Can't get phone on to access anything!
SOURCE: I need the access code to pair it to my cell phone.
Follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
So - 0000 (four zeroes)
hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
SOURCE: Sync SGH-A707 Samsung cell phone problem
Your phone needs the main ribbon, that is the cable that connects to the side of the with the battery to the side of the phone with the screen.
NB: a professional technician has to fix this.
br,
www.phonefreedomjamaica.net
SOURCE: Need to reset samsung galaxy s2 phone. Can't
If you want to try a simple solution, Go to Settings, Wireless and Networks, then Turn on "Airplane Mode" wait until you see an airplane on the top status bar of your phone... then Turn OFF "Airplane mode"
If that doesn't work, and you want to reset your phone, take it to the place you bought it or any place that is on your carrier.
SOURCE: I need a manual for my Samsung Galaxy
Did you tried to search on Google.com? i think on samsung's official website you can get free download manual.if need further help post comments.
SOURCE: why my samsung galaxy s gt i9003 cell phone reeboot automatically
This is controlled in your settings menu under 'Fixed Dial'. (or similar command). You will need to change this setting.
I do not have a copy of the user guide for your phone but for most phones these are the directions:
When you turn on fixed dialing, you
can call only numbers stored in the
fixed dial list.
Turn fixed dialing on or off:
- > Settings > Security > Fixed Dial
Use the fixed dial list:
- > Settings > Tools > Dialing Services
> Fixed Dial
