Question about Fisher and Paykel Washing Machines
My fisher and paykel won't power on - Fisher and Paykel Washing Machines
    Habit-Forming:
    Scholar:
  • Fisher and P... Expert
  • 170 Answers
Model number would be a help. In a few cases (some models) no power can be caused by a faulty drain pump but 99 times out of every 100 no power is because the main control board has shorted out and needs to be replaced.
Posted on Dec 24, 2016
  • 93 Answers
SOURCE: no power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
Posted on Jul 10, 2009
SOURCE: Fisher and Paykel GWL08: Will Not Power ON
It's been a while since I fixed mine... So I am not sure if this fixes your problem. For some reason, some of the electronic components (touch panel) get wet inside. You need to take out the electronics touch panel, wipe it off, if wet (BTW it is not difficult). Make sure you know where and how everything goes back together. On mine, I found rocker switch that got wet and corroded. If found the model on line (Cherry Semiconductor, ordered it and now works
Posted on Dec 15, 2009
  • 159 Answers
SOURCE: my fisher paykel washer stopped in the middle of a...
Either the computer board is dead OR the pump was on it's way out & took the board with it.If your lucky the pump is just dead & therefore not providing power up to the board,thats the cheaper way to go first.Or you may be up for both.It was probably pumping out at the time when it stopped.
Posted on May 29, 2010
  • 30 Answers
SOURCE: Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
Posted on Jun 08, 2010
  • 713 Answers
SOURCE: My fisher paykel top loader won't do a cold wash.
Hi just read your posting.Have you selected cold only?Are the hoses from the taps going to the correct water valve?Cold tap to c on the machine and hot tap to h on the machine.What is the model number of the machine?The model number sticker is on the back of the machine up top.Please reply with additional information and I am sure I can help rectify the fault.Looking forward to your reply/
Posted on May 21, 2011
Fisher Paykal 602 dishwasher - top drawer won't power on
Most likely the thermal fuse (inside heater assembly) is blown.
Not easy to repair. Need to replace the whole heater at the base of drawer.
Mar 28, 2013 | Fisher and Paykel Dishwashers
Machine beeps 3 lights on and won't pump water out
can you take a picture of the lights that are on so I can work out the error code thanks
Jan 29, 2013 | Fisher and Paykel Fisher & Paykel Washer
Fisher paykel dishwasher dd603 won"t turn on.
Is the problem with both the drawers or just one.
When you say - will not turn on - does it mean you get a blank display?
assuming mains power is turned on (no problem with circuit breaker), then it is likely the power board at the base of dishwasher (under the bottom drawer) is faulty and needs replacement. Make sure mains power cable is taken out when you work on the dishwasher.
Dec 11, 2012 | Fisher and Paykel 23 in. DD603H SS...
Fisher paykel gwl15 won't power on
Did you pump make loud noises before the machine stopped.
if pump did, replace pump and get the fuse in the board replaced.
Oct 08, 2012 | Fisher Paykel EcoSmart GWL15
Fisher and paykel won't let water in but just sensing water level non-stop
Any switch the same size will work there fine,
It must have the three pins,com, nc, no on the switch.
May 08, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel GW509 won't power up, pump not blocked, plug loose?
62. (00111110) Phase 5 - Pump Over Current
The Motor Controller module has detected an excessive pump current.
Primary Source: Pump.
Action:
Replace Pump.
Secondary Source: Motor Controller module.
Action:
Replace Motor Controller module.
107. (01101011) Phase 2 to 6 - Motor Controller module Reset Error
The Display Module has detected that the Motor Controller module has reset when
it should not have. This can be due to a Motor Controller module supply
disturbance or microprocessor failure.
Primary source: Motor Controller module.
Action: Replace Motor Controller module.
Red, Blue, Yellow go on the motor
Brown , White go on the pump.
Apr 13, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel Ecosmart WA37t26gw2 won't drain
Check your belts and replace if faulty
turn the pump by hand with belt off to see if pump is jammed
still no go, you may have a faulty electronics board.
Oct 30, 2011 | Fisher and Paykel GWL11 Top Load Washer
Hi My mw512 fisher paykel washer won't Drain,how do i remove the drain pipe at bottom of tub? it won't seem to just pull off, des it need to be turned? cheers Michelle
I have a model 11, but I believe they are the same. The end at he outlet of the pump actually has tabs on it. Just twist and pull. Make sure the tabs are ligned up with the slots before you pull too hard.
May 09, 2011 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
29 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
