Question about Frigidare Kitchen Ranges
I have a Frigidare gas range. Dropped a small piece of food into the gas vent slit in the bottom of the oven. How do I get it out? Or do I let it burn off?
  • 878 Answers
SOURCE: Kenmore Gas Range Oven not Working Properly
greg, sounds like your needle valve is not seated. Remove the bottom drawer. Look back to the base of the burner where the shutter air adjustment is. Right under there is the valve which should have a 1/2 inch or 7/16 nut. (I Forgot what size). Turn this nut clockwise until the flame is adjusted to the correct size, should be a nice blue flame. The nut maybe hard to turn because you are seating the needle. back
Posted on Dec 23, 2006
SOURCE: 8 year old kitchenaid gas range nom fire in the oven
I went to the kitchenaid web site for parts and found a trouble shooting section. I read about how a electronic glow coil works and discovered that mine was just old and did not reach the right voltage to open the gas flow valve.
Posted on Feb 21, 2008
SOURCE: tin foil baked onto bottom of gas range oven
rape it
Posted on Oct 09, 2008
SOURCE: Oven bakes unevenly and burns food
Jenn Aire oven is about 5 to 7 % cooler than electronic temperature setting. How may this be re-calibrated?
Posted on Oct 14, 2008
SOURCE: Whirlpool Gas Range E2 F3
Posted on Nov 24, 2008
Is my frigidare fgf326ASA a self cleaning range?
I didn't read through the manual but I didn't see a lock in the parts list. Self cleaning ovens are locked during the cleaning cycle for safety.
Below is a link to sears parts direct where you can download an operators manual.
Manual Frigidaire Gas range FGF326ASA
Aug 24, 2014 | Frigidaire FGF326AS Gas Kitchen Range
We had some butter drip on the bottom of the oven and a small fire started. Smothered it with flour to put it out now there is some flour and possibly butter that went through the slits in the bottom of...
I would just pull the oven all apart and clean it by hand...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Sep 07, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My apartment has a small Magic Chef gas kitchen range, I don't know the model number but on the back top of the unit is a space that heat pours out of when I use the oven. is this supposed to happen?, is...
Yes,this is normal.
The heat must escape all ovens for them to function correctly.
The advantage is, you can place a pot or pan of food near the vent to stay warm while the baking continues.
Works good as a bread warmer wrapped in foil also.
Aug 23, 2010 | Magic Chef 31000 Gas Kitchen Range
When i turn my oven on, the flames come up into
If the burner pressure is adjustable(some are not) you can use a small adjustable wrench to turn the gas orfice to lower the gas pressure. The orfice is usually located in the broiler/storage comaprtment at the very bottom of the range. It is the brass piece that goes into the burner venturri and is where the gas comes out. If your turn it clockwise it will decrease pressure & counter clockwise will increase pressure. If the flames are coming into the burner compartment that is quite an increase in pressure!!! Make sure the the range did not have the gas regulator removed. If it was then that would explain why the oven burner pressure is so high.
Nov 11, 2009 | Whirlpool GS460 Gas Kitchen Range
Need instruction book
Jade / Dynasty ph# 800-884-5233, most cases the big BANG noise is coming from the broken oven bottom pan, small BANG is normal, if you know how to remove the bottom them pull it out and inspect it, part of the V shape flame spreader may come off from bottom pan, you can have the welder weld it back on for you or order new bottom pan thru Dynasty. I'm not sure what do you mean by gas shut off. (turn off oven? turn off burners?)
Mar 22, 2009 | Dynasty DGRSC 36-4G Gas Kitchen Range
Bottom gas oven will not light
Ignitor. Easy fix.The new part comes with 2 high temp wire nuts. The wire is extra long. I would cut the old one at the base just to make it easier to replace.Remove the door to make life easier.
Jan 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Converted to LP Gas,How to adjust top & bottom flames in oven?
Open the air vent to the burner, you may have a small delate when it goes on , make sure the burner is clean buy the ignition, or the ignitor it's goin bad, you will know that when the oven takes more then a minute to ignite.
Nov 19, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Kitchen Ranges Logo
37 people viewed this question
Top Frigidare Kitchen Ranges Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Frigidare Kitchen Range Expert? Answer questions, earn points and help others
