I am having trouble with the volume of my new "magic sound composer keyboard by WinFun". How can I fix it?
I am having trouble with the volume of my new "magic sound composer keyboard by WinFun". I turn the toy on, turn up the volume and when I press a keyboard, it does not make any sound. Is there any way to fix this?
2 Suggested Answers
SOURCE: 65S500 will not turn off
Check to see if you have it set to do the Magic Focus on turn-off. It is in the menu under setup.
Posted on Jan 27, 2008
Some keys on the left side are not giving sound when played and the master volume is loosing can it be fixed or should i have to buy a new master volume
It's about hardwares.
Wiring connection sockets is loose.
Inside the korg PA50,Wiring connection to the keyboard is separate to left and right.
Open/disassemble your korg.
Look for connection cable to the left keyboard.
One end is on the keyboard,the other end is at the mainboard.
Unplug both of it, then mounted again.
For master volume,better buy new one.
Jul 31, 2013 | Korg Pa50 Professional Arranger Keyboard...
Toshiba model 37AV502U TV
Keyboard issues and answers:
A problem that is more common than most people think is an issue with buttons on thecontrol keyboards of modern TV sets.
Recently for whatever reason I have seen more questions about this so I have composed this answer and solution for these kinds of problems.
It can be any button on the set-channel up/down or volume up down-you name it.
The symptoms are the same: channel will scan up or down andwill not stop-remote control has no effect on this---It can be channel, volume,or even input or menu if the set has those up front or on the side of the set.
All these push controls have something in common-beneatheach is a tiny momentary push switch-when pushed with the plastic button itperforms a specific task (vol up or down etc.).
What happens is the afflicted switch beneath the plasticbutton is bad-when released it is supposed to stop its function but does not.
Keyboard or button controlled features have PRIORITY over the remote control, hence the remote will not stop this fromhappening. Both the remote and thekeyboard go to the microprocessor in the set but keyboard is first in line.
How to resolve this issue?
Someone needs to get at the tiny pc board with the buttonsand locate the one associated with the issue (ie sound or channel etc) andunsolder that switch from the board-usually just two pins (may be more formounting only purposes) and then see if set does not have the issue with switchout of the circuit.
For the TECH minded with the board out test here theswitches with a ohm meter set to high resistance-any reading with button notpressed means a bad switch-seen ones that read 5,000 plus ohms-it may benecessary to unsolder more than one switch to locate the offender here butan open reading with switch not pressedis the rule.
I have taken the time to compose this answer as some do notunderstand what is happening in these types of situations---No magic wand orsmoke and mirrors here-have to disable the offending switch to know.
The beauty (in my view) of this kind of problem is if found, you really do not have to replace anypart-just operate the set with the remote with one button that no longerfunctions on the set itself-who could ask for more?
SD TECH
Jun 01, 2012 | Toshiba Televison & Video
Volume increases to 100 or drops all the way to 0 when pressing the volume button on either the remote or back of the tv. I can't control the volume I want.
A problem that is more common than most people think is anissue with buttons on the controlkeyboards of modern TV sets.
Recently for whatever reason I have seen more questionsabout this so I have composed this answer and solution for these kinds ofproblems.It can be any button on the set-channel up/down or volume updown-you name it.
For the TECH minded with the board out test here theswitches with a ohm meter set to high resistance-any reading with button notpressed means a bad switch-seen ones that read 5,000 plus ohms-it may benecessary to unsolder more than one switch to locate the offender here but an open reading with switch not pressed is therule.
SD TECH
May 30, 2012 | LG Televison & Video
Coby tv changes inputs on its own
SD TECH
May 30, 2012 | Coby TFTV2425 24 in LCD TV
Tv stuck on menu
Both the remote and thekeyboard go to the microprocessor in the set but keyboard is first in line.How to resolve this issue?
SD TECH
May 23, 2012 | Philips 42PF9630A 42 in. Plasma Television
Menu box keeps popping up pushing clear or the menu button only stops it for a few seconds
Keyboard issues and answers:A problem that is more common than most people think is anissue with buttons on the controlkeyboards of modern TV sets.Recently for whatever reason I have seen more questionsabout this so I have composed this answer and solution for these kinds ofproblems.It can be any button on the set-channel up/down or volume updown-you name it.The symptoms are the same: channel will scan up or down andwill not stop-remote control has no effect on this---It can be channel, volume,or even input or menu if the set has those up front or on the side of the set.All these push controls have something in common-beneatheach is a tiny momentary push switch-when pushed with the plastic button itperforms a specific task (vol up or down etc.).What happens is the afflicted switch beneath the plasticbutton is bad-when released it is supposed to stop its function but does not.Keyboard or button controlled features have PRIORITY over the remote control, hence the remote will not stop this fromhappening. Both the remote and thekeyboard go to the microprocessor in the set but keyboard is first in line.How to resolve this issue?Someone needs to get at the tiny pc board with the buttonsand locate the one associated with the issue (ie sound or channel etc) andunsolder that switch from the board-usually just two pins (may be more formounting only purposes) and then see if set does not have the issue with switchout of the circuit.For the TECH minded with the board out test here theswitches with a ohm meter set to high resistance-any reading with button notpressed means a bad switch-seen ones that read 5,000 plus ohms-it may benecessary to unsolder more than one switch to locate the offender here but an open reading with switch not pressed is therule.I have taken the time to compose this answer as some do notunderstand what is happening in these types of situations---No magic wand orsmoke and mirrors here-have to disable the offending switch to know.The beauty (in my view) of this kind of problem is if found, you really do not have to replace anypart-just operate the set with the remote with one button that no longerfunctions on the set itself-who could ask for more? SD TECH
May 22, 2012 | RCA HD52W59 HDTV Projection Television
My emerson lcd tv lc320em1 has volume issues. Volume turns up by itself, constantly. All the way up.
SD TECH
May 20, 2012 | Emerson Televison & Video
Input keeps switching n it own
May 20, 2012 | LG 32LG30 32 in. LCD HDTV
My volume keeps going up on my apex tv
May 15, 2012 | Televison & Video
May volume keys on my keyboard are not responding. My speaker/headset volume is inaudible. whenever I press the volume keys on my keyboard, nothing happens. the same as when i click the volume symbol on...
They are actually two separate issues:
I will assume that you have funtioning speakers or headset.
1) first fix your main audio problem by re-installing your sound card driver that would normally come with your PC/Laptop or (external) Sound Card. This should fix the issue with your software volume control
2) second fix your Keyboard volume control: if after fixing your audio system driver previously, this is still not working, then you will need to re-install your Keyboard 'soft' key driver that control the extended function of your specific keyboard: the driver may also be included as part of your PCLaptop but may also have come with a 'third party' non-orininal keyboard.
Hope it helps & good luck!
Dec 25, 2009 | Computers & Internet
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
