Question about Canon Office Equipment & Supplies
How do i fix the error code 000061-00001 in canon 6800 when message comes i got into service mode and change the bodyvalue from 1 to 0 machine works but the copy is blank
How do i fix the error code 000061-00001 in canon ir 6800 when message comes i got into service mode and change the user value from 1 to 0 machine works but the copy is blank
The Machine
  • 788 Answers
SOURCE: Canon i850, service error 6800
This error indicated that the internal printer counter for the waste ink sponge has reached its threshold. You should be able to reset this counter once without cleaning the sponge.
Do this:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
now try press resume button 4 times..after that press the power button
This should clear your error and let you resume printing. If you start getting ink smudges on the paper you will have to disassemble the printer and clean the waste toner sponge.
Posted on Jun 17, 2008
SOURCE: Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
Posted on Jan 12, 2009
  • 168 Answers
SOURCE: Error code E000070 0001
this is a error code for the transferf sheet either it is ripped or not turning anymore
Posted on Feb 03, 2009
SOURCE: CANON IR C6800 ERROR CODE E000078-0001
error code E000005-0000
Posted on Aug 26, 2010
SOURCE: canon iP 1980 berubah menjadi
kenapa bisa berubah dari iP1980 menjadi iP2600. apa solusinya dan penyebabnya ???
Posted on Mar 02, 2011
How to solve the error of canon iR2016 photocopy system error E003?
How to reset E000, E001, E003, and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Canon Printer Support Phone Number
Dec 06, 2017 | Canon Office Equipment & Supplies
How do i get the factory default setting for canon ir 6800?
Go to service and and clear the error
Asterisk * press
then press 2 & 8(Two buttons single time)
Again press Asterisk *
COPIER>FUNCTION>CLEAR>ERR
Then press ok an off the machine wait 1 minute and on the machine..
Jun 23, 2016 | Canon Office Equipment & Supplies
First i changed the fuse gear canon ir 6800 and put the fuse unit back to machine . when i turn it on the machine show the error 000005-000010 what can i do ?
hi . that error indicate that the cleaner roll ( in the fixing unit )is over . maybe there is a sensor disconnected or misplaced. check That section and clear error from service mode
copier / function / clear / err ok.
Feb 27, 2016 | Canon Office Equipment & Supplies
Error code is coming in my machine
Dear
To enter service mode
1) Press the User Mode key.
2) Press 2 and 8 on the keypad at the same time.
3) Press the User Mode key on the control panel.
Then press COPIER>FUNCTION>ENGIN>ERRCLEAR.
And make power OFF and ON.
If not solved..
1.Check connection of the Connectors (Thermistor Connector
and AC Connector).
2.Replace the Fixing Main Thermistor (Film Unit).
3.Replace the Fixing Assembly.
4.Replace the DC Controller PCB
Hope this may help you to get clear.
Thanks.
Feb 13, 2015 | Canon Office Equipment & Supplies
I have a canon 4080i error code e000004-0401 comes up and have to shut down when retart get the same message.
you have a fuser related error code, either thermisters or thermo fuse.
to reset error code you need to go in to a service mode and reset it.try this hit the additional fuction button then hit 2 and 8 keys together and additional function button again that will put you into service mode BE very careful in there though.
under function/clear/err code highlight err code then ok reset machine see what happens if error code comes back then you need to get a tech to have a look at ya fuser
Canon Tech
Apr 09, 2009 | Canon Office Equipment & Supplies
Do this:
3. Release RESUME
Jun 17, 2008 | Canon i850 InkJet Photo Printer
Canon pixma mp600
If its still under warranty send it back.
Solutions for error code 6800 Issue: Error code 6800 appears on the display (multifunction printers MFP)
1. Contact Canon for 6800 error - MP600 2. The MP600 may require repair
Oct 28, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
Sep 28, 2007 | Canon imageRUNNER 400S Copier
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
24 people viewed this question
old marine
old marine
