My gwl15 won't power on - Washing Machines
  • Washing Mach... Master
  • 5,323 Answers
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures. Washing Machine Repair Help
Posted on Jan 06, 2017
Power button on GWL15 has issues
You will need to get a new tac switch installed into the display board
and put some clear packing tape over the crack on the decal to stop water getting in again and wetting the new switch.
Dec 06, 2012 | Fisher Paykel EcoSmart GWL15
Fishwe&Paykel GWL10 won
It could be the out of balance switch faulty & need replacing.
Nov 17, 2012 | Fisher Paykel EcoSmart GWL15
Fisher paykel gwl15 won't power on
Did you pump make loud noises before the machine stopped.
if pump did, replace pump and get the fuse in the board replaced.
Oct 08, 2012 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel EcoSmart GWL15 NO POWER Doesnt turn on. Outlet is fine, power to the house and no breaker problems. It simply wont turn on.
Whoops- answered you other posting first, sorry ;-0)
The same thing applies- I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 22, 2011 | Fisher Paykel EcoSmart GWL15
My fisher gwl15 washer won't power up, any help
This is usually a sign the controller module has expired.
Jun 05, 2011 | Fisher Paykel EcoSmart GWL15
My washer, model # GWL15, hums and vibrates when not washing anything. I now have it unplugged and it started doing it again.
Hi just read your posting.From the information in your posting when the machine is not being used and the power at the power outlet is turned on your machine hums and vibrates until you turn the power off,Is this correct?Please verify that I understood the information in your posting by replying back and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 15, 2010 | Fisher Paykel EcoSmart GWL15
GWL15, no display lights or power
Hi just read your posting. Now there are 2 reasons why your machine will not power up.They are 1--your motor controller is faulty. 2--Your drain pump is faulty.If you have or can borrow an electrical test meter I can guide you throe finding the faulty part and then repairing it.Sorry to ask you this but are you 100% sure you have power at the power point? Hope this helps and if you need further help please reply
Jun 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
No power washer will not work
Sounds like a control board failure, sparks are never a good thing. Better to get a serviceman look at it unless you are an electrician and can do an insulation test after working on it.
Feb 03, 2009 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
