Cannot connect my you view box to the internet
How do I change the compatibility mode on the PC to normal;
you can change the compatibility view settings on internet explorer 8 by following the steps below:
1. open internet explorer
2. go to "tools"
3. go to "compatibility view settings"
4. the websites that have been added to compatibility view list will be displayed in the box under "websites you've added to compatibility view". you can remove them by using the "remove" option besides the box.
the following link can be helpful:
Jan 20, 2015 | Microsoft Windows Internet Explorer 8 for...
Fix internet connection windows 7
If your having a problem with Internet explorer dorpping your connection,here is a fix.
First left click start,then left click Control Panel.
Now under the headding (Network and Internet) look for View network status and tasks,left click (View network status and tasks) a new window will open called (View your basic network information and set up connections)
Left click (Local Area Connection) a new window will open,look to the bottom left you will see (Properties) left click that.
A window will open called (Networking) in the center of the window you will see (This connection uses the following items) in that window look for (Internet Protocol Version 6 (TCP/IPv6)
Remove the check mark from he box on the left and click ok,now click close,in the (Local Area Connection Status) window click Close.Now just click the X in the window Network and Sharing Center.Thats it your Internet connection should run much better and not drop your connection.
Hope this helps good luck and enjoy your internet connection once again....
on Mar 03, 2011 | Computers & Internet
Your TV has a SCART socket. So you can use anything from a plain "receive only" Sky box through to the recording HD boxes. As long as the box also has a SCART socket then the TV and box can be connected.
If you take a box abroad with you to leave there permanently then you'll need to think about what kind of contract (if any) you want. A Sky box without a viewing card will let you watch a broadly similar range of channels to Freeview in the UK. There's a useful comparison guide here:
Used Sky boxes are available cheap from Gum and the Facebook selling pages, or have a look in your local classifieds.
If you buy a recorder box, remember that the recording and Live Pause features are only available with a Sky subscription. They don't work with an expired viewing card or no viewing card at all. If you think you'd like to record programmes while abroad then consider a Freesat PVR instead. It will cost more in the short term, but you will have the same kind of functions as a Sky recorder box.
One other option is TV via the net. There's a device called Slingbox. It uses the internet to port your home's Sky box signal to you somewhere else in the world. You don't bother with a second Sky box, just add a Slingbox digitiser to the home Sky box and connect it to your internet service. In Spain, you have a Slingbox receiver connected to the internet and your TV. What you've then got is control of the UK Sky box, and those signals sent to you in Spain via a web connection. You operate the Sky box in the same way you would at home. The difference is that the TV is 1500 miles away.
Slingbox relies on you having a decent internet service in Spain. That might not be practical, or possible, or even desirable. But if you want to have your full Sky package in a second location without forking out for a whole year's subscription then it is one solution that wiorks.
Sep 16, 2014 | Televison & Video
On my acer laptop, when i try to log on to Internet Explorer, the Dial-up Connection box pops up. In the "Connect to:" box i have Broadband Connection with a check mark in the "connect automatically"
To create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help.
Click on the tools at the bottom of the drop down list will be internet options.
Click on the connections tab tick in the box never dial a connection
Apr 15, 2013 | Acer Aspire Computers & Internet
I cannot view other webcam in yahoo messenger, always not connected.
Webcam not Connected ( to your Messenger ) can usually be overcome by setting your Messenger Internet Connection
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'No proxies' or 'Connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes, If not change them > Apply > OK
Jun 23, 2010 | Yahoo Messenger
I am trying to connect a new laptop to my home network. The wireless connection indicates that it is connected to the internet, but i canno get to the internet. I have statically assigned an IP like...
Internet explorer... Under the address bar you should see "file, view edit,favorites, tools and help" click on tools, internet options and go to the connections tab. make sure you have nothing in the white box then click on LAN settings. I bet you have "proxy settings" checked. None of the boxes should be checked.
Oct 13, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
After downloading yahoo messenger 9 ... i am un able to view webcams in yahoo chatrooms!
can u be plz bit more clear wid ur query?
as far as yahoo or any other IM is concerned the person who is having a webcam has to invite u and allow or give permission to u, inorder to view his/her cam.Unless and untill u wont be able to view a webcam without their permission
Sep 07, 2009 | Yahoo Messenger
Connected with limited access
This actually sounds like the device is not getting proper DHCP settings.
