Question about Sony FD Trinitron WEGA KV-32HS510 32" TV
HV32HS420 blinking 6 times now
I've replaced the IC6501 & IC8002. Now it blinks 6 times. I have a service manual but not familiare with it. I am an electrician and can work with tools. Can someone please advise?
Thank you
  • Eric Vanderberry Aug 30, 2009
    OK, what am I checking for?
    Thanx
  • 3,037 Answers
Did you get my last message?
Six blinks means No Horizontal (H STOP), no raster, goes to the blinking-self diagnosis immediately. Check C515 and 516 and the jungle IC, IC206.
Let me know how this turns out
Benjamin
Posted on Jul 21, 2009
I have a Sony Vega KV 32HS420 it will not come on and bliniks 6 times. what is up?
Try replacing IC8002 and IC6501 (MCZ3001D).
Hope this helps.
Apr 07, 2011 | Televison & Video
Tv shutdown now blinks standby 6 times
a common fix for 6 blinks is an ic on the power supply board. the location is ic8002 locate and replace should fix your problem
Jan 25, 2010 | Sony KDF-55WE655 55" Rear Projection...
Sony Trinitron Wega TV keeps shutting off and red
There are two Ic's that need replacing on the Deflection Board (D) board.. These regulate power for the High Voltage and Chopper PWM circuits. The IC location on the board are IC6501 and IC8002
Nov 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My sony wega not start
If your SONY will not start and it is blinking the 6 or 7 blink code you can fix this by installing a new IC at location IC6501 and IC8002. You use the same IC's at both locations and they can be purchased on eBay for about $20. for a package of 4. the #s on the IC are: MCZ3001D and 0542D - they control the horizonal deflection circuit. Good luck.... OR you can pitch the TV because as I believe SONY's are junk. They are made in Tijuana Mexico.
Oct 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Light blinks 6 times, no picture, no sound
6 times blinks shows error of Low +B, OVP/ OCP
Replace IC6501 & IC8002 [ MCZ3001D ] on D board.
If you are handy with electronics stuff repair and can solder parts in circuit board then replace above said ICs or call local TV tech to do the job.
Thanks.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV turns off and the standing timer light blinks.
There is a timer option programmed into your set. Check the timer setting in menu, under advanced settings
Sep 16, 2009 | Televison & Video
Kv-34hs420 Standby light blinks 6 times. Power supply issues?
Replace IC6501 and IC8002 at same time, both have same number and located parallel on DZ board. Part number is as follows..
670581001 MCZ3001DB
Available in Part Store.
Jun 26, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony blinks 6 times wont turn on...is it worth fixing
replace on the D board
IC6501
IC8002
C6510
C8027
C6532
C8037
Hope this fixes you, if not then alot of other might get theirs fixed. please leave your feedback!
this fix cam from sony tech just 5 minutes ago.
FIxes problems with tv not turning on when cold, very hard to turn on. or people that have to unplug and plug in again to get it to come on. I usually dont give info like this for free as I'm a head tech.
good luck
Jun 26, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony kv-40xbr800 won't turn on, blinks 6 or 7 times
there are two large electrolytic caps on the D board located on the same side as the hv xformer.
both caps are 1200ufd at 250v, replace C6503, it is futher away from the side of the pcb.
this is the part of the ac rectifier that feed IC6501 chip MZ3001D
cap size is 1 1/8" diameter and about 2" inches high.
my problem with 6 or 7 blinks, would go away temporarily after the tv was unplugged for 24 hours.
i verified the fix by attaching a 250ufd at 250v cap in parallel with the C6503.
the problem was corrected.
you must assume the cap is leaking, which leads to the intermittent failure.
parts and shipping are a killer, so i turned to ebay.
search ebay for "Electrolytic Capacitors, 1200 uF, 250 Volt, Snap in 2X".
as the only bidder, i picked up two caps for $3.99 + $3.50 s&h.
might be wise to replace both caps, C6503 and C6590.
bill wireman
Feb 16, 2008 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony FD Trinitron WEGA KV-32HS510 32" TV Logo
211 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
