Question about Pool & Spa
The Pacer pool cleaner is stuck in one area,while the pump is operating
  • 106 Answers
SOURCE: My pacer pool cleaner doesnot want to work , i put
Sounds like diaphragm is ripped. Replace
Posted on Jan 14, 2010
  • 106 Answers
SOURCE: Zodiac Pacer pool cleaner not sucking water or moving
Remove diaphragm and check for rips or tears in plastic.
  • 106 Answers
SOURCE: I have a baracuda pacer pool cleaner and it seems
A coupe of things you can try. Either add one hose length or take one off. If that doesn't help, you can reverse the hose positions.(take the first one off, and put it last. Change all of them) Also, changing the amount of suction may help.
Posted on Apr 19, 2010
Testimonial: "thank you for your suggestion I will try this solution of changing the hoses around"
jharwell668
  • 640 Answers
SOURCE: Zodiac Pacer getting stuck near
There are several things that you will want to check if these pool cleaners are becoming hung on your pool steps. make sure that you are utilizing your return flow. If the return jets are not positioned properly, it will cause issues with steps. Position the return line directional so that you can only detect water movement on the surface 8 feet out from the wall, and aim it at the center of the opposite wall. In addition to your return lines, you will also want to confirm proper hose length and weight. Make any adjustments to the flow needed if it is too strong. If these options don't work, you will need to install a wheel deflector (#W69647).
Posted on May 09, 2011
jharwell668
  • 640 Answers
SOURCE: My Zodiac pacer prefers to clean the walls of the
Here are a few things that you can try to get your pool cleaner to cover the entire surface of the pool. Add return diverters or divert return inlets downward. You may need to use the Pool Pulse feature to lower your flow. You might also need to add hose weights.
Pacer not "chugging" or moving around the pool. I
the pump may have a plugged up impeller or internal part wear , i need to know what type of pump yu have, also a plugged filter may be the cause
Oct 28, 2011 | Zodiac Pacer Pool Cleaner
Zodiac Pacer getting stuck near lower steps in shallow end of pool.
Dec 29, 2010 | Zodiac Pacer Pool Cleaner
My Zodiac pacer prefers to clean the walls of the pool instead of the bottom, and as a result it gets stuck on the walls over the water outlet
Dec 19, 2010 | Zodiac Pacer Pool Cleaner
Hi, we have a Zodiac pool creepy crawly pool cleaner which seems to work for a while, then get stuck in the one spot and not move in our inground pool.
With these pool cleaners, getting stuck in one spot is most likely the result of a waterflow problem. Check your water flow valve and make sure that it is adjusted correctly. make sure that you don't have any blockage that would prevent movement and cause the cleaner to stick in one place. This might seem like common sense, but make sure that you have enough hose to reach the entire pool. Many times, when this occurs, the cleaner cannot reach one part of the pool. make sure that your hose balance is correct also.
Oct 24, 2010 | Zodiac Pacer Pool Cleaner
Pool cleaner working very eratic , stop /starts
you probably need to replace the diaphragm, unthread the nut directly beneath the wagon wheel, press the white tube downward and inspect the rubber diaphragm for damage or deformity. this is the most common problem with the Zodiac Pacer.
Apr 07, 2010 | Zodiac Pacer Pool Cleaner
Barracuda Pacer comes right up the side and above waterline then sucks so much air, pump has to be reprimed. Really annoying
You just need to slow the cleaner down and dirvert some suction away from it. It should never really come anymore than 1/3 the way up the wall.
Mar 29, 2010 | Zodiac Pacer Pool Cleaner
Pacer does not run on INTEX pool pump, no pulsating action of diaphragm, pump sucking OK, Auto Weir Valve connected, pool 1,20m deep, round, 4,88m diameter
make sure to check the diaphragm inside, check for deformity or debris stuck in it. You can take the unit apart just below the wagon wheel and push the white tube downward to expose the diaphragm.
Feb 03, 2010 | Zodiac Pacer Pool Cleaner
Zodiac pacer
Jun 07, 2009 | Zodiac Pacer Pool Cleaner
May 31, 2009 | Zodiac Pacer Pool Cleaner
Pool & Spa Logo
46 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