First of all, power cycle the router, and reboot the computer to make sure a fresh connection from both devices is achieved.
If the issue persists, check to make sure the computer does not have any static IP settings stored in the adapter.
The following steps will tell you how to do so:
-Control Panel
-In Classic View, select network connections
-In Category View, select Network and Internet connections, then select network connections
- Right click the appropiate network adapter (Local Area Connection, for cabled connections, wireless for wireless connections)
- Select Properties
- in the "This connection uses the following items:" Box select the "Internet Protocol (TCP/IP)" (making sure to keep the checkbox selected (selecting the name helps) then click properties.
- If obtain an IP address automatically is selected (and the boxes below are grey), and Obtain DNS Server address automatically (again grey boxes below) are selected then something else may be happening, which will require more advanced steps.
If the boxes are not grey, then you may have incorrect settings, select the appropriate radio boxes (listed above) to make the boxes greyed out, and that may resolve your issue.
Feb 26, 2009 | Belkin (F5D7230-4) Router (587009)
Cant get ps3 connection to internet
First, you need an ethernet cord and of course an aircard. connect one end of the the ethernet cable to your playstation and the other to your laptop. View your network connections (control panel-->network and internet connections-->network connections). Right click on your aircard connection and click properties. On the aircard properties window click the advanced tab. on the tab there will be a box asking if you want to let others connect to this connection. check in that box. below there will be a box asking what the home networking connection is. Put **Local Area Connection** in the box. Last make sure firewall is turned off. On your playstation go to network connections and click easy and go from there. (dont try to put in IP adress or anything just let the playstation do it all automaticly). Test your connection and you should be good to go.
Oct 15, 2008 | Computers & Internet
I would like sto dump my system, and start over. Syst: Gateway GT5220. running Windows XP service pack 3
this will perform an install that will eraseeverything and start over.
  1. Remove all CDs or DVDs from the optical drives.
  2. Turn off the computer using the normal Windows shut down process.
  3. After the computer is turned off, disconnect all USB devices except the keyboard and mouse. This includes USB devices such as a printer, scanner, removable storage, or camera.
  4. Turn on the computer. To start recovery, at the prompt press the F11 key.
    View Picture Note: If this is the first time the computer has been started to the recovery partition, insert the System Restore CD when prompted and then click OK.
    View Picture Files copy.
    View Picture
  5. In the System Restore Options dialog box, select Full System Restore (Destructive), and then click Next.
    View Picture
  6. In the System Restore - Format and Recover dialog box, click Yes.
    View Picture
  7. Files copy.
    View Picture
  8. In the System Restore dialog box, click Restart.
    View Picture
  9. The computer restarts.
  10. Drivers and applications are installed.
    View Picture Note: The following Out of Box Experience (OOBE) screens may vary slightly between models.
  11. In the Welcome to Microsoft Windows screen, click Next.
    View Picture
  12. In the Are your speakers working? screen, click Yes! I can hear the music!, and then click Next.
    View Picture
  13. In the What time zone are you in? screen, select the appropriate time zone, and then click Next.
    View Picture
  14. In the End User License Agreement screen, click Yes I accept for both EULAs, and then click Next.
    View Picture
  15. In the Help protect your PC screen, click Help protect my PC by turning on Automatic Updates now, and then click Next.
    View Picture
  16. In the What's your computer's name screen, type a name for the computer and a description, if desired, and then click Next.
    View Picture
  17. In the What's your Administrator password? screen, type the appropriate information, and then click Next.
    View Picture
  18. In the Is this computer in a domain? screen, click Skip.
  19. The computer checks the Internet connectivity. Please wait.
    View Picture
  20. In the How will this computer connect to the Internet? screen, select the appropriate option, and then click Next.
    View Picture
  21. In the Do you use a username and password to connect to the Internet? screen, select the appropriate option, and then click Next.
    View Picture
  22. In the Setting up a high speed connection screen, select the appropriate options, and then click Next.
    View Picture
  23. In the Ready to register with Microsoft screen, to register with Microsoft after the OOBE screens are completed, select No, not at this time, and then click Next.
    View Picture
  24. In the Thank you screen, click Finish.
    View Picture
  25. Installation is complete. Any application that shipped on a separate CD can now be installed. It is recommended to update the antivirus definitions and perform Windows Updates.
Oct 06, 2008 | Gateway Computers & Internet
Computers & Internet Logo
David Payne
David Payne
