Question about Health & Beauty
My Conair model 264XRB hair dryer reset button will not reset. Note by button says refer to operator manual if this occurs but I don't have that. Help?
Shmoopy
  • 53 Answers
SOURCE: wii console error
Is it just one game that does this? Does it happen in the middle of a game or right away? Is the game an import?
I would call Nintendo on this one.
Posted on Mar 24, 2008
SOURCE: Conair WW36GD bathroom Scale
tanita 621 how do i change weight from cm to pounds??
Posted on Jan 18, 2009
SOURCE: HOW TO PUT THE SPRING BACK IN A CONAIR HAIR HC318D
I can help with this!
Posted on Aug 07, 2009
SOURCE: I need a manuel for model hc200 conair hair
http://www.conair.com/instruction_booklets/HC200ACS%20IB%209-29-061.pdf
Posted on May 25, 2010
  • 289 Answers
SOURCE: wii says An error has occurred. press the eject
Your discs might be scratched, the disc reader might be faulty or dirty. You should try to clean both the disc and the drive.
Posted on Jun 13, 2010
My Wascomat TD77 dryer keeps shutting down after 5 minutes and shows E 14. What is wrong with it.
Taken from the following: https://www.wascomat.net/pdfs/487032981.pdf
This is for a different model, but the codes are likely the same.
It is related to non-ignition of gas. You may need to switch on your gas supply, or service your ignition coil.
Resetting gas error
When the ignition control fails to detect a flame a error code E14 is displayed. When this condition occurs, the gas valve is shut off and the ignition control must be reset manually.
Resetting
Open the operating panel and press the gas reset button on the back of the user module board for one second.
See the picture of the gas reset button section 21
NOTE! When resetting the system the dryer must operate on a program with heat and when the heat indicator is on.
Error code
Error code 14 is a normal occurrence when first starting up a dryer, since air in the gas line must be purged.
Aug 26, 2014 | Dryers
Conair Ion 1875 hair dryer won't go on
did u try pressing the trouble shooter on the cord if that dosent work
take it back
Dec 05, 2012 | Conair Health & Beauty
Where can I find an online instruction manual for the Yellow Bird Conair Pro 1875 watt blowdryer, please?
I found a list of all their instruction booklets for hair dryers (some are 1875 watts) but they don't have the Yellow Bird:
http://www.conair.com/cnt_ib.php?action=filter&type=category
You could try calling Customer Service at 1-800-326-6247, or ask for the instructions via the online form here:
http://www.conair.com/customer-service-cn-18.html
Good luck, and I hope this helps!
Jul 01, 2011 | Conair YB075W HAIR DRYER 1875W YELLOW BIRD
I need maual for Revlon 1875 IONIC hair dryer Model # RV479 i want to download the PDF manual if possible
Well you may please follow the link below to get your manual -
http://www.conair.com/instruction_booklets/1875Watt_Ionic_Styler_146XR.pdf
Good Luck!!
Thanks for using FixYa!!
Mar 26, 2011 | Vacuums
How to disassemble philips 4891 hair dryer?
How to disassemble philips 4891 hair dryer? 'Conair corp ...
www.faqqq.com/fix/how-to-disassemble-philips-4891-hair-dryer-conair-co...
the of and to a in - Microsoft Research_??? ... w account security info april 99 right education comment net national co real ... say america feb maps canada ...
Philips - Hair Dryers
www.support.philips.com/.../worldproducts.jsp;...HAIRDRYERS...
PhilipsPhilips SalonPro AC Hairdryer HP4892 2000W IonBoost Ceramic diffuser ... PhilipsSalonDry Pro Hairdryer HP4891 2100 W IonBoost Ceramic diffuser.
How to repair the hair dryer not working not turn on - YouTube
? 1:02
https://www.youtube.com/watch?v=WITmaE5F9bI
Aug 16, 2012 - Uploaded by comohacerunomismo
This guide explains how to repair the hair dryer of our favourite brands: Phillips ... HOW TO FIX HAIR DRYERS / BLOW DRYERS, RESET AND ..
Dec 25, 2010 | Conair corp pers care 1875W CHR Hair Dryer...
What do I do if my reset button does not work on my conair hair dryer
Usually when hairdryers exceeded their temperature settings the thermostat shuts off and the reset button is pressed and the unit turns on.But if it doesn't it means that a fusible breaker is open(meaning that the line is cut-off).You want to repair it your self?Get a philips screw driver(one with a + tip on the end)unscrew the dryer opening it in half.There you would notice wounded wire(called nicrome wire-your heater) and there is this little silvery capsule like object with two wires on each end.Take note of the orientation of the part(the end is flat and the other end is conical) get a similar type on your local hardware store.And replace the bad one with the same position of the original.Screw the cover back take note of the parts where they are originally where and check if you have connected everything right(twice or thrice to make sure and be safe)before plugging it to the outlet.
Oct 29, 2010 | Heating & Cooling
Power chord frayed and I need a new one for a conair hair iron CS36. The chord pivots in the handle 360 degrees.
go to (www.fixit.com/small apliance)
what I found out with my hair dryer (conair infinity model) was that there was a short at the plug and when I bent the wire a little to left or right the dryer would work. The plug is GFI protected that means there is a test and reset switch built in to the plug. There for for me to fix my hair dryer I would have to replace purchase order the whole cord. The cord assembly cost almost half the price it would cost to replace the dryer with a new dryer. I purchased a new dryer.
Dec 26, 2008 | Conair Dry 'N Straight Hair Dryer and...
Frizzy hair!! help with conair hair dryer!!!
http://www.naturallycurly.com/
ask the curlies on the forums here! HTH!
Mar 07, 2008 | Dryers
Health & Beauty Logo
70 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
