Question about Vacuums
E brush assembly on ocean blue vac needs to be cleaned. How do I get it open to free the passageway?
5 Suggested Answers
SOURCE: Cleaning brush assembly on steamvac
Yes this does come apart. The clear plastic pieces clip into the black plastic piece, flat tip screw driver inserted into the gap can release the clips and allow for cleaning.
Posted on Dec 25, 2007
SOURCE: spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Posted on Feb 16, 2009
Dissolu
  • 221 Answers
SOURCE: Hoover Steam Vac with Clean Surge model #F50905-900
All you need for your item is the belt.dissassemble the unit and you will se the track where the belt was, or even the old ne snapped an trapped somewhere inside. brush assembly purchase will not solve this.
update me about your progress.
Good luck
Posted on Jun 24, 2009
  • 12 Answers
SOURCE: hoover steam vac, brushes won't
There are three things to check when experiencing 'no spin' on the cleaning brushes. 1) Check the small pull out filter screen under the machine. It must stay clean for air to pass to the turbine which powers the brushes. 2) Check that the long shaft on the brush assembly is not broken off. This shaft inserts into the turbine motor and powers the brushes. If you're handy you can replace just the long shaft brush rather than replacing the whole brush assembly. Look for the brush on Ebay 3) If you're handy you can dissemble the machine and inspect the turbine motor which powers the brushes. In all cases the bearings seize in the turbine. You can often free them up and re-lube them to get more service from them or simply replace the turbine assembly. Don't throw your Steam Vac out because the brushes no longer turn...you can fix it!
Posted on Oct 22, 2013
How to clean brushes on hoover steam vac
Hi, it's Allie from Crucial Vacuum!
Cleaning the brushes on your unit is crucial in maintaining your Hoover performing at it's best and it is very easy to do. First, make sure your unit is off and unplugged, and make sure to remove the clean and dirty water tanks to avoid any possible leaking.
With the handle in the upright position, tilt the unit back and rest it on the floor. Grad the brush assembly and pull firmly until you remove them from the unit. Clean the brushes with running water until the water runs clear and the brushes are clean.
You can purchase direct your replacement items from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
http://www.crucialvacuum.com
Aug 21, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
I have power on the rotating brush but no vacuum?
First check the filters. If the motor is running properly and the filters clean the most likely problem is a blockage in the tube from behind the brushes pet hair is good at blocking any vac, make sure the vac is disconnected from power then unscrew the assembly under the vac that holds the brushes the drive belt and the tube, once free you should straighten out an old wire coat hanger and prod it through to the inspection flap at the rear of the vac, if this is clear try the same procedure with something more substantial than a coat hanger on the detachable suction hose that you use for getting into corners. If there is no blockage I am sorry that is the limit of my experience.
Feb 01, 2011 | Dyson Slim DC18 All Floors HEPA Bagless...
I have a hoover steam vac f5899-100 the brushes doesnt spin...everything else works but tha. we took the brushes apart to clean
if after you cleaned the brushes and still doesn't work. it will have to be the turbine assembly that the brushes fit into.
Jul 20, 2009 | Hoover F5899-910 SteamVac Vacuum
Good luck
Jun 24, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Spin brush removal
follows:
white piece.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Brushes do not spin
The manual suggests cleaning the filter screen near the brush assembly. This is located on the bottom of the unit. In cleaning this it did not successfully help. I then proceeded to take the cover (blue) off the motor an brush drive and worked my way to the gear assembly. This is where I found the actually problem.
The problem: The brushes are driven by a turbine wheel operated with suction from the vacuum. In my unit the turbine and bearings became loose or slipped to the point that the worm gear lost contact with the additional gears that drive the brush. When resetting the assembly so that ample contact is established the unit began to operate fine.
This can be complicated to explain and illustrate therefore taking the unit in for repair is recommended. If you are confident in repairing the unit yourself then go for it.
Jul 28, 2008 | Hoover F7452-900 SteamVac Upright Vacuum
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Vaccum stops cleaning after a while it shuts off
Sounds like the motor is overheating and thermalling out (Hight Temp shut down). This could be caused by overfilled cannister, obstructed passageways, or debris accumulated around the motors cooling fan. Try emptying the catch container and blow out / clean all the filters. Check for obtructions by going to the hose mode and alternately blocking and uncovering the nozzle end - feel for good suction and listen for a definite change in motor sound (Pitch Change) With the intake open, the motor should rev freely, when blocked it will slow and sound labored / loaded down. Another possible cause could be a binding brush roller overloading the motor - but this will usually burn out the belt first. Notice any unusual smells? Burned belts stink like burnt rubber.
Jun 01, 2008 | Fantom Vacums FM760 Twister 500DX Bagless...
Hoover brushes stopped spinning
THE TURBINE WHICH DRIVES THE BRUSHES RUNS OFF SUCTION, A POOR DESIGN IN MY OPINOIN THEY GO BAD ON A REGULAR BASES. PROBABLY HAVE TO REPLACE TURBINE ASSEMBLY
Mar 27, 2008 | Vacuums
Nov 10, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
