it fixed.
Rocky
Aug 22, 2008 | Kirby Heritage II Vacuum
Dyson DC44 Animal Cordless Vacuum Logo
128 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
