Question about Universal Televison & Video
AIM LCD TV UNIVERSAL REMOTE CODE - Universal Televison & Video
  • Universal Master
  • 6,694 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Posted on Dec 23, 2016
Code for remote tv sanyo
The code is 049 for my Sanyo TV
With my universal remote you hit the code search key until it lights up then you press and release the tv key
Then enter the three digit code and the indicator light turns off if you enter the wrong code the light will flash rapidly.
Aim the remote at your tv and press the on/off key. If your tv turns off you have found the right code.
Jan 10, 2015 | Sanyo 42 in. LCD TV
Tip
DirecTV Remote Control Code Search Tosearch for a control code for your TV...
Tosearch for a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Slide the MODE switch to the TV position.
  3. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  4. Enter 9-9-1 followed by 1:
  5. Aim the remote at your TV and press the PWR key once.
  6. Point the remote at the TV or component and press
    CHAN ^. Repeatedly press CHAN ^ until the TV turns off.
  7. When the TV turns off, press and release the SELECT key.
You have programmed your DirecTV remote control for your LCD TV.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
on Jun 10, 2010 | Universal Remote Control DIRECTV Universal...
Tip
DirecTV Remote Control Code Entry To enter a control code for your TV using...
To enter a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Locate the 5-digit code for your TV. (See DirecTV Remote Control Code List, page 14.)
  3. Slide the MODE switch to the TV position.
  4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
  6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 4 and 5, trying each code for your brand until you find the correct code.
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
I need to no the codes and how to set up the innovage jumbo universal remote to a LG LCD screen ? asap
The Innovage code list gives LG (Goldstar) TV only codes: 004, 005, 009, 056, 057, 155, 156, 172 . A manual code search is also available. Turn on the LG unit, aim the remote at the TV and press and hold Code Search until the LED lights up solid red. Push the TV button on the remote and then slowly press the on/off button until the TV responds. Then press Enter to store the code on the remote.
There is a link to the manual here: http://www.blurtit.com/q717681.html . Scroll down to the remotecentral.com link.
The only other issue is the age of the remote. Universal remotes only have the codes that correspond to devices released 6 months or more before the remote was programmed. If your TV is newer, then you need a newer remote.
I hope this helps.
Jan 21, 2011 | Televison & Video
I need the Cox remote code for 32" Dynex TV
You can try Insignia remote codes, because both are BestBuy brands and this has worked before.
Jan 20, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I want to program my Magnavox tv with a RCA remote and all of the online tips are not working
062,004,006,130,134,183,008,019,068,069,075,076,077,088,131,132,133,219,235
press code search indicotor light on.
press tv botton light blink.
enter codes tries each one on top light go off each code.
aim remote at tv off/on work u have it.
Aug 14, 2009 | Universal Remote Control TV-B-Gone...
Need a remote code for the tv 37" Sabre LCD Tv Model # lct371bka. RCA Universal remote Model # RCR660
as soon as u bought the universal remote it came with a paper that say a bunch of codes find ur tv model go to set up look were u can put in the code and follow the code exact
May 24, 2009 | Sabre LCT371BKA LCD TV
Need code
Hi beebeehuf, I will be happy to help.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Jan 21, 2009 | iLO 3200 32 in. LCD Television
Need tv code and direct tv code for universal remote
um no Jk. what you need to do is hit code search, and aim it at the device you want to program, hold code search untill it blinks and then press the icon of the deviced being programed on the remote.
Jun 13, 2008 | Televison & Video
Televison & Video Logo
Top Universal Televison & Video Experts
JOHN TOPLISS
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
